drifting info
you basically take a rwd car and enter the turn sideways. so if you making a left turn, you let you rear slide out and counter steer so the you are turning the steering wheel right...im pretty sure that how you explain it... anyways its huge in japan, a famous cartoon intial d is based on it
of course taking a turn conventionally is faster and saves tires, but drifting is cool, your basically sliding through turns but in a controlled manner. its def catching on in the us, the japan teams come over and put on show, and there is a gto that is pretty famous.
..to get a better idea, go to blockbuster and rent intial d...in the anime section, part 1 horrible as it is the setup , but from 2 and on they are cool.
