| Re: Restoring links and bookmarks in MS Internet Explorer How are you copying if your old machine is dead? Do you have the HDD in an enclosure? If you can read the drive, you should be able to pull that file no problem. It almost sounds like are copying the desktop shortcuts rather than the actual favorites file. It should be under C:users/user name/Favorites.
Grumpy like Ketch...
"You're darned right it does!"
