10-12-07, 04:47
| | Beach Bum Detailer
Joshua312 is offline
Join Date: Aug 2005 Location: West Michigan Posts: 2,787 | Computer Stuff... Hey guys,
I recently purchased a server and I plan on setting up a small network of 4 computers. One will be my MacBook, and then three desktops. Basically this small network will be for me to practice in Active Directory and other server roles. I have already purchased a Netgear 8 port ethernet switch, and will be buying a KVM switch as well for these machines.
I was just wondering if anyone has an old monitor (or not so old) they no longer have a use for (looking to spend under $150)...or any other ideas of things I should add to this network for testing.
The server will be running Windows Server 2003 Enterprise edition and set up as a File Server, DHCP server, DNS Server, and Active Directory.
Also, I want the server to have a static IP address and then within the properties in the server set the IP range for the client computers. Do I do this simply by changing my routers IP to a private IP like
10.0.0.1 and then my server would be 10.0.0.2 and then the clients would dynamically receive their IP address from the given range of 10.0.0.3 to 10.0.0.50 for example? | |
10-12-07, 05:32
reeeko99 is offline
Join Date: Feb 2005 Location: Denver, Iowa Posts: 92 | Re: Computer Stuff... On the 2003 Server setup DNS for resolution and DHCP to hand out a range of IP addresses
( Scope ).
DNS will allow you communicate easily with the other computers on your network.
DHCP scope will hand out IP addresses to the client computers for ever how many IP addresses you need.
Hope that helps.
You should be able to setup the routing through the DHCP scope.
Configure scope options will get you want you want. DHCP in Windows Server 2003 - Configure Scope Options.
Reeeko99, 07 Mazda3 S Touring Silver
10-12-07, 05:42
| | Master of Redundancy
jsatek is offline
Join Date: Mar 2006 Location: White Plains, NY Posts: 1,608 | Re: Computer Stuff... dhcp will hand out a range of addresses. you also can use a mac address of a lan card to reserve an ip so it will remain static each time the pc is booted
server ip's should be static, dns will resolve a name to the ip. | |
10-12-07, 05:51
rjstaaf is offline
Join Date: Jul 2002 Location: Upstate, SC Posts: 1,699 | Re: Computer Stuff... Joshua,
You have me curious after the other post about Windows Server 2003 and now this one, what are you up to? Are you going for a certification?
Just curious...
Bob | |
10-12-07, 06:05
| | Beach Bum Detailer
Join Date: Aug 2005 Location: West Michigan Posts: 2,787 | Re: Computer Stuff... Quote: |
Just curious...
Bob | Hey Bob,
Since that last thread on Server 2003, my instructor actually told us that because of the class we are enrolled in we have access to a website which gives us free software because of their deal with the University I am going to. So I have downloaded Windows Vista Business, Windows XP Pro, Visio, Project, Server, etc...but right now I am running all of these off from my virtual machine on my Mac and while it works nicely I would rather have the KVM switch so I can be logged in on all these machines/users at the same time...so I did some searching and picked up this server. Dell PowerEdge 2450 P3 2 x 933Mhz 512MB 2U SERVER - (eBay item 160165023220 end time Oct-11-07 09:46:31 PDT)
and basically I just want to set up a network in my home to test out and put to use what I am learning in my classes. It's nice to read the book and talk about it in class, but the real fun is when I can actually go in there and put it to use. After I complete this course, to answer your question, yes I will be taking the certification exam. Since I plan on continuing the CCNA courses I am hoping the site which I download these programs from is updated with the Server 2008 (137 more days!)...I remember seeing pictures of your setup before and it was very slick. Which KVM switch do you have if you don't mind me asking? I'll be sure to take some pictures once I get everything setup so you can see what kind of mischief I'm getting into  | |
10-12-07, 07:23
rjstaaf is offline
Join Date: Jul 2002 Location: Upstate, SC Posts: 1,699 | Re: Computer Stuff... Was it through the MSDN Academic Alliance? I am taking a C++ programming course at the College where I work and I was able to get a free copy of Microsoft Visual Studio 2005 for the course. The only problem is that the license was only good for 180 days so I went ahead and used my staff discount and bought the educational version since I will need the software for my next couple of classes.
I used the PowerEdge 2450 when I had my own business, they were great machines...
In my desk I am using an Avocent SwitchView MM2 4-port KVM Switch. It does not only video, keyboard and mouse but audio, microphone and includes a USB hub. There is a USB 1.1 and USB 2.0 version. I currently have the USB 1.1 4 port version which I got off of eBay a couple of years ago. Currently the USB 2.0 4 port version is going for about $250 on eBay and they retail for about $269. Avocent - SwitchView MM2 4-port KVM Switch
With the MSDN Academic Alliance, I was also considering getting a copy of Windows Server 2003 to play around with active directory in an attempt to get single sign-on and roaming profile functionality in my home network. It is a pain to do though with a mix of both Windows and Linux desktops. I have given up on it for now. Since then I discovered Fedora Directory Server which is a Linux based LDAP server and I may see how much of my initial plans I can achieve with it. Fedora Directory Server (Open Source LDAP) | |
10-12-07, 08:58
| | Beach Bum Detailer
Originally Posted by rjstaaf Was it through the MSDN Academic Alliance?[/url] | Yes! It is through the MSDNAA. I read through the FAQ section and it said the software is full license and the only thing which will change is when you are no longer enrolled in a Computer/Networking class you will no longer be able to receive updates for the program. I could care less if I received updates...as long as I have the software to play around with. It is definitely a great learning tool! We recently went through a seating restructure at the company I work for and I was able to use the Visio 2007 to create a map of all the computers and their associated ports..it made the move go so smooth!
