05-02-11, 12:20 #1
KBM- Pad Priming and Supplemental Wetting Agents
Forum Sponsor
Perhaps a more befitting title would have been, "How to rub polish into a pad and mist water onto paint, in 13,000 words or less."
Thanks to David Saunders for sending me a simple e-mail about pad priming.
What started out as a three page response turned into five, then twelve pages.
At that point, I decided to finally write most of what I wanted to about the subject.
What follows is a 5 month compilation of various written tidbits & thoughts.
Ten minutes here, thirty minutes there, and finally a wrap-up day to convert the article from a Word document to a forum-ready file.
If anybody is interested in a .pdf version of this, e-mail me and I'll fire a copy your way... it is a much easier on the eyes.
And thanks in advance to the 8-10 guys that will fight their way through the entire thing!
iamwaxman@aol.com
05-02-11, 12:21 #2
Forum Sponsor
Mr. David Saunders-
Glad to hear you got the M205 to finish out to perfection.
Your e-mail about your recent polishing experience has inspired me to write more in-depth about the subject than I first anticipated. Perhaps this article can help other paint polishing enthusiasts to better understand the benefits and drawbacks to priming a pad, using the buffing liquid as the primer. I decided to discuss the benefits of supplemental wetting agents, too. When used together, the dynamic duo of pad priming and wetting agents can deliver stunning results. But, as with most things, there are benefits and drawbacks to consider.
When writing this tutorial, had the random orbital in mind, but after reading through the content, I am confident that most of the information can easily apply to any polishing machine. This includes orbital, random orbital, forced rotation orbital, and rotary machines.
If I happen to cover some things you are already aware of through experiences of your own, deductive reasoning during your hundreds of polishing sessions, or via diligent research in your quest for knowledge, my apologies in advance. Much of the written information has been included for the benefit of much less experienced readers. I hope that at least some portion this article will benefit you, too. I appreciate the fact that someone with your talent and level of passion would ask for an opinion on the subject. With that said… happy reading!
Let's address your two specific questions.
1. Is it possible that a foam buffing pad, once saturated with buffing liquid, could deliver less cut, despite technically having more abrasive product in the foam to begin with?
In my opinion, the answer to this question is a resounding yes.
It is definitely possible and probable that pad saturation can diminish the cutting power of a pad. Saturation is akin to using too much oil in an engine. Although the engine has ample lubrication, the splash and drag on the crankshaft counterbalances and other moving parts diminishes overall performance. Down the line a bit, this article delves into the nuances of pad saturation directly.
2. Is it fair to say that in some cases, a properly primed pad cannot equal the cut of a non-primed pad?
In my opinion, the answer to question two is I suppose, albeit rarely.
Unless I am completely missing something, or cannot recall the instance when I saw this to be true… I feel pretty confident stating that for the task of cutting, a non-saturated, properly primed pad will typically and easily outperform a non-primed pad of the same type.
That being said, I am certain that there will be instances when a primed pad will outperform a non-primed pad for certain tasks, and vice versa. In fact, I recently saw Mike Stoops of Meguiar’s clear up some rather nasty hazing using a non-primed Meguiar’s W9207 7” Foam Finishing Pad. The foam pad easily outperformed the primed Meguiar’s DMF5 5.5” DA Microfiber Finishing Disc I was using. It wasn’t even close: I was a beaten man! Truthfully, this was the only time I’ve ever seen a foam pad rival the Microfiber Disc so easily.
Instead of priming the pad, Mike used only three or four dots of Meguiar’s DA Microfiber Finishing Wax to remove the hazing. After seeing the results, I was able to mimic his results by dialing back the amount of product used on the Finishing Disc. I still used a primed pad, but I minimized the amount of liquid on the pad big time- more than I usually do. We had compressed air handy, which is by far the best way to clean the pad and control the amount of buffing liquid attached to it.
Throughout the polishing session, we had seen an inordinate amount of scouring, or hazing. In this case, neither the disc nor the liquid was responsible for the damage; the abraded paint residue was! The first time I encountered this phenomenon, it was a real eye opener, and taught me the value of keeping the pad clean. It also taught me to be on the lookout for this occurrence at the onset of all future polishing sessions (a rather tough thing to judge when polishing clear-coated paints).
Luckily, we realized early on that the paint residue was responsible for the hazing. After all, soft paint is one thing, but soft and crunchy is pretty rare, especially with paint jobs that aren’t all that old. This paint was relatively new and our microfiber discs were fresh and fluffy, so the deduction was not all that hard to come by.
So, why did the two pads deliver such different results?
