Autopia.org
Old 03-05-07, 09:56   #1 (permalink)
Catching the Detail Buzz
EOppie's Avatar
EOppie is offline
EOppie is on a distinguished road
Sound Deadening
Hey guys. I have a 06 Ford Escape Hybrid and I am looking to do some sound deadening on it. I really don't have much experience in this area and hoping someone could make a recommendation on where to start/good but not too $$$ products.
I am not looking to win an audiophile competition, just make the interior a bit quieter.
Old 03-05-07, 10:50   #2 (permalink)
Who does #2 work for?!?!
LastDetail's Avatar
LastDetail is offline
LastDetail is on a distinguished road
Re: Sound Deadening
Since it is a pretty new car the stock sound-deadening material should be in relatively good shape.
Are you looking to decrease road noise from the undercarriage i.e. wheel/tire noise? or noise that is coming into the car from other drivers/automobiles on the road?
I have always had good experiences with Dynamat, which by itself is not ridiculously expensive, however the cost to have it installed can be significant. If this is something that you are going to do yourself you could probably pull it off on a budget. However it has been some time since I attemtped to sound deaden a car so the prices might have changed.
I'm your Huckleberry
Old 03-06-07, 05:22   #3 (permalink)
:P
ZeusCGP is offline
ZeusCGP is on a distinguished road
Re: Sound Deadening
Pay somebody? It's easy as peel and stick.
If you go to ebay you can pick up a Dynamat Xtreme bulk pack for around $100.
Secondskinaudio.com with their Damplifier is also great.
Cheaper solutions would be Fatman, Edead, Peel&Seal...
It's really not that hard to do. But as LastDetail said, figure out what you want to quiet down first.
Old 03-06-07, 10:52   #4 (permalink)
Resident Tint-Master
seracis's Avatar
seracis is offline
seracis is on a distinguished road
Re: Sound Deadening
On the contrary, most OEM damping material is crap compared to just about anything available to the consumer. At work, we use Hushmat, but it's comparable to Dynamat. If you remove your door panels you will see a sheet of plastic which is more or less a dust barrier. If you remove the plastic sheet and replace it with Hushmat, Dynamat or any other product listed above, you will notice a huge reduction in road noise. Cover as much as you can. Get a grease pencil and trace your door panel on the door. Then when you remove the panel you will see where your "boundary" is. You don't want to see any damping when the panel is on.
Old 03-07-07, 05:46   #5 (permalink)
TaG 125cc
kompressornsc's Avatar
kompressornsc is offline
kompressornsc is on a distinguished road
Re: Sound Deadening
There's a good video on Crutchfield on how to install it in doors. I am going to tackle this project in the spring on both my Ridgeline & my wife's RSX-S - both have tons of road noise.
'06 Honda Ridgeline
Old 03-07-07, 07:09   #6 (permalink)
dgoff07 is offline
dgoff07 is on a distinguished road
Re: Sound Deadening
if your on a budget, i suggest using eDead sound deadening, in the eDead line they have a closed cell foam that blocks higher frequencies like road noise. I have had nothing but great results with it. you can also pick up some Jute or something like it at home depot or lowes, which is just like carpet padding. it is already under the carpet on almost every vehicle, but you can add it other places and it really helps!
Old 03-07-07, 07:34   #7 (permalink)
Uber-n00bie
2.5RS's Avatar
2.5RS is offline
2.5RS is on a distinguished road
Re: Sound Deadening
RAAMaudio - Quality and Value in Automotive Sound Deadening
Cheaper and better than Dynamat (Yes, I've used both) Get Some RaamMat and Ensolite foam, a few cans of his spray adhesive and you are good to go.
He has also got a good "How To" section, read through that. Its really not that hard to do, if you are comfortable popping off panels and pulling up carpet (Should be pretty easy on most vehicles)
Good luck!
- Andrew
"Nothing is really work unless you would rather be doing something else." - J.M. Barrie
Old 03-07-07, 02:56   #8 (permalink)
EOppie's Avatar
EOppie is offline
Re: Sound Deadening
I have heard good things about "Brown Bread" as well. I would be doing the install myself...seems pretty straight forward, just time consuming.
I guess I am looking to make the overall cabin quieter. The noise from the engine is not really noticible, more road noise.
Old 03-07-07, 04:55   #9 (permalink)
dmxsoulja3 is offline
dmxsoulja3 is on a distinguished road
Re: Sound Deadening
I second the Ramm mat
Old 03-08-07, 10:55   #10 (permalink)
EOppie's Avatar
EOppie is offline
Re: Sound Deadening
Has anyone used this "Spray Undercoating with Sound Block"? I think it is made by duplicolor.
I heard that people use it in their wheel-wells...don't know how that comes out. I am sure it does some to protect the undercarriage.
Old 03-08-07, 01:49   #11 (permalink)
tomstin's Avatar
tomstin is offline
tomstin is on a distinguished road
Re: Sound Deadening
I'm VERY happy with the RAAMmat, Rick is a very helpful guy! RAAMaudio - Quality and Value in Automotive Sound Deadening
Old 03-08-07, 06:20   #12 (permalink)
Come on! Fhqwhgads!!
Jngrbrdman's Avatar
Jngrbrdman is offline
Jngrbrdman is on a distinguished road
Send a message via AIM to Jngrbrdman Send a message via Yahoo to Jngrbrdman
Re: Sound Deadening
I have a friend with a 97 Supra that he has been cleaning up, and to assist with the sound deadening we put quilt batting behind all the removable panels in the doors and rear hatch area. Basically anywhere we could stuff it we stuffed it. That car is way quiet inside now. His goal wasn't really to kill all the sound. It was just to assist in cutting down the sound without spending a ton of money on something that wasn't really a top priority.
...it should be Encouraged!
Does this sound like a good method? ptownTSI Car Detailing 12 07-05-05 12:36
Is it really as bad as you guys make it sound? Stratous Car Detailing 24 03-29-05 05:59
What's a PC suppose to sound like? flip2jetta Car Detailing 4 10-14-04 11:29
sound deadening queston... ahunt01 Exterior & Performance 26 04-06-04 03:50
Does this sound about right?? 71chevelle Car Detailing 5 07-04-03 02:51