Sounds like you have a pretty elaborate switch! I will probably just go with a cheapo $50 one I can find on ebay. I can't do too much more until the server gets here...quick question you may be able to answer. I am trying to set up a VPN and I have it set up on the following domain Computer.TestServer.local but I am guessing since I do not have a Public IP address to assign to it, I won't be able to connect to it from another computer?
10-12-07, 09:39
twitch is offline
Join Date: Jan 2006 Location: near New Orleans, LA Posts: 912 | Re: Computer Stuff... Congrats Josh it sounds like you are well on your way
What you are setting up is enough to play with and learn on without a doubt however I do see something that is missing in your scenario.
You have to find at least 10 of the most helpless people you know, call them "end users", and let them on the network. You'll learn more than you dreamed possible
Good luck man! If I come across a monitor I will let you know as well. The problem though is that it would be a CRT so it would probably be $$ to ship.
__________________ Scott - 04 G35 6MT Coupe - Club Flex | |
10-13-07, 05:25
rjstaaf is offline
Join Date: Jul 2002 Location: Upstate, SC Posts: 1,699 | Re: Computer Stuff... Quote: |
Originally Posted by Joshua312 Yes! It is through the MSDNAA. I read through the FAQ section and it said the software is full license and the only thing which will change is when you are no longer enrolled in a Computer/Networking class you will no longer be able to receive updates for the program. I could care less if I received updates...as long as I have the software to play around with. It is definitely a great learning tool! We recently went through a seating restructure at the company I work for and I was able to use the Visio 2007 to create a map of all the computers and their associated ports..it made the move go so smooth!
Sounds like you have a pretty elaborate switch! I will probably just go with a cheapo $50 one I can find on ebay. I can't do too much more until the server gets here...quick question you may be able to answer. I am trying to set up a VPN and I have it set up on the following domain Computer.TestServer.local but I am guessing since I do not have a Public IP address to assign to it, I won't be able to connect to it from another computer? | I think with the MSDNAA the terms differ for a lot of the software available through the program. Actually now that I look at the CDs, it is the set for Visual Studio that came with my Visual Basic text book that has the short term license. Sorry for the confusion there...
The KVM I have is probably more than you need for a server on a test network. I bought this one so that I could not only share the usual monitor, keyboard and mouse but since these are desktop machines I also wanted to share one set of speakers and I have a USB extension cable run so that I can plug in my USB stick without having to open the cabinet. The KVM works via keyboard shortcuts. It is ideal for sharing desktop machines.
Wish I had a spare monitor but I donated all my surplus equipment earlier this year. If you don't find someone with a spare, you might be able to find an LCD panel on eBay in the $50 range if you stay around the 15" size. I did a quick search and there seems to be a lot in this range. I have an affinity for Viewsonic and have had nothing but great luck with them. I have a 15" Viewsonic LCD that is more than 10 years old and still works flawlessly. An LCD will be less expensive to ship than a CRT and will be less likely to get broken during shipment.  | |
10-13-07, 06:49
| | Beach Bum Detailer
Originally Posted by twitch Good luck man! If I come across a monitor I will let you know as well. The problem though is that it would be a CRT so it would probably be $$ to ship. | Scott, good to hear from you!
Come on, you don't think I get enough of end users every day at work  I have decided to put my sisters computer on this server, my mom was a little weary since it was going to sit in between our bedrooms and she is always sneaking on it late at night, so I told her I would put a limit on the internet access through the router settings...but it would be good to actually have a computer to practice policies on with an end user using it daily. | |
10-13-07, 06:52
| | Beach Bum Detailer
Join Date: Aug 2005 Location: West Michigan Posts: 2,787 | Re: Computer Stuff... Bob, no worries on the spare monitor. I have been looking on ebay and I seen the Viewsonic brand a couple days ago but I was not familiar with them. I will take a closer look now and see if I can find one ending soon...if not I may just head out to Best Buy and pick up a nice one. It would probably almost be cheaper in a way to pick up an eMachines desktop which comes with a free monitor for like $400  | |
10-13-07, 02:48
| | Beach Bum Detailer
Join Date: Aug 2005 Location: West Michigan Posts: 2,787 | Re: Computer Stuff... Okay, so I think I have it set up now until I receive the server...
I have set up the Router to forward requests on Ports 5631 and 5632 to the routers WAN IP address to point to what will be the server's static IP address.
I don't think this will do anything browser-wise if I try to connect but it should help me remotely log-in to the server now outside of my network. I will just have to test it out once I set it's Static IP. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 02:01. | | | |
