Page 2 of 22 FirstFirst 123456789101112131415161718192021 ... LastLast
Results 13 to 24 of 261
Like Tree1Likes
Thread: Rotary Usage
  1. #13
    Autopia Master Trooper
    PrinzII's Avatar
    Join Date
    Jul 2001
    Location
    Gilbert, AZ
    Posts
    5,740
    I did something I haven't done since the age of 19. That's right. I used a rotary buffer on a Land Cruiser. But in a nutshell, I think I need to get some more practice (and my own DeWalt Buffer). The buffer I used was a Wen and it had a wool bonnett that would flop around.
    Shift_Cactus!
  2. #14
    theveed's Avatar
    Join Date
    Feb 2002
    Location
    Singapore / Manila
    Posts
    1,154
    Great info guys, especially Andre... Thanks...
    BTW, how many panels can your pad cover before "caking" up? I found that my W7000 pad cakes up about half a hood or so. I'm only using about a quarter size drop of product per 1/3 of the hood (or 2sq ft.)
  3. #15
    Andre''s Avatar
    Join Date
    Mar 2001
    Location
    Cincinnati, OH
    Posts
    672
    You should use more product than that, say two or three quarter size drops. I can polish 1/4 of a car before i need to spur the pad with a brush.
    BTW your welcome.
    Andre'
  4. #16
    theveed's Avatar
    Join Date
    Feb 2002
    Location
    Singapore / Manila
    Posts
    1,154
    so the lack of product is my main reason of residue? i'll give it a shot...
  5. #17
    Andre''s Avatar
    Join Date
    Mar 2001
    Location
    Cincinnati, OH
    Posts
    672
    Yes it could be, try using more product and see it may help.
    Laters.
    Andre'
  6. #18
    Taxlady's Avatar
    Join Date
    May 2002
    Location
    DDO (Montreal), Quebec, Canada
    Posts
    1,107
    DavidB wrote a great article about using machines for buffing and polishing. There is a whole section on using a rotary. It's in Detailing Articles and Tips:
    Machine Buffing
    Always do right. This will gratify some people and astonish the rest.
    --Mark Twain
  7. #19
    theveed's Avatar
    Join Date
    Feb 2002
    Location
    Singapore / Manila
    Posts
    1,154
    I've read that already... needed more info... thanks.
  8. #20
    NY detailer's Avatar
    Join Date
    Feb 2002
    Location
    Staten Island, NY
    Posts
    1,641
    I would practice as much as possible. Be very careful before you use the rotary for real. Everyone makes mistakes and it is very easy to burn the paint on the car.
    Like showroom said, slower is best and work the speed up, i never go past speed 3.
    good luck
    Love to make old cars look new and new cars look better!
  9. #21
    Join Date
    Jun 2002
    Location
    Las Vegas
    Posts
    7
    Here is a car with pretty bad swirls. I used a yellow pad and very low rpm's. If you hold the pad on and angle and move fast with high rpm's you will see the hologram effect. When you flaten the pad and slow down on the rpm's you will see them disapear. Most production line detailer dont go far enough, the last step thats why you see those holagrams.
    http://www.washman.biz/pictures
    Easy money this detailing stuff
  10. #22
    Chuckmotor's Avatar
    Join Date
    Dec 2001
    Location
    Charlotte, NC
    Posts
    651
    About a month ago, I was trained by a pro how to use the rotary, and I've been practicing ever since. I've gotten pretty good at it-- no more splattering, sputtering, or slipping, just a smooth ride. In fact, I bought the Makita recently to aide my weekend business. I had a '92 Camaro that was in pretty bad shape and had no gloss, but a wool pad shined it up very well. After I finished, I smoked up the tires on the Camaro (with permission!). We went to a back alley/parking lot and I revved that American muscle up and slammed the gas. I accelerated to about 60 mph and then stopped and took a look behind me-- beautiful gray smoke. When the smoke cleared, I admired my long, parrarel lines of tire rubber on the pavement. Oh yeah, the rotary! The car looked great, and I feel very comfortable with a wool pad after a couple weeks with a lot of practice. I haven't left any buffer marks, burns, or bad swirls yet, so I think I'm doing ok. The key to a great finish is the right combination of pads and chemicals, and a slow, steady pace at under 2000 RPM. If you keep the pad flat and moving, you will not hurt the car.
    -Chuckmotor
  11. #23
    theveed's Avatar
    Join Date
    Feb 2002
    Location
    Singapore / Manila
    Posts
    1,154
    Great tips Chuck...
    Question... what do you do on tight painted panels like in between the bumper and the taillight, under emblems, etc where the painted surface is small (about 3-4")?
    How about bumpers? The areas on a bumper where it's ridged, gapped (for air passage like grilles), etc that are painted? Do you do those by hand instead?
  12. #24
    Join Date
    Jan 2002
    Location
    North Jersey
    Posts
    331
    THe buffer should aways be on the move. If it skips you may have to recenter the pad on the adapter so the pad spins in a circle. Also, try more product to load the pad. Never run the machnine on a dry surface.
    Dont think about burning the paint. Just remember that a clear coat is very hard and will not burn easily. As long as you are using the right products of course, ie. cc compounds, and high speed polishes.
    Finally, make it a point to be more carefull around edges like door handles, wings, mirrors, where the panels end and a new one begins, and moldings. Anything plastic or rubber needs to be taped off.
    Ryan
    Ryan
    Yes! There must be a smarter way to do this.
LinkBacks (?)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
