07-01-07, 08:13
#13 (permalink)
| | []D[][]\/[][]D
truzoom is offline
Join Date: Mar 2005 Posts: 1,643 | Re: Freak Neighbor Quote: | I would go down to the courthouse and see if there is a property map of your place. Get your own survey done if it's not too expensive if you question his results. Could he be thinking of liability issues for you cutting the lawn? Most people would not care or welcome it as it was before. |
Good point to add.
Anyone remember the episode of the Jetsons where Spacely and Cogswell argue over whether a building is 6" across the property line?
Maybe you'll get lucky Pat and you'll have the upper hand in the situation.  | |
07-02-07, 04:28
#14 (permalink)
| | Senior Moderator
Pats300zx is offline
Join Date: Dec 2001 Location: West Chester, Pa. Posts: 6,260 | Re: Freak Neighbor I have a copy of my deed and the layout from the builder. I really need to go out and measure and compare to the measurements that the surveyor did. I doubt they are incorrect. He apparently pulled the deeds from the courthouse and used GPS software to map it. I can't believe the guy spent all this money to have it done.
I guess I am just miffed that the guy is such an idiot to not let me cut the grass in the rectangle and block off my property. Its only like a few feet and only makes both properties look good.
With the way this guy is I can see him ramping this up and getting lawyers and taking it to court. Its just causing unwanted stress and tension in my home.
I mean who videotapes someone cutting their lawn for 45 mins
Its not a duplex that I live in. Its a townhome and I have a end unit. We are grouped in six units per set. This clown is in the next grouping on my left. | |
07-02-07, 05:45
#15 (permalink)
Danase is offline
Join Date: Jan 2006 Location: Michigan Posts: 2,946 | Re: Freak Neighbor This guy sounds crazy. I think I would keep a hand gun on my side when this nut is around and I am outside working.
07-02-07, 06:28
#16 (permalink)
| | Enjoying it
keesue is offline
Join Date: Nov 2006 Location: SF Bay Area Posts: 119 | Re: Freak Neighbor It sounds like he is trying to get you to move and has someone he wants to move into your place. Its a fairly common technique to low-level harass someone. If you accept this theory, you are now one up on him. Given that he has delineated the property line, plant scrubs along the line and enjoy your home.
Learning from the Pros
07-02-07, 06:46
#17 (permalink)
Danase is offline
Join Date: Jan 2006 Location: Michigan Posts: 2,946 | Re: Freak Neighbor You should have your survey markers in the ground still from when the place was built. They should be located at all of the property corners and will be down anywhere from 1"-6". Dig around the corners a bit and you will find them. They are just metal rods.
07-02-07, 07:38
#18 (permalink)
BlueLibby04 is offline
Join Date: Jul 2006 Location: Eastern Ky Posts: 1,031 | Re: Freak Neighbor haha, I would bet that digging isnt a good idea at the moment. Cross one of those stakes and he will be up your rear with that camera. | |
07-02-07, 07:45
#19 (permalink)
Danase is offline
Join Date: Jan 2006 Location: Michigan Posts: 2,946 | Re: Freak Neighbor Quote: |
Originally Posted by BlueLibby04 haha, I would bet that digging isnt a good idea at the moment. Cross one of those stakes and he will be up your rear with that camera. | It's really the only way and a surveyer is going to have to do it as well, if he is a sober and real surveyer.  Do it when he is at work one day or something. Keep the grass together and put it back when you are done. I do this all of the time at my day job.
07-02-07, 07:57
#20 (permalink)
BlueZero is offline
Join Date: Dec 2006 Location: Green Bay, WI Posts: 809 | Re: Freak Neighbor Do you know anyone with a metal detector. That would help finding the stake. I know my surveyor only charges like $20 per stake to come out with his metal detector and locate it.
Scott
2003 Black Jeep Liberty
07-02-07, 09:08
#21 (permalink)
qballjr13 is offline
Join Date: Jun 2006 Location: Shrewsbury, MA Posts: 435 | Re: Freak Neighbor As many have mentioned your best to have your own independent survey done just to verify his information. Typically a property boundary marker is a 4x4 or 6x6 concrete rectangle with a hole drilled into it to make the exact property line. So get your own surveyor and then run a nice planting bed just a couple inches off the property (on your side) and then he can always see where the line is. If I were you, the next time he got into my face I would explain to him how nice it was when the last person lived there and how everyone works together and helps each other out. I always say "kill them with kindness". Tell all your neighbors to do the same...maybe that will drive him out and you can stay were you are and live happily ever after.
I know just enough to get me in trouble!
2004 Toyota 4-Runner SEV8, Natural White
1950 Chevy Streetrod, 502hp/546lb/ft torque
07-02-07, 09:40
#22 (permalink)
| | Self Professed Knowitall
Grimm is offline
Join Date: Aug 2006 Location: Muskegon, MI Posts: 749 | Re: Freak Neighbor Sounds a little like the people that used to live where we are now. The house was basically a dump including the yard. One day in the spring after we moved in I was fertilizing the yard, and the next door neighbor told me how he offered to throw fertilizer on our lawn for nothing when the previous owners were there and they refused. | |
07-02-07, 10:15
#23 (permalink)
Yal is offline
Join Date: Sep 2006 Location: NY, Long Island Posts: 710 | Re: Freak Neighbor I live in a townhouse I have an old lady living on one side and a family on the other side. I constantly cut and prune across the property line. I also pick up stray bits of garbage and I shovel snow on the sidewalk for both. They think my wife and I are the nicest neighbors they have ever had, which kind of makes me wonder who lived here before
I'm afraid that eventually in the time we live here the old lady might not be around and some punk like the guy you describe is going to move in!  I mean I can understand if you were parking your car on his property, installing a bench or a shed on it, or chopping up a tree or two, but cutting grass, pruning?!? | |
07-02-07, 11:59
#24 (permalink)
| | Banned
WilliamHBonney is offline
Join Date: Mar 2007 Location: USA!!! Posts: 1,416 | Re: Freak Neighbor Quote: |
Originally Posted by Danase This guy sounds crazy. I think I would keep a hand gun on my side when this nut is around and I am outside working. | Heh, I already have one on my side at all times. F this guy, Im a pr!ck and would get back at him for it but you arent like me. One question though, why are you doing your yard when you live in a townhome? We live in one and thats what we pay the association fees for, they do all the yard work and landscaping. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 07:35. | | | |
