Results 1 to 1 of 1
Thread: Servicing the Makita BO6040.
08-29-09, 06:29 #1
- Join Date
- Jul 2009
- Posts
- 2
As you know any moving parts need some grease to work property.
It would be shame when your Makita/DA machine is broken:doublesho because of some grease problem. To prevent this I recommended you to take grease service for your lovely machine. This write up is for the Makita BO6040, but with some common sense
you can do this grease service for any polish machine:buffer:
Tools needed.
Good and right size Philips screwdriver.
Allen wrench.
Good grease.
Ice scream stick
or something silmular
10..9..8..7..6..5..4..3..2..1..lift off:driver:
-Remove the backing plate.
-Remove the seal plate.
-Remove the dust seal.
-Clean the machine before greasing.
-Greasing.
-Install all parts together.
-Switch the speedcontrol to the lowest range and connect the machine to the power outlet. Let it runs for to let the grease spread property into the gears.
-Done
(MUST SEE) Edge adapter for Makita BO6040
By agentf1 in forum Machine Polishing & SandingReplies: 35Last Post: 04-16-09, 11:57 -
Makita BO6040.....?
By YankeeFan in forum Machine Polishing & SandingReplies: 6Last Post: 03-31-07, 04:59 -
Makita BO6040 with what pads?
By Yuen in forum Car Detailing Product DiscussionReplies: 4Last Post: 02-18-06, 03:53 -
RO to Rotary adapter (Makita BO6040 to Makita 9227CB)
By littlejohn in forum Machine Polishing & SandingReplies: 8Last Post: 09-20-05, 03:21 -
Makita BO6040 : I ordered it
By cvcaelen in forum Car DetailingReplies: 4Last Post: 11-13-02, 05:29
LinkBack URL
About LinkBacks
