Last
Results 1 to 12 of 33
Thread: Rotary polishing videos
12-04-09, 08:43 #1
- Join Date
- Nov 2008
- Posts
- 52
anyone hear of this stuff before? looks a lot like this hd uno stuff. anyways, cool videos showing how to properly polish with a rotary buffer.
Clearcoat Solutions Inc.
12-04-09, 09:10 #2
Re: Rotary polishing videos
Just watched the first video and he says he's sanding to remove oxidation?
My guess is because it's an original 1972 Ferrari it's a single stage paints and while they do oxidize easily you don't have to sand to remove oxidation you can remove oxidation using a lot less aggressive products and methods and then you won't have to risk making a mistake removing sanding marks using a rotary buffer with a wool pad and a compound.
I'm not saying his approach is wrong, but as someone that's restored a lot of antique and original single stage paints sanding usually isn't my first choice especially if retaining the original paint is the highest priority.
12-04-09, 09:15 #3
I like his cart and how he has the pad washer elevated.
He's right about the pad washer, it will clean a dirty pad and with a new pad it will remove a lot of the loose fibers. You don't need a high speed when cleaning the pad but the part he forgot was to lift the buffer up a little with the pad still inside the bucket and under the lid and then bring the RPM's up to a higher speed and this will zing out most of the excess water and cleaning solution.
Not a big deal, just something we show in all our classes.
12-04-09, 09:21 #4
Isn't Tom Horvath the creator of System I products?
Just watched his buffing section, I would have used a smaller wool pad for inside the scoops and taped off the high body lines if this car were truly something I didn't want to risk making a mistake on. I would have also covered up all the wiper blades because no matter how GREAT you are with a rotary buffer you will always throw a little splatter and it's paint to clean little white dots splattered all over black wiper arm assemblies as well as anything else it lands on.
Personal preference.
I still wouldn't sand off oxidation especially if one of the goals was to NOT remove factory orange peel which he eluded to.
Nicely done videos though...
12-04-09, 10:16 #5
- Join Date
- Mar 2009
- Location
- Lawrence, Ks
- Posts
- 99
This may be a stupid question, but is he going way too fast or do I just buff really slowly
(And I'm talking about the speed he goes over the surface, not the rpm's of the buffer itself) I was always taught that the slower you go the less swirls you will get etc. If someone could enlighten me I would appreciate it!!!
12-04-09, 12:18 #6
[QUOTE=Mike Phillips;1335947]Isn't Tom Horvath the creator of System I products?
not sure if he was creator but i do know he was in all of System 1 video. and looking at the product info t looks likw this is just System 1 relabled
12-07-09, 04:51 #7
The 3000 grit DA disc isn't course at all. A medium polish would easily level that.
If anything, it just helps to remove whatever contaminants. Kinda like claying.
12-07-09, 04:55 #8
Yes thats Tom the creator of system one and his new system
Ron
Makita,Metabo,Flex3403,603VV Rotary's,Flex3401,UDM,PC,PC7424XP,Griots 2Aztec HotRod,Camspray 1500A PW,CamSpray Foam Cannon
12-07-09, 05:31 #9
- Join Date
- Jan 2008
- Posts
- 32
Yes, Tom Horvath created System One. He also created the CSI line. He doesn't work at System One anymore.
12-09-09, 02:11 #10
12-09-09, 03:23 #11
12-09-09, 05:09 #12
- Join Date
- Jan 2008
- Posts
- 32
The Geek had that pad washer on sale for $99 (regular price $139) so I bought one. I should receive it next week.
It's a little expensive, even on sale, but it's super-easy to use and when you're working on fussy paint, you don't want to wonder if it's your dirty pad that's making things difficult.
The cart looks cool too, but I doubt I could afford that if I was almost too cheap to buy the pad washer.
Autopia Guide to Detailing: Over Polishing Paint
By Autopia Expert in forum Guide to DetailingReplies: 22Last Post: 05-10-12, 02:21 -
Rotary on the cheap: $20 rotary & System One (long)
By Radian78 in forum Machine Polishing & SandingReplies: 17Last Post: 03-10-08, 11:35 -
Using the Porter Cable 7424 Car Polisher
By Autopia Expert in forum Guide to DetailingReplies: 0Last Post: 11-10-06, 12:09 -
polishing with a rotary question...
By wannafbody in forum Machine Polishing & SandingReplies: 2Last Post: 11-10-05, 01:42 -
Adapter to use PC backing with a rotary....
By AlexRuiz in forum Car DetailingReplies: 14Last Post: 02-16-05, 09:31
LinkBack URL
About LinkBacks
