05-25-07, 08:28
#25 (permalink)
| | Beach Bum Detailer
Joshua312 is offline
Join Date: Aug 2005 Location: West Michigan Posts: 2,787 | Re: My first "system"... Alright guys, went today to pick up some RCA cables and I also picked up a line out converter for my factory headunit.
I bought the 2 channel, there is also a 4 channel available.
My sub amp is a one channel and my front stage amp is a 2 channel...should I return the 2 channel for the 4 channel? It's all too confusing to me. | |
05-25-07, 02:43
#26 (permalink)
xtremekustomz is offline
Join Date: Apr 2007 Posts: 257 | Re: My first "system"... I think I read that you are using 1 component set and 1 subwoofer right? If so all you really need is the monoblock for your sub, and a 2 channel for the front unless you want to power the tweeters with the front side of the 4 channel and the mid on the rear. I run an amp on my tweeters, 1 on my midrange, 1 on my midbass, and 1 on my sub. I do all of this for a reason but if you are using a factory head unit with line out converter then the 2 channel and the mono will work just fine. If you have anymore questions just pm me and I'll do all I can to help you out. | |
05-25-07, 07:45
#27 (permalink)
| | Glossy Tundra
Brandon1 is offline
Join Date: Jan 2005 Location: Wrightsville Beach, NC/Louisburg, NC Posts: 1,860 | Re: My first "system"... Josh, you will need the 4-ch model. First 2 to power each of your RCA's on your front stage amp. The second 2 to power each RCA on your sub amp.
Just get either 2 2channel LOC or one 4 ch. Look up line output converter on caraudioforum.com for more info.
Good luck.
__________________ SHOWROOM SHINE DETAILS
YOUNGSVILLE, NC 2003 Toyota Tundra Trd 4x4 20" Enkei rims, Toytech 3" lift, Borla exhaust. | |
05-30-07, 03:13
#28 (permalink)
| | Beach Bum Detailer
Join Date: Aug 2005 Location: West Michigan Posts: 2,787 | Re: My first "system"... | |
05-30-07, 05:13
#29 (permalink)
| | Glossy Tundra
Brandon1 is offline
Join Date: Jan 2005 Location: Wrightsville Beach, NC/Louisburg, NC Posts: 1,860 | Re: My first "system"... Looks great Josh, I will get back to you with some advice on the h/u you need!
I am envious of that ED 13kv.2 sub and amp, should sound killer!
05-30-07, 05:48
#30 (permalink)
Join Date: Apr 2007 Posts: 257 | Re: My first "system"... Probably the best bang for the buck head unit out right now is the Pioneer 7800 or whatever the newest model is in that line. It has a true 4 volt out, time correction, built in eq, lots of nice features. If you don't mind getting an older unit look for a Alpine CDA-7998. They don't make them anymore and haven't for a few years but it the best cd player they have ever made. It does not have built in power though. | |
06-04-07, 04:52
#31 (permalink)
bholtmeier is offline
Join Date: Jun 2007 Posts: 16 | Re: My first "system"... Go to ficaraudio.com
Check out the FI "Q" ...awesome driver..for cheap | |
07-22-07, 11:08
#32 (permalink)
cherryspeed is offline
Join Date: Jul 2007 Posts: 32 | Re: My first "system"... Looking good, i think you are off to a great start. | |
07-27-07, 02:30
#33 (permalink)
Join Date: Apr 2007 Posts: 257 | Re: My first "system"... I know a guy that has an Image Dynamics IDMAX 12" for about $175 shipped. PM me and let me know if you want it. It is a $500 woofer. I actually use one myself. This thing plays LOW. It's -3db downpoint is at 10hz where most others are around 25-30. It is defintealy a sq woofer but man that thing can get loud. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 03:59. | | | |
