07-25-06, 12:34
-Tyler-
BlackSunshine is offline
Looking for simple 2 channel home stereo receiver
I have two Monitor Audio RS-8s as my main speakers and I just love them to death. They are simple, yet elegant, and have just the sound I was looking for (lots of bass even for their small size). I am running them with a simple Yamaha receiver I bought from a retail store 5 or 6 years ago. I don't feel like it is doing them justice. There is a lot of "hiss" from this receiver, and I don't really need all the extra doodads it has in terms of sound stages and surround sound capabilities. I use these speakers (and my SVS sub) for 2 channel music only, and I would like a dedicated amp or receiver for this purpose. I don't have any experience in any of the higher quality brands so I'm looking for recommendations. I'm not looking to spend over about $500 but if spending more will get me way better sound, I'm open to suggestions. I have to have a jack for the sub, and I'm bi-wiring my speakers currently with my Yamaha receiver. Those are really the only options I have to have.
http://www.monitoraudio.com/products...series/rs8.htm
Those are the speakers I have.
http://www.svsound.com/products-sub-box-10nsd.cfm
and this is my sub. It's nothing fancy, but it's just fine for 2 channel music.
Monitor recommends Music Fidelity amps, but I have never heard of them before. The speakers recommend 6 ohm nominal impedance, 175 watt power handling, and a sensitivity of 91 dB, which is where my Yamaha starts to struggle. I have to crank it up a good deal to get some substantial sound.
BTW, if I ever win the lottery, I'm going straight out and buying some B&W 803Ds.
2009 Pontiac G8 GT - white
2009 Yamaha Raider S - black
2010 H-D Road Glide Custom - Scarlet Red
07-25-06, 12:48
Go Tigers!
TigerMike is offline
2003 G35 - protected & perfected with Zaino [Zaino, made for those who refuse to live in a world full of compromises]
07-25-06, 12:51
-Tyler-
I'd like to get something that's 100+ watts into 6 ohms if possible, but the Denon looks to be a nice piece.
07-25-06, 01:20
Canyoneer
John Styrnol is offline
Look into some Rotel stuff.
My Home Page
00 Explorer XLT
07-25-06, 04:44
Slick61 is offline
I say go vintage & semi-exotic. Shop for an old Luxman, Revox, or Tandberg integrated amp or separates from the 80s... Or, you could pick up a classic Marantz receiver from the 70s. Depends on your budget & what you want to do with it. If you're looking for something newer (solid state) & more reliable, Adcom separates are usually a pretty safe bet.
Late 70s/early 80s were primetime for 2-channel integrated amps & receivers- tho most are solid state. Tubes would most likely really warm up the sound (depending on source), though tubes can be finicky & will cost you more.
It can be as cheap or expensive a hobby as you want! Just have fun.
07-25-06, 08:08
numa numa...
merci is offline
May I humbly suggest the NAD C720BEE. Continuous power output of 50W into 4ohms and up to 220W into 2ohms.
Resistance is futile. You will be assimilated.
07-25-06, 08:28
BoxsterCharlie is offline
I echo the suggests of NAD and Rotel. Also look at Adcom. There are a lot of good options in your price range; in fact paying more gets into diminishing returns really fast.
I'm also a wannabe B&W 803D owner! If I could just spend less money on cars...oh well!
07-25-06, 10:38
Dr. Jan Itor
ZaneO is offline
Rotel seperates would be nice but more expensive then you're looking to spend. For music only, *I* would be looking at Integra - http://www.integrahometheater.com/mo...s=Receiver&p=s
Don't know if you remember or not, but I have a pretty good source for high-end equipment.
Originally Posted by David Fermani
I don't care if Sal dropped a deuce in my package
07-25-06, 10:59
-Tyler-
Integra was one of the names I was trying to remember. If I decide to go through with this (if I can stop spending money on other toys) I will most definitely shoot you a PM regarding your source. Thanks for the reminder.
130w per channel, 6 ohm... nice. What's the DTM 5.3 go for?
At the store I bought the speakers at, they were running then with an NAD receiver. At the time I wasn't considering purchasing a new receiver so I don't remember the model name. Thanks for all the suggestions.
07-25-06, 11:26
-Tyler-
What does continuous power output mean? If a receiver is rated at x number of watts per channel, at x ohms, is that the maximum power output under ideal cirumstances? Is contiunous power the same as RMS?
The Integra receiver, for example, states Power Output** (6 ohm, 1 Khz,Ftc) 130 W/Ch. It also says something about dynamic power. The nominal impedance of my speakers is 6 ohms, so I'm assuming it would be best to run the receiver at 6 ohms, if there is a switch like on my Yamaha. The recommended RMS watts for my speakers are 40-175. I'd like to stay closer to the 175 since I do like to listen to my music loud and clean. How do I know if a receiver satisfies these requirements with all the numbers and technical terms? I just want the most power for the money, without going over what my speakers can handle.
Does a 50 watt continuous mean it will usually put out 50 watts of power, but it is capable of 130 watts under full load?
07-26-06, 12:10
Who? Me?
the other pc is offline
I’d go with Slick61 myself, there’s an awful lot of great two channel gear floating around out there and since multi channel home theater is all the rage these days the old stereo stuff is often available cheap.
Heck, I gave away the Denon integrated amp I’d been carrying around since college. The sucker was built like a battleship but I had no place to hook it up and no room to store it so I passed it along. Had a GAS Thalia Pre-amp that was just being passed around with friends and finally passed it out of my crowd. My unused gear pile is now down to one Audionics pre-amp and one Soundcraftsman 205 Wpc amp. Oh yeah, and a Parasound mini-tuner. And a subwoofer active filter from a strange little company in Culver City whose name I forgot. One of my buddies decided to unload his Carver Cube and his Magnaplaner MG-1’s a while back because they were just collecting dust and taking up space.
There’s all kinds of fun, funky and very good sounding equipment dispersed throughout the countryside. Just a quick look at ebay came up with an APT/Holman pre-amp and amp set with bids that weren’t going anywhere. Damn, I’d bid on those myself if I had room.
Then again, you’ll probably have trouble finding classic gear with a subwoofer output. That’s one of them new-fangled features that came after “aux” changed to “CD” and “phono” disappeared. Hmmm, where the hell did I put that active filter?
PC.
07-26-06, 05:30
Dr. Jan Itor
ZaneO is offline
MSRP ~$400.
