Old 06-16-09, 12:02   #1 (permalink)
To Shine and Protect
salty's Avatar
salty is offline
Acceleration Explained
This was sent to me as an email, not sure on the total truth to it all, but interesting any way.
>> Even if you're not a motor head, this is impressive.
>> Acceleration explained.
>> * One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge
>> (actually Keith Black, etc) Hemi engine makes more horsepower (8,000 HP)
>> than the first 4 rows at NASCAR's Daytona 500.
>> * Under full throttle, a dragster engine will consume 11.2 gallons of
>> nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at
>> the same rate but with 25% less energy being produced.
>> * A stock Dodge Hemi V8 engine cannot produce enough power to merely
>> drive the dragster's supercharger.
>> * With 3000 CFM of air being rammed in by the supercharger on overdrive,
>> the fuel mixture is compressed into a near-solid form before ignition.
>> Cylinders run on the verge of hydraulic lockup at full throttle.
>> * At the stoichio metric 1.7:1 air/fuel mixture for nitro methane the
>> flame front temperature measures 7050 degrees F.
>> * Nitro methane burns yellow. The spectacular white flame seen above the
>> stacks at night is raw burning hydrogen, dissociated from atmospheric
>> water vapor by the searing exhaust gases.
>> * Dual magnetos supply 44 amps to each spark plug. Which is typically the
>> output of an electric arc welder in each cylinder.
>> * Spark plug electrodes are totally consumed during a pass. After 1/2 way
>> thru the run, the engine is 'dieseling' from compression and the glow of
>> the exhaust valves at 1400 degrees F. The engine can only be shut down
>> by cutting the fuel flow.
>> * If spark momentarily fails early in the run, unburned nitro builds up
>> in the affected cylinders and then explodes with enough sufficient force
>> to blow the cylinder heads off the block in pieces or split the block in
>> half !!
>> * Dragsters reach over 300 MPH +... before you have completed reading
>> this sentence.
>> * In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate
>> an average of over 4 G's. In order to reach 200 MPH well before reaching
>> half-track, at launch the acceleration approaches 8 G's.
>> * Top Fuel engines turn approximately 540 revolutions from light to
>> light!
>> * Including the burnout, the engine must only survive 900 revolutions
>> under load.
>> * The redline is actually quite high at 9500 RPM.
>> * THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew
>> is working for free, & NOTHING BLOWS UP, each run will cost an estimated
>> $1,000 per second.
>> 0 to 100 MPH in .8 seconds (the first 60 feet of t he run)
>> 0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
>> 6 g-forces at the starting line (nothing accelerates faster on land)
>> 6 negative g-forces upon deployment of twin 'chutes at 300 MPH
>> An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle
>> on earth . . quicker than a jet fighter plane . . . quicker than the
>> space shuttle....or snapping your fingers!!
>> The current Top Fuel dragster elapsed time record is 4.420 seconds for
>> the quarter-mile (2004, Doug Kalitta). The top speed record is 337.58
>> MPH as measured over the last 66' of the run (2005, Tony Schumacher).
>> Let's now put this all into perspective:
>> Imagine this...........You are driving a new $140,000 Lingenfelter
>> twin-turbo powered Corvette Z-06. Over a mile up the road, a Top Fuel
>> dragster is staged & ready to 'launch' down a quarter-mile s trip as you
>> pass. You have the advantage of a flying start. You run the 'Vette hard,
>> on up through the gears and blast across the starting line & pass the
>> dragster at an honest 200 MPH.... The 'tree' goes green for both of you
>> at that exact moment.
>> The dragster departs & starts after you. You keep your foot buried hard
>> to the floor, and suddenly you hear an incredibly brutally screaming
>> whine that seares and pummels your eardrums & within a mere 3 seconds the
>> dragster effortlessly catches & passes you. He beats you to the finish
>> line, a quarter-mile away from where you just passed him. Think about
>> it - from a standing start, the dragster had spotted you 200 MPH.....and
>> it not only caught, but nearly blasted you off the planet when he passed
>> you within a mere 1320 foot long race !!!!
>> That, my friends.....is acceleration.
Mark
deluxedetailing
Old 06-16-09, 04:44   #2 (permalink)
The Business of Details
reparebrise's Avatar
reparebrise is offline
Re: Acceleration Explained
WOW great perspective
At Your Service
Yvan
Old 06-16-09, 06:42   #3 (permalink)
Bright Dynamics Owner
Jakerooni's Avatar
Jakerooni is offline
Maybe it's just me but that right there goes to show what a massive waste of time effort and most of all money Top fuel dragsters are. So many better things I could do with 4 grand in 4 seconds. ehh... Probably just me though.
Old 06-16-09, 07:09   #4 (permalink)
Mahi Killer
Brandon1's Avatar
Brandon1 is offline
Contact: Send a message via AIM to Brandon1
Most of that is true. I have a friend that races top fuel nitro boats, and that Keith Black Hemi is an amazing sight!
Showroom Shine Details
Premium Automotive/Marine Detailing
Suggestions of a sporty ride at or less than $53K??? ExplorerXLT95 Car & Driver 140 09-30-03 06:38
