Autopia.org
Old 05-09-07, 10:50   #1 (permalink)
63vette is offline
63vette is on a distinguished road
63 corvette aftermarket audio system
I'm in the process of re-wiring my 63 corvette. Last year I had an Alpine unit installed in the glovebox. The guy that installed it hooked it directly to the battery. That worked fine as long as I remembered to turn it off when I turned off the car. This maybe a stupid question, but does Alpine or anyone else make an adapter that will connect directly from the alpine unit to the factory connection on my new wiring harness??
Old 05-09-07, 01:50   #2 (permalink)
Who? Me?
the other pc's Avatar
the other pc is offline
Cool Re: 63 corvette aftermarket audio system
Try Crutchfield.
PC.
Old 05-21-07, 12:48   #3 (permalink)
Pb2theMax's Avatar
Pb2theMax is offline
Pb2theMax is on a distinguished road
He hooked it up wrong. It should shut off when you turn off the igntion. There are 3 main wires for a head unit. Constant power to the battery, ignition, and ground. He probably didn't correctly hook up the ignition wire.
You need to get a wiring harness adapter for a 63 corvette, and then wire your Alpine harness to the loose ends.
05 Black Tacoma Double Cab V6 4x4 TRD Sport
My CarDomain
Old 05-21-07, 12:16   #4 (permalink)
63vette is offline
Thanks for the replies. I wasn't able to navigate the autodomain site to well. Tyhe site had some great rides, but I couldn't find any info to help with my problem.
Old 06-12-07, 01:01   #5 (permalink)
I used to run Washmaster
JRock10's Avatar
JRock10 is offline
JRock10 is on a distinguished road
Send a message via ICQ to JRock10 Send a message via AIM to JRock10 Send a message via Yahoo to JRock10
there isn't going to be a wiring harness for your vette. it's too old. what you need to do is go to the ignition harness. find the constant and the accessory wires, and connect the alpine accordingly. (red to acc, yellow to constant)
I own Pristine Detail Nashville.
Old 06-12-07, 06:01   #6 (permalink)
Setec Astronomy's Avatar
Setec Astronomy is offline
Wow, that installer must have been confused when there were only 14 wires, not 400 (like in a current car). Doesn't sound like much of an installer to me.
Grumpy like Ketch...
Old 06-14-07, 10:48   #7 (permalink)
JRock10's Avatar
JRock10 is offline
sounds more like a "buddy that installs" did the work.
Showoff your Audio System EdLancer Hot Tub 10 12-16-06 11:17
Basic Car Maintenance Guest Car Ownership 0 11-20-06 04:13
Zaino System Review and Commentary MCA Detailing Product Discussion 23 04-13-06 11:55
2006 Civic Sedan/Coupe Corey Bit Spank Car & Driver 23 07-08-05 10:12
Audio System to be installed very soon PrinzII Interior & Electronics 13 12-17-03 10:02
