Results 1 to 7 of 7
  1. #1
    Still swirls. Skipped a step?
    Join Date
    Mar 2009
    Posts
    103
    Issue is, I'm having trouble removing swirls left from rotary, wool pad and SSR3.
    Next I used rotary with orange pad and SSR2.5, then PC with green pad and Poli-Seal.
    I'm thinking my 2nd step is not abrasive enough, maybe the SSR2.5 breaks down too quickly.
    Thought?
  2. #2
    Re: Still swirls. Skipped a step?
    Accumulator's Avatar
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,268
    b34tBoX- Maybe the 2nd step is instilling swirls of its own Are you sure it's still the wool/SSR3 swirling that you're seeing?
  3. #3
    Join Date
    Mar 2009
    Posts
    103
    I'm seeing the swirls being created with the wool pad combo. The 2.5 and orange pad doesn't seem to minimize the appearance of them at all, or should I say not as much as I would like.
  4. #4
    DetailKnight's Avatar
    Join Date
    Mar 2011
    Location
    Capon Bridge,WV
    Posts
    73
    Try using the PC with an orange pad and SSR2.5, then the PC with green pad and poli-seal. In other words... I think you did skip a step!
    Knights House of Detail Mobile Detailing and Pressure Washing...Capon Bridge,WV... 540-686-2927
  5. #5
    Join Date
    Mar 2009
    Posts
    103
    Ok. I'll try that.
    I figured I would get more correction power by using the orange pad with the rotary.
  6. #6
    Join Date
    Mar 2011
    Location
    Capon Bridge,WV
    Posts
    73
    Quote: Originally Posted by b34tBoX View Post
    Ok. I'll try that.
    Do it with the orange pad on the rotary, then do it with the PC with the orange pad to remove marks left by the rotary!
  7. #7
    Join Date
    Mar 2009
    Posts
    103
    Awesome, yeah, the orange pad and rotary was doing nothing to remove swirls!
  1. Replies: 26
    Last Post: 11-23-09, 12:35
  2. Replies: 33
    Last Post: 09-16-08, 10:37
  3. Should have skipped the Flex?
    By Jeff Laughhunn in forum Machine Polishing & Sanding
    Last Post: 06-04-08, 04:13
  4. does DACP always cut it for the first step for the swirls in most cars?
    By quamen in forum Professional Detailer General Discussion
    Last Post: 03-16-04, 06:25
Posting Permissions
  • You may not post replies
  • You may not edit your posts