Some background:
The paint we were working on was a soft, single stage, black. The brand was unknown to us. Truthfully, when dealing with any aftermarket paint job, the brand isn’t all that important because the hardness of the finish will vary depending upon how accurately the painter adhered to the manufacturers mixing and drying recommendations. The amount of paint sprayed onto the car can vary from painter to painter, too, which can also affect the overall characteristics of a cured paint job.
Even if the model of car is familiar to you, the paint system can vary widely. Claude Sevigny of Meguiar’s Canada, a man that I enjoy talking with and respect immensely, recently told me of a major European automobile manufacturing plant that was using three completely different paint systems (traditional, water based, and powdercoat)! So, unless you can decipher a vehicle’s paint code and know the characteristics of each paint type beforehand, you might notice that a seemingly familiar paint type is reacting to polishing differently than before, but you won’t know why. Consequently, you might chalk up the differences to changes in your technique, pad saturation, temperature and humidity, or a number of other things.
05-02-11, 12:23 #3
Forum Sponsor
Back to the question: why did the pads perform so differently?
Pad comparison:
Both pads are designed for final polishing, and neither pad is known to cause marring when used on delicate paint surfaces. The 7” foam pad is taller and larger in diameter than the 5.5” microfiber disc, which could potentially absorb some of the machine’s orbital motion via increased cushioning action.
The diameter discrepancy between the pads was pretty substantial. In general, a larger diameter pad offers improved stability as it glides across a surface. In other words, if the machine is inadvertently tilted one way or another during polishing, the pressure shift is more gradual. Subsequently, it is easier to regain control of the pad when its diameter is larger.
In addition, during that time, the pivot point (or fulcrum) does not receive as abrupt a concentration of pressure as it would on a smaller pad, so there would potentially be less scouring of the surface at the pivot point. These observations are perhaps hypothetical, yet sensible nonetheless.
Finally, larger diameter pads feature more surface area. But then, this is where our comparison gets complicated, at least when comparing these two pads. Before we compare these two pads, let's run some numbers.
The 7” diameter foam pad features 38.48 square inches of total surface area, while the 5.5” diameter microfiber pad features only 23.76 square inches of total surface area. That’s a difference of 61.9%, in favor of the larger pad. This means that if the same pressure is applied to the same machine, the smaller pad will have a larger concentration of weight and pressure placed upon it. This can change all sorts of things, including overall backing plate rotation when using a random orbital machine.
Additionally, a larger pad of the same type can be used longer before it accumulates the same percentage of potentially damaging residue and debris. Looking at things another way, you can use a large-diameter pad longer before cleaning is needed.
So far, it seems as though a larger the pad is the best choice for final polishing duties. Yet, we haven’t taken into account how the buffing liquids we use are built and designed to interact with the pad, nor have we accounted for the fact that the DA Microfiber Disc features thousands upon thousands of fibers that are capable of holding loads of buffing compound and abraded paint residue.
In fact, if we were able to measure the surface area in contact with the paint at any given time, I believe that once its fibers had packed together due to compression, the smaller DA Microfiber Finishing Disc would offer up a huge surface area advantage. Perhaps, the difference would be a startling amount.
To be fair, we must also consider how the disc was prepared for polishing, and how well its cleanliness and fluffiness was maintained. Do you see where this is going? That’s right- we have way too many unknown variables to form a tenable conclusion. So, where does this leave us?
The short answer:
In this case, it’s quite likely that initially, the flat-faced foam pad offered up more immediately usable surface area, thus keeping the pad-to-residue ratio lower than that of the microfiber disc. Perhaps it’s also true that the pore structure of the pad was able to store the damage-inducing paint remnants away. Maybe the abrasive grains were able to attach themselves to the pad only briefly? If so, abrading action would have been short lived- much shorter than we realized.
Finally, we should at least consider the possibility that machine movements and applied pressures were more evenly dispersed across the panel, and pad face.
But then, this is all conjecture, hypothesizing, and theorizing. In short, it’s a guess. We didn’t end up having the time to discuss things, nor do any structured testing. Conceivably, it could have been Mike’s polishing abilities!
After all, as of late, the glorious Mike Stoops has become quite the paint-polishing guru.
"Perhaps it’s not that at all. Maybe he’s not that good, but instead failed to realize that the foam pad shouldn’t have worked better?"
Oh, how that Professor Von Stoops loves a good joke. Isn’t that right, Mr. Mike?
The long answer:
Somewhere amongst the following 12,000 or so words is the long answer. I’ve tried my best to be brief, but obviously it didn’t quite work out as I’d planned. Regardless, I hope you’ll stick with it and read my best attempt at writing what I know to be true.
