Autopia.org
Old 03-31-08, 11:32   #25 (permalink)
paul34 is offline
paul34 is on a distinguished road
Re: HID lights
So all of you throwing HIDs into your halogen housing are ok with blinding oncoming traffic?
Unfortunately light distribution is much more complex of an issue than just aiming those halogen housings down.
ONR = Optimum No Rinse
Old 04-01-08, 06:55   #26 (permalink)
Autopia Master Trooper
PrinzII's Avatar
PrinzII is offline
PrinzII is on a distinguished road
Send a message via ICQ to PrinzII Send a message via AIM to PrinzII Send a message via Yahoo to PrinzII
Re: HID lights
In my case, I am not blinding oncoming traffic at all. I didn't even have to aim the low beams down because the Edge's low beam has a shield that kills the glare.
Shift_Cactus!
Old 04-02-08, 11:02   #27 (permalink)
Accumulator will become famous soon enoughAccumulator will become famous soon enough
Re: HID lights
Putting HIDs in the M3's (Euro) housings didn't work out very well. No problems with blinding oncoming traffic (at least nobody let me know) but the pattern isn't good enough for me; I just *know* it could be better, even though the guys at ECS Tuning think it's OK as-is.
I'm gonna swap 'em out for proper HIDs with the right housings.
Old 04-02-08, 02:20   #28 (permalink)
BuffMe is offline
BuffMe is on a distinguished road
Re: HID lights
Just to clear up some questions and put some facts out there...
There are halogen projectors and HID projectors. Halogen projectors do not have the proper cutoff shield necessary to put HID's behind them, they are manufactured to focus halogen light in a different pattern than HID lighting. So, be aware that it is possible to have projectors but not have the proper cutoff shield within the projector for HID's.
Also, note that it is possible to have "proper" HID lighting with a reflector housing and not a projector. Cars such as the Toyota Prius come stock with HID lighting without a projector. How is this? The bulbs are different. A HID bulb for a reflector housing will have a type of shielding around it, creating the proper cutoff (thus no need for the projector and cutoff shield). For example, Philips manufactures both kinds of HID bulbs. Their HID bulb meant to be used with a projector will be denoted D2S.
http://www.kbcarstuff.com/photos/PB-D2S-4K-2T.jpg
However, their bulb meant to be used with a reflector housing will be denoted D2R.
http://www.kbcarstuff.com/photos/PB-D2R-4K-2T.jpg
Notice the difference between the two. The D2R bulb has a shielding built around it to prevent light from spraying up away from the road. Note that while this does act as a shield, it is not nearly as crisp of a cutoff as can be achieved by using a projector and cutoff shield, but it still remains a MUCH better option than using nothing at all.
Also, 4300k is the brightest light possible for HID's. If you want the maximum output, go with those. 6000k tends to be a bit blue. However, I have found that 5000k kits are the perfect compromise. They are just a slight hint of blue but don't attract unnecessary attention due to it.
You get what you pay for in HID kits in the quality of the parts and the warranty. Many people get away with using cheap kits, many do not. It's a crap shoot, at best, if you're going for a budget kit.
Old 04-02-08, 09:52   #29 (permalink)
Enjoying Being 21
Monte78Carlo2k1's Avatar
Monte78Carlo2k1 is offline
Monte78Carlo2k1 is on a distinguished road
Send a message via AIM to Monte78Carlo2k1
Re: HID lights
I am in the process of retro fitting HID retro fits in my stock headlights for fun. Just because I don't want to worry about the proper cut off and the issue of blinding people. A lot of work but it should be worth it in the end. With that said I have gone and ordered a set of HIDs like most have just to see the differnce between stock regular lights - then HID lights in the stock housing - then whenever I finish my retro fit (still not legal but hey...) seeing the difference yet again.
BGB Mobile Detailing Service
My Cars: 78 Monte - 01 Monte LSX - 04 KB Cobra
Old 05-13-08, 05:44   #30 (permalink)
PedroDaGr8 is offline
PedroDaGr8 is on a distinguished road
Re: HID lights
I currently have FX35 projectors retro'ed into my Honda CR-V headlights. It is a great setup. Nothing compares to real HID projectors ( a few of the true hid reflectors are OK most aren't, halogen seldom if ever looks as good as the real deal).
Old 05-13-08, 08:00   #31 (permalink)
victory is offline
victory is on a distinguished road
Re: HID lights
Originally Posted by BlackElantraGT View Post
jsatek, IIRC you bought an inexpensive HID kit so I'm curious to know which kit you got and do you think those are real Bosch ballasts or Chinese knock-offs?
I don't doubt they're real. I've seen cheap kits come with hella ballasts as well.
Old 05-14-08, 08:01   #32 (permalink)
Re: HID lights
Oh there is no doubt that is fake. IIRC osch never made ballasts that looked like that, those are cheap chinese knock offs of Hella Gen III ballasts. Bosch never even made HID kits, EVER.
Old 05-14-08, 03:37   #33 (permalink)
victory is offline
Re: HID lights
Not surprising.
Old 06-20-08, 05:09   #34 (permalink)
Autobanh Motorsports
RZJZA80 is offline
RZJZA80 is on a distinguished road
Re: HID lights
are all headlights not adjustable? If for some reason your headlight beams cannot be adjusted up/down and left/right, then yeah maybe don't use HID's, but if they are, go ahead and adjust them accordingly. I've never seen HID's in a car that couldn't be adjusted down and worked perfectly.
Old 06-20-08, 09:09   #35 (permalink)
sal329's Avatar
sal329 is offline
sal329 is on a distinguished road
Re: HID lights
I have a set I put into my fiances 99 Accord they work great. When I first put them in we waited till night I had the car parked on the street with the lights on I drove my car commin at it and driving away from it it was blinding. Pulled the car in the garage and aimed the lights down a lil bit and did the same test and no problems. We have been driving it now for 5 months with 0 people flashing us or anything. They are a great approvement and for only $90.
Old 06-21-08, 01:07   #36 (permalink)
Re: HID lights
Originally Posted by RZJZA80 View Post
are all headlights not adjustable? ... I've never seen HID's in a car that couldn't be adjusted down and worked perfectly.
Adjusting won't solve the problem if the reflector/lens messes with the output in certain ways. I had a conversion like this on the M3 at one point and no matter how you adjusted the lights it was never right for both the driver and oncoming traffic. The reflectors (made for the characteristics of regular halogen bulbs) scattered the HID's bright light in ways that was very irritating to anybody looking at them.
How lights behave is primarily a matter of the reflector and lenses working *in tandem* with the bulbs...the combination simply has to be right or all the up/down right/left adjustments in the world won't fix it.
Why do police leave their flashing lights on? mikebai1990 Car & Driver 78 01-19-07 10:58
lights camryKev Exterior & Performance 2 09-09-03 01:46
silverFUSION bulbs Review adjulian Exterior & Performance 5 05-28-03 02:16
black car in the sun and under flourescent lights jpws6 Car Detailing 2 05-07-02 02:58
Turn on your lights hook Car Detailing 9 09-12-01 10:02
