04-19-07, 08:41
mikebai1990 is offline
Silicone lubricant vs. Lithium grease
I have a bottle of white lithium grease that I've always been using to lubricate my door hinges and such. Today I saw some silicone spray lubricant and bought it for the heck of it. I understand the silicone does not attract dust/dirt, which is a big plus for the antenna of our Acura which is having trouble retracting all the way down. Other than that, what are the disadvantages and advantages of both silicone grease and white lithium grease? Which is a better choice for hinge lubrication?
04-19-07, 08:48
1981 Camaro Z28
BigJimZ28 is offline
Re: Silicone lubricant vs. Lithium grease
I also like the lithium grease for my hinges
but the silicone lube is great for your weatherstrips, cleans, protects, keeps them soft!
04-20-07, 02:40
I find that the lithium grease gets all over and is very greasy. It often deters me from detailing the door jambs and those areas because I'm worried about destroying my MF towels. From what I know, the silicone is not very greasy or wet as opposed to the lithium grease. I was thinking about using silicone instead of lithium. Do you guys think that would be a good idea?
Thanks for the advice about the weatherstripping, BigJim. I'll be applying it to the rubber seal areas around the doors and such.
04-20-07, 02:50
1981 Camaro Z28
you can try it it will prob work Ok
it it not a heavy duty lube like a grease so you might have to use it more offen
04-20-07, 07:53
BoxsterCharlie is offline
I thought silicone was bad for rubber? Or am I thinking about something else? Not to hijack the thread, but I've been looking for a replacement to BMW Gummipfledge which they don't sell anymore.
04-20-07, 08:15
EdLancer is offline
The silicone spray is great for lubing and conditioning weatherstriping foam and door locks, thats about it. Stick with white or lithium grease for door hinges and latches.
2003 Rio Red Mitsubishi Lancer
04-20-07, 09:34
jasonmac is offline
I use lithium grease for my hinges too, it's always worked well for me.
04-21-07, 09:55
Sounds good, I guess I'll continue to use white lithium grease for the door hinges and silicone for the weatherstripping.
04-27-07, 09:40
BlueLibby04 is offline
I use silicone for door hinges. Always have and always will..
