Old 04-24-05, 08:47   #1 (permalink)
Senior Moderator
DETAILKING's Avatar
DETAILKING is offline
Computer problem----->
Whenever my computer's screen saver kicks in and then I come back to the machine, it seems to lose internet connection over that time span, which I notice because AIM and yahoo messanger auto restart. I'm not sure why this started happening all of a sudden. Any suggestions?
Old 04-25-05, 12:34   #2 (permalink)
Pursuing Wheel Cleaners
dcswd's Avatar
dcswd is offline
dcswd is on a distinguished road
What internet connection are you using? Dial-up? Cable? DSL?
Kind of a way around it... but maybe you would want to disable your screensaver. Just set your computer to turn off the monitor after a certain number of minutes. That doesnt take any cpu power while the screensaver will (although small... but this matters for some computers)
Old 04-25-05, 05:23   #3 (permalink)
Autopia Master Trooper
PrinzII's Avatar
PrinzII is offline
PrinzII is on a distinguished road
Send a message via ICQ to PrinzII Send a message via AIM to PrinzII Send a message via Yahoo to PrinzII
DK: What are the power settings on your computer? You might want to modify those via the Control Panel.
Shift_Cactus!
Old 04-25-05, 08:23   #4 (permalink)
Senior Moderator
DETAILKING's Avatar
Power settings have not been changed. I never let the machine go to sleep or hibernate, turn off hard drive or anything. Screen saver kicks in after 10 mins and the monitor turns off after an hour. Seems like after about 30 mins or so the connection is lost and as SOON as I touch a key and the desktop is restored the connection is restored....WIERD.
Old 04-25-05, 08:46   #5 (permalink)
Spilchy's Avatar
Spilchy is offline
Spilchy is on a distinguished road
Is your computer hooked into a router?
If so, reboot your router. It may need to be refreshed.
If you do have a router DEFINATELY check to see if there is a firmware update for it.
That should fix it. I'd also reboot your modem and computer after you install the firmware.
If you don't have a router, I'd contact your Internet provider and let them know. Maybe your modem needs to be updated.
Are you running a firewall software program? If so, it may be interfering and you have to change some settings. Try disabeling the software program, allow your screensaver to kick in, wait a bit and then try to hit the Internet. If you CAN, after it has been disabled, then you have your problem.
If that is the probelm, still do you firmware updates and run all your Windows Updates while you're at it. Now is a good time to clean out your spyware with a program like AdAware from LavaSoft. Reboot everything. Give your machine a tune up!
Old 04-25-05, 08:56   #6 (permalink)
rjstaaf's Avatar
rjstaaf is offline
rjstaaf is on a distinguished road
I would do as Spilchy suggests, disable your screensaver and see if it still drops your internet connection after sitting idle for the same amount of time.
Has anything changed recently on the machine, updates to the OS, new software, etc?
Bob
1997 Honda VFR750F
Old 04-25-05, 09:05   #7 (permalink)
Shoot me I'm not dead yet
Autoeng is offline
Autoeng is on a distinguished road
If it does drop only after going to the screen saver you need to pull the case off, reseat your boards and wire connections and clean out the dust. Just did mine this weekend as it wouldn't wake up after going to screen saver. Solved the problem.
Autoeng
Old 04-25-05, 09:38   #8 (permalink)
Senior Moderator
DETAILKING's Avatar
Yeah it happens when the screen saver goes on and the monitor shuts down.....not AS SOON as that happens but some time into it....less than 1 hour. If I disable the screen saver and monitor shutoff, the machine stays connected online when idle even 2-3 hours.
I will disable my firewall and see if that helps. I have no router and cable going through my USB ports, so maybe the USB's are disabled. I'll try hooking it into my network port too and see if that helps.
THANKS GUYS
Old 04-25-05, 06:37   #9 (permalink)
perry's Avatar
perry is offline
perry is on a distinguished road
Send a message via AIM to perry
That sounds right. The USB ports are being put in to power save mode and causing the disconnect. Normal network connection is better than USB anyways, so give that a whirl.
If you go in to the device manager and look at the properties for the USB root hub, one of the tabs should be "Power Management" and you can uncheck the box that allows the computer to manage the power to the USB ports. You'll have a couple of those root hubs, so uncheck the box on each. Not using Windows right now so I'm not sure of the exact wording, but it should be fairly obvious.
