Old 09-30-07, 07:06   #1 (permalink)
Ari Gold
G35stilez's Avatar
G35stilez is offline
G35stilez will become famous soon enough
Using an amp/sub with stock head unit, questions...
So, I'm at my breaking point right now with these factory stereo in my company car, yet don't want to dump any cash in for a car that will be gone in a year. I still have my 10" Kicker Comp VR in a sealed box and Kicker 600 watt amp stored away from my Integra. I would really like to hook them up, so...
-What sort of equipment would I need outside of a 4-gauge wiring kit?
-Are there any adverse effects from doing this (other than lesser quality than if I used an after market receiver)?
-Where should I purchase these new products?
Best,
Sean
'02 Escalade
Old 09-30-07, 07:20   #2 (permalink)
Glossy Tundra
Brandon1's Avatar
Brandon1 is offline
Brandon1 is on a distinguished road
Send a message via AIM to Brandon1
Re: Using an amp/sub with stock head unit, questions...
Line Output converter, or something like the MTX signal converter. Your stock headunit contains eq that limits bass at higher volumes to prevent distortion in the speakers, so when you hook up a sub, it wreaks havoc on it's performance. You have to have something to kill that eq.
MTX re-Q Bass restoration signal processor Get full bass response when adding amps to a factory system at Crutchfield.com
You just hook this up like a LOC, then it allows max performance from your sub.
SHOWROOM SHINE DETAILS
YOUNGSVILLE, NC
2003 Toyota Tundra Trd 4x4 20" Enkei rims, Toytech 3" lift, Borla exhaust.
Old 09-30-07, 06:35   #3 (permalink)
Detailer
imageautodetail's Avatar
imageautodetail is offline
imageautodetail is on a distinguished road
pac and stinger makes converters for almost everything, call a independently owned audio shop in your area, should run about $100, they do an excellent job for company cars and leased vehicles
Old 10-02-07, 06:14   #4 (permalink)
Car Detail Noob
hXc drummer23's Avatar
hXc drummer23 is offline
hXc drummer23 is on a distinguished road
I would get a new headunit. My brother explained to me why it is better, but I forgot.
Old 10-02-07, 08:26   #5 (permalink)
Another hobby...
corvettecrazy is offline
corvettecrazy is on a distinguished road
Send a message via AIM to corvettecrazy
Yes it is possible. As Brandon1 mentioned some headunits do beging to limit bass to prevent distortion. But not all of them do this, I dont know much about infinity's stock radios so I can't tell you for sure. Even if the HU does beging to limit bass at higher volumes you should still be good to go at reasonable listening levels.
Now depending what kicker amp you have, will depend what products you may or may not need. If the amp has speaker level inputs (not all of them do) then you dont need anything special to hook it up to you car. Tap the rear speakers for the speaker level signal and then run it to the amp (as well as the rear speakers still). That would provide the amp signal for the sub.
Now if your amp does not have speaker level inputs you will need something along the lines of a Line Output Converter. May companies make then, heck I think even walmart sells them. They are a simple tap into the rear speaker wires, sometimes a power, ground, and then run the RCA's to the amp. They can be purchased almost anywhere. I might suggest crutchfield.com . Yes I know they have slightly higher prices but their customer support is top notch and they are awsome at working with you through wiring issues or any questions you have during the install. And their hours for customer support are even better (8am to midnight est. 7 days a week)
The issue I have with something along the lines of what Brandon1 stated (which is not a bad product at all) but if you are going to spend 150 for that why not get a cheaper aftermarket headunit and avoid the need for it all together.
Adverse effects, not really. Obviously it wont be aftermarket quality but you seem to know that. While it may not be aftermarket it is still going to be better than a subless stock system.
I hope that helps a little.
Old 10-03-07, 12:36   #6 (permalink)
94BlkStang's Avatar
94BlkStang is offline
94BlkStang is on a distinguished road
typically it's the amps in the system that are equalized and may limit the bass. As long as you bypass the factory amp you should get the full signal from the head unit. There are kits like suggested from PAC or other manufacturers that will bypass the stock system and allow a connection for an external amp and sub for many syatems. A good installer should be able to take care of it very easily.
Old 11-25-07, 04:33   #7 (permalink)
Ari Gold
G35stilez's Avatar
So basically:
-Confirm my amp has speaker level inputs, then tap into my rear speakers to get the signal.
-Run the power kit for the amp.
-Connect, tune, go.
What should I run my remote wire to?
'02 Escalade
Old 11-25-07, 06:28   #8 (permalink)
Another hobby...
Originally Posted by G35stilez
So basically:
-Connect, tune, go.
Personally I would connect your remote wire to a switched power source in the car. IE. something that is on when the key is in acc and the on position. I like this choice because when I am in my car I listen to music 95% of the time, so if the amp was on 5% of the time with no music on, no worries. (you can also add a switch to remote turn on wire. which would sovle the extra 5% of the time)
Old 11-25-07, 11:07   #9 (permalink)
Cooter's Avatar
Cooter is offline
Cooter is on a distinguished road
Send a message via MSN to Cooter
I always hooked my amp up to the fuse which controlled the radio when using at factory head unit.
Also, I thought you could get the line level converters for around $20 from PAC.
Questions Questions Questions 07CivicEX Exterior & Performance 3 04-24-07 02:25
Questions for those using the Vacuboom... kpagel Professional Detailer General Discussion 2 03-07-07 08:40
Is this a good head unit? kgb Exterior & Performance 9 02-12-04 05:19
need help deciding on a head unit pawg198 Car Interior & Electronics 12 04-18-03 09:17
