Old 12-14-07, 02:20   #1 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
John Deere Oil question
Hi-
I figured I would post this here since everyone here seems to be an expert on something.
I have a John Deere L120, yes the HD model and that is not heavy duty. It kind of came with the house, not my choice. Anyway. I have been using it this winter with a snow thrower attachment. I left it outside for about 5 hours today and the temp is in the 20's. I started it up to move it in the garage, it ran for about 5 min. I figured I'd check the oil and this it what I saw, white foam on the dipstick. Any thoughts?
Thanks,
Steve
john-deere-oil-question-deere-dip-stickjpg.jpg  john-deere-oil-question-deere.jpg
Old 12-14-07, 02:34   #2 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
Re: John Deere Oil question
that would be water ( or some other liquid)
that got mixed in with the oil
Old 12-14-07, 03:07   #3 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
Ok, first question. Is it really bad? Second, how did it get in there? Should I just change the oil. It is stored in side all year. Maybe I did not run it long enough to get it hot enough to evaporate the water?
Old 12-14-07, 04:11   #4 (permalink)
jshillin's Avatar
jshillin is offline
Contact: Send a message via AIM to jshillin
Change the oil...
Old 12-14-07, 04:15   #5 (permalink)
Late bloomer
Bunky's Avatar
Bunky is offline
Contact: Send a message via AIM to Bunky Send a message via Yahoo to Bunky
Foam is bad....change the oil.
Al
Old 12-14-07, 04:26   #6 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
What about an oil additive? Do I have to change the filter as well? I will do a full change in the spring. There is a good amount of clear oil at the end of the dipstick. The foam is mostly in the dipstick tube.
Old 12-14-07, 07:35   #7 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
I don't think there is a filter(but I could be wrong it has happened before)
just warm it up then pull the plug and let it drain for a little longer then normal
you might need to do it a few times but it is easy and does not take much oil
do it now water is bad in the wrong place
Old 12-14-07, 07:43   #8 (permalink)
jshillin's Avatar
jshillin is offline
There should be a filter, there's one on my dad's john deere. Just change the oil & filter & be done with it. Doesn't cost much and it is much cheaper than having that little engine rebuilt!!
Old 12-15-07, 06:06   #9 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
Thanks for the help. Will do it today. Do you think it could have been caused by water in the gas? I suspect no, but did put a very small amount of gas from my boat in it last week.
Steve
Old 12-15-07, 06:28   #10 (permalink)
Late bloomer
Bunky's Avatar
Bunky is offline
You should change the oil and filter on at least on a season basis. I think they spec the oil changes by number of hours of operation. The cause of foam in an air cooled engine is used oil contaminated by condensing water over time.
Al
Old 12-15-07, 09:17   #11 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
Thanks, I don't put many hours on it, maybe 40 per year. I changed the oil this morning with 5-30 which was recommended by the Deere dealer near by.
I'll keep a close eye on it. I hose it down in the summer and I wonder if water gets in somehow.
Steve
Old 12-15-07, 02:12   #12 (permalink)
Late bloomer
Bunky's Avatar
Bunky is offline
When you drained it, was it foamy? I think you thought most was in the dipstick tube?
Al
