08-06-07, 01:47
David703 is offline
What vehicle's fluid can eat through clear coat?
My car was on an auto transport but it was underneath a car. My car had fluid on the hood that leaked from the car above. I thought i could wash it off but it etched into the clearcoat. And the car was only on the transport for a week! What could this fluid be? Brake fluid? Trans fluid? What could be so acidic? Not oil.
08-06-07, 01:49
South Florida Style
themightytimmah is offline
Re: What vehicle's fluid can eat through clear coat?
Dot 3 (I think) brake fluid will do it.
08-06-07, 01:50
Setec Astronomy is offline
Probably brake fluid, that is pretty corrosive to paint. Coolant can be also, but usually only when it's hot. How big/bad is the spot?
08-06-07, 02:50
1981 Camaro Z28
BigJimZ28 is offline
your lucky!
I have had old brake fluid dissolve paint before I could grab a rag!
08-06-07, 03:40
David703 is offline
I wet sanded it out pretty good, but I can still see it at the right angle. I'm borrowing a paint thickness meter and see if I can go down anymore. Thanks all!
08-06-07, 03:58
94BlkStang is offline
Brake fluid is by far the most corrosive but it would have completely ate through the clear coat if it was on that long. Any fluid can, especially used fluids that have contaminants, could cause some etching if it's allowed to sit on the surface and dry for an extended period.
08-06-07, 06:05
Self Professed Knowitall
Grimm is offline
Yeah, I doubt it was brake fluid. Anything more than a few minutes and the paint is gone with that stuff.
08-06-07, 06:57
smprince1 is offline
Agree with everybody above ..... brake fluid is very aggressive and will eat paint.
08-06-07, 07:12
jasonmac is offline
Same here, though I've never experienced it! *knocks on wood*
08-07-07, 12:46
porcupine73 is offline
ethylene glycol coolants can mess up the paint a little bit. Yes brake fluid or clutch fluid as already mentioned can really do a number.
08-07-07, 01:38
mikebai1990 is offline
Brake fluid and coolant are two corrosive fluids that I know of.
08-07-07, 07:45
Damn Dirty Ape is offline
Hyrdraulic oil from the cylinders that raise/lower the car ramps on those rolling parking lots?