At least it’s what I think I know.
PAD PRIMING, AND HOW IT AFFECTS POLISHING PERFORMANCE
My theory as to why pad priming works so well is based mostly in deductive reasoning and comparative analysis of polishing results. Comparisons were made using primed pads and non-primed pads, and by employing various application methods on all sorts of paint types.
It has been my experience that most times a better result is achieved by priming the pad with the buffing liquid as opposed to using a non-primed pad. Certainly this may have to do with the way I handle my polishing machines, manipulate their speed controls, time my polishing cycles, and apply pressures and angles to the machine. There are lots of other procedural issues to consider, too.
One thing is for sure- I am definitely able to see the effects that priming has on a pad by magnifying the pad using my Radio Shack Handheld Lighted Microscope (Carson Optical makes the microscopes for Radio Shack):
Illuminated Microscope - RadioShack.com
MicroMax™ | MM-100 | MM100 | Microscopes | Pocket
While I typically prime the pad and use additional product for the defect removal process, I use a different approach for final polishing. Although I still prime the pad thoroughly at the onset of the polishing session, I minimize the amount of compound applied to the pad by blowing the pad clean using compressed air prior to polishing. If I don't have air handy, I place the pad face into a microfiber towel and run the machine for 3-7 seconds, or until the pad is still moist but there's no obvious polish stuck in the pores of the pad. Then, I add small amounts of buffing liquid as needed. For delicate or hard to refine finishes, sometimes no added product is needed. Let’s discuss final polishing and prepping of the pad for final polishing after we cover some benefits and drawbacks associated with pad priming, using the buffing liquid as the primer.
05-02-11, 12:24 #4
Forum Sponsor
WHY PRIME A FOAM PAD IN THE FIRST PLACE?
Many polishing enthusiasts believe that pad priming will eventually happen on its own through the reapplication of product after several polishing passes, and I suppose it might. But then, the word prime denotes the word preparation in this case, so it should not be left to happen consequently or by chance. Besides, I much prefer to prepare the pad using fresh, non-contaminated buffing liquid.
Pads that feature strands of material such as wool, microfiber, or micro fingers require manual priming in order to ensure a thorough coating of the individual fibers. Since there is no way to know which way the strands are going to bend, twist, or lay in relation to the surface (or each other), it is best to manually prime them prior to use.
That being said and unless otherwise noted, this discussion relates to foam pads. Don’t misunderstand- there are large sections of this article pertaining to the Meguiar’s DA Microfiber Discs as well as the Surbuf Microfingers Pad, but your questions were in reference to foam pads, so the primary focus is on them. Some close-up shots of the various pads discussed in this article:
A Pentel P205 pencil with a 0.5mm lead was used as a pointer in the following photos.
Close-up shot of a Meguiar’s W8207 Soft Buff Yellow Foam Polishing Pad
Close-up shot of the Meguiar’s DMF5 DA Microfiber Finishing Disc
Close-up shot of the Surbuf R Series 00055R Microfingers Pad
Close-up shot of the Meguiar’s W4003 Easy Buff Knitted Wool Pad
There are all sorts of foam pads available to choose from, and selecting one can be a hit-and-miss proposition. For this discussion, let's focus on the structure of a foam pad.
The pad face is the flat portion of the pad that is set upon the paint (no surprise there). Foam pads feature thousands of air pockets or pores. Between each pore resides the actual foam material. For the remainder of this discussion, we shall refer to the areas of foam as the walls of the pad. Finally, the portion of each wall that touches the paint surface when the pad is placed upon it is referred to as the wall-top. If we could somehow measure the surface area of each wall-top and add it together to determine the total area, we would know exactly the net surface area of foam along the face of the pad.
Manufacturers could possibly use this number to give us an indication of the abilities of their pad. But then, this figure would only be a starting point, because once the pad is put to use, everything changes. As the pad is shuttled across the paint, its walls shift and bend, constantly changing shape along the way. As an example, if the pad is compressed, the walls are going to either:
1. Lay over on their sides.
2. Scrunch and fill the void area of the pores.
3. Move vertically into the pad, keeping the void area of the foam somewhat intact.
What likely occurs most of the time is a combination of all three.
Depending upon what happens affects the net surface area of foam in contact with the paint. No big news there.
The amount of foam in contact with the paint at any given time is dynamic, and when we add a shot of buffing liquid into the equation, it’s virtually impossible to know whether the foam is contacting the paint surface, or simply moving polishing liquid across it. It gets more complicated as we continue!
