Old 08-08-06, 08:15   #1 (permalink)
Danase's Avatar
Danase is online now
Can I move a hard drive from one computer to another?
Ok, I have a second hard drive on my Dell with all of my documents on it. But, since my Dell is not working right right now can I take that drive to my Compaq and install it? Simple as plug in and go?
Thanks!
Old 08-08-06, 08:19   #2 (permalink)
Go Tigers!
TigerMike's Avatar
TigerMike is offline
Is that drive you want to move an external drive? If so, then you can certainly move it to any computer you mish.
And, yes, you can also move a second internal drive to another computer.
2003 G35 - protected & perfected with Zaino [Zaino, made for those who refuse to live in a world full of compromises]
Old 08-08-06, 08:23   #3 (permalink)
Danase's Avatar
It is an internal drive. So it should be as simplae and unplugging it from the dell and plugging it into the Compaq and wha-la?
Old 08-08-06, 08:23   #4 (permalink)
rjstaaf's Avatar
rjstaaf is offline
From the sounds of your post I am gonna assume you are talking about an internal drive and that your computer has an available bay inside. You should be able to install it in the HP. Since the drive is already likely set up as a slave you shouldn't need to change any jumber settings. You may need a new hard drive ribbon cable though that will support a second drive. Open up the computer and look at the gray ribbon cable and see if there is another connector on it that isn't being used.
Bob
1997 Honda VFR750F
Old 08-08-06, 08:26   #5 (permalink)
Go Tigers!
TigerMike's Avatar
http://compreviews.about.com/od/tuto...s/DIYSecHD.htm
Old 08-08-06, 09:14   #6 (permalink)
ifoam is offline
yeah, the only thing you have to worry about is the jumper settings
most hd are already set to CS (cable select) but if it's not, set it as cable select. a label somewhere on the hard drive shoud let you know the settings. you can take out the jumper with tweezers
this is the jumper section on the back of the hard drive
Old 08-08-06, 10:09   #7 (permalink)
I admit I have a problem
marko's Avatar
marko is offline
the jumper recommendation is absolutely correct. all hd manufacturers have available resources on their web sites, so just look up your particular model to determine the correct jumper placement to set as a slave. the only catch I can think of at the moment is that certain operating systems can't handle large hard drives, but unless you're running win95 you should be in good shape.
It's a healthy addiction. I can stop any time I want. No really.
Old 08-08-06, 10:37   #8 (permalink)
Mobile Detailing
Five Star is offline
don't forget, if your running Win Xp home edition, You may need to reactivate windows due to the massive hardware changes.
Old 08-10-06, 01:12   #9 (permalink)
adept is offline
Contact: Send a message via AIM to adept
Are you guys forgetting that It wont work due to windows having set up all the hardware configuration and such? The harddrive will work as a secondary drive but if you are using it as the primary one then it will not run.
- Aaron M
Old 08-10-06, 01:15   #10 (permalink)
Danase's Avatar
I am using it as a secondary. And it worked. I am not on a slow Compaq!
