03-13-06, 01:03
| | Kayak detailer
White95Max is offline
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | SD card storage capacities I was just looking for an answer to how many images at 5.0MP I could fit on a 256MB or 512MB SD card, and came across this website. It's exactly what I needed, and maybe it can help someone else in the future. http://www.picstop.co.uk/pdf/image_count.htm
__________________ Paul...
03-13-06, 01:09
JohnnyDaJackal is offline
Join Date: Dec 2002 Posts: 1,464 | Those numbers are going to be off depending on how big you save your images. The larger the picture, the less the number of pictures you can hold and vice versa. | |
03-13-06, 01:10
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | I assumed those numbers were for maximum resolution. Am I incorrect on this assumption?
03-13-06, 01:30
Setec Astronomy is offline
Join Date: Jul 2004 Location: New Jersey Posts: 7,398 | I think Johnny is referring to the jpeg compression level that you use. The Canons at least, allow you to pick from three compression settings in addition to the picture size (MP's).
Grumpy like Ketch...
"You're darned right it does!"
03-13-06, 01:30
Join Date: Dec 2002 Posts: 1,464 | Probably, my 4MP camera with the 256 xD card on the highest settings holds around 160ish, so 130 isn't to far off. | |
03-13-06, 01:33
Originally Posted by Setec Astronomy I think Johnny is referring to the jpeg compression level that you use. The Canons at least, allow you to pick from three compression settings in addition to the picture size (MP's). | Yes I was referring to JPEG compression levels, sorry for not including that. Canon and every other digital camera I've seen has a least 2 options, most have 3 though for JPEG compression level settings. Once you start shooting in RAW or TIFF those image numbers are going to drop significantly, as there image size is way bigger then JPEGs. | |
03-13-06, 02:03
| | []D[][]\/[][]D
truzoom is offline
Join Date: Mar 2005 Posts: 1,643 | The range of colors in the pictures will also make a difference?
A picture of something at night will be mostly dark, while a picture of chameleon paint with metallic flake will have more range...
Or is that what you guys are already talking about? | |
03-13-06, 02:06
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | That's a good point.
But regardless, I was assuming that the numbers stated are how many images a camera could store at the highest possible size it can create.
It is off somewhat for my 2.1MP camera though. I can only get about 50-55 usually.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 01:58. | | | |
