Go Back   Autopia.org > THE CLUB HOUSE > SPONSOR FORUMS > High Definition Car Care
Old 10-28-09, 11:30   #145 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
Re: POWER Waterless Auto Washer... On The Cheap
DC motors are more forgiving than AC. Plus, most automotive systems run on a DC volt range from 12 to 18 volts. My Ford Bronco alternator charges at 16+ volts.
The whole reason I recommended the 18v battery to begin with is because that's what the large Nomad system uses. It's not stepping down the power.
Autopia.org Mayor At-Large
Old 10-28-09, 02:56   #146 (permalink)
rwisejr's Avatar
rwisejr is offline
Exactly Why i used it aswell.It runs flawlessly
Ron
Makita,Metabo,Flex3403,603VV Rotary's,Flex3401,UDM,PC,PC7424XP,Aztec HotRod,Camspray 1500A PW,CamSpray Foam Cannon
Old 10-29-09, 07:58   #147 (permalink)
GeorgesBlazah's Avatar
GeorgesBlazah is offline
I just finally opened my Nomad today. I took a few quick looks at it and the connector that plugs into the machine looks exactly like the one that plugs into my laptop power supply. Would I be able to just use that instead of the whole inverter thing?
- George
Old 10-29-09, 08:53   #148 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
George,
The connector is not an issue... the correct power is. The machine needs 12-18v DC at 6+ AMPS to run properly.
Old 10-29-09, 12:14   #149 (permalink)
Yeah I wasnt sure if the cable would provide that, that was my main concern.
- George
Old 10-29-09, 01:02   #150 (permalink)
Just turned it on...worked for 2 sec then shut off. Now its not doing anything . Hopefully I'll get a replcement.
- George
Old 10-29-09, 02:33   #151 (permalink)
axel_ny's Avatar
axel_ny is offline
u may burn the transformer. try again with your car and see if the nomad is burn before u send it out for exchange.
nomad has a fuse 8A in the 12v plug, check that too.
Old 10-29-09, 05:33   #152 (permalink)
rwisejr's Avatar
rwisejr is offline
Do you have water in it ? If not try it with some in it .
Ron
Old 10-29-09, 06:29   #153 (permalink)
Showroom Shine's Avatar
Showroom Shine is offline
Contact: Send a message via AIM to Showroom Shine Send a message via MSN to Showroom Shine Send a message via Yahoo to Showroom Shine
Just got my replacement today. It looks a bit different than other one,more square shaped. It also has a better looking nozzle. I believe it has a little more pressure too.
Old 10-30-09, 08:35   #154 (permalink)
Tried it in the car first
Yeah its got water. I called the company I got it from and they are sending me a shipping label to send back and theyll either give me a refund or another one.
- George
Want to use my new pressure washer for my "inbetween cleanings". What soap will work? Threxx Car Detailing 3 06-28-05 10:52
Review: Prestone De-Icer Washer Fluid JM19 The Man Cave 15 02-01-05 02:45
Buying a power washer? 49er Car Detailing 5 01-29-05 09:21
NXT for cheap at Advanced Auto Parts... GoodnClean Car Detailing Product Discussion 13 02-19-04 12:04
