Old 02-19-08, 09:14   #1 (permalink)
ravi.rajan is offline
ravi.rajan is on a distinguished road
Question Amplifier Tuning
Hi,
Need some help in tuning my car audio system.
Have an ALPINE 9887 HU with JBL GTO5355M 5 Channel App and Polk Momo series components, mid range and subwoofers.
Would like to know on how to exactly tune the above systesm (focus on crossover settings on HU and amplifier input level/cross over settings will help)
Thanks,
Ravi
Old 02-20-08, 07:10   #2 (permalink)
Glossy Tundra
Brandon1's Avatar
Brandon1 is offline
Brandon1 is on a distinguished road
Send a message via AIM to Brandon1
Re: Amplifier Tuning
When you start, make sure everything is installed properly. Make sure everything is in phase. Make sure all eq is set to flat, and soundprocessors off. Make sure all crossovers are off. Burn a cd with a 50hz tone. (Realm of Excursion) Then disconnect all of your wires leading to your speakers. Get a Digital Volt Meter. Then you have to do some math. Take the output to "ONE" channel of the amp (example, if I have a 50x4 amp, take 50) and then multiply it by how many ohms it will be running. ( Example, if I have a 50x4 (rms) amp that runs at 4ohms, multiply by 4). Then take the square root of that number. That will be the voltage that you will be looking to get from the amp.
Now hook up the+ and - to of the volt meter the corresponding terminals on one channel of the amp. Put the cd in and turn it to 3/4 volume. now slowly raise the gain on the amp until the # you got from the math problem, matches the # on the volt meter. Then set all other speakers in your system that same way.
For crossovers, I always use the crossovers on my h/u. I generally go with 80hz highpass at 18/db octave for front speakers, and 80hz low pass at 24db/octave for subs. DONT turn on the bass boost, or BBE or any of that junk, that just mixes signals and makes it sound worse.
Your system should sound pretty damn good after that.
Kinda odd first post for a "detailing forum"
SHOWROOM SHINE DETAILS
YOUNGSVILLE, NC
2003 Toyota Tundra Trd 4x4 20" Enkei rims, Toytech 3" lift, Borla exhaust.
Amplifier Tuning? Brandon1 Car Interior & Electronics 2 01-12-06 06:34
Escort 8500 tuning question ahunt01 Car & Driver 4 07-31-03 02:14
Pioneer recall; FYI Patrick Car & Driver 0 07-31-03 07:29
amplifier cd changer mounting dkj3 Car Interior & Electronics 2 02-13-02 04:42