In relation to the overall size of the pores, the walls can be thick or thin. Keep in mind that although pad manufacturers typically list a pores per inch rating (or PPI) of the foam used to make the pad, this rating by itself is not an accurate indicator of what should be expected in terms of cutting power from the pad.
Theoretically, two seemingly identical pads can feature the same PPI rating yet deliver much different performance. Even if the foam type and physical characteristics are identical by comparison, one pad might feature large pores and thin walls, while the other can feature small pores and thick walls. The following diagram illustrates this point:
Cross section of two foam pads featuring 100 pores per inch (100 PPI)
The pores dispersed throughout the blue pad are half the size of those dispersed throughout
the yellow pad. Consequently, each pad's wall thickness varies proportionately.
I hope you don’t mind if I stray even further from the pad priming for final polishing topic. It won't be much longer- I just think its important to preface that discussion with some facts that you probably already know, but may have not pondered.
05-02-11, 12:25 #5
Forum Sponsor
PRIMING CAN DETER SATURATION OF A FOAM PAD
Pad priming, using an abrasive buffing polish to treat the pad, slows the absorption of the liquid components of the buffing polish into the membrane-like structure of the pad (as it is repetitively added during the polishing process).
As you know, buffing compounds and polishes use all sorts of hard materials to abrade paint (aluminum oxide is just one example). By stuffing the pores of the pad full of buffing polish, we've created a hard barrier. This is akin to damming a river using rocks and debris to slow or stop the movement of water. In our case, however, the hard barrier keeps the liquid portion of the buffing compound or polish from traveling throughout the foam pad with little resistance. What is the net result? Pad saturation is kept to a minimum! Why is this desirable?
To put it simply, pad saturation is a performance killer. While keeping the face of the pad moist, supple, and coated with buffing liquid can be beneficial, saturating other areas of the pad with buffing liquid almost always diminishes its performance. After all, if the majority of the pad is loaded with liquid and debris instead of air, the foam cannot respond or rebound quickly because these products do not easily compress, and are much heavier than air. The avoidance of pad saturation also keeps mass out of the center of the pad, so the pad can respond in an agile manner.
What are some other benefits to avoiding pad saturation?
The pad will operate at a lower temperature if air can travel through it. With liquid and hard material stuck in the membrane-like structure of the pad, airflow decreases, so heat cannot readily escape, causing the pad to run hotter. Higher operating temperatures can alter a pad's performance and dramatically shorten its life.
The pad can be used longer during the polishing session before it needs replacing. If we can avoid all of the aforementioned negative situations from occurring, there is no need to change the pad as frequently.
Pad longevity may be increased because there is not as much solvent, oil, paint residue, or abrasive material stuck inside the pad. All of this foreign matter can degrade the structure of a pad over the long haul, either by mechanical agitation or through the absorption of volatile liquids.
If the goal is defect removal, pad priming offers many benefits.
Pad priming increases the useable surface area of a pad. Filling the pad pores with hard particles and liquid allows additional polishing liquid to set upon those areas, effectively increasing the surface area of the pad.
Pad priming mass-loads the face of a pad. By keeping the polishing liquid located on or around the face of the pad, the only additional weight added to the pad is focused where it should be, not throughout the pad. Keeping the pad free of saturation allows it to compress and rebound as it was intended. In most instances, the additional weight along the face of the pad would be considered a plus. There's not a lot of weight difference, but there is a difference.
Pad priming stiffens the face of a pad. For defect removal, this can be a huge asset because it accomplishes so much. Consequently, this is a big section to read.
Imagine that we are able to visually magnify a single point of a paint surface, and at this point, there are several crisscrossing, sharp-edged canyons. They appear to be formed by rivers, but in actuality, they're simply scratches in the paint! Some of canyon-like scratches aren't too deep, and grinding the protruding paint residing between those scratches will be rather easy to accomplish. Removal of the paint protrusions leaves a smooth paint surface.
The remaining canyon-like scratches are very deep. Rather than eliminate the paint residing between these scratches, you decide to smooth away the uppermost edges of the scratches via repetitive polishing. The smoothing effect will improve the reflectivity of the surface, and the scratch will be less noticeable. Besides, the abrasive action of the polishing compound and pad will remove some of the finer scratching that is present along the canyon-like walls, if the polish or pad comes into contact with them.
As the foam walls of the pad shuttle polishing liquid across the paint surface using a squeegee-like action, some of the scratch-edge is scrubbed away. Inevitably, there will be loose abrasive particles rolling across the paint surface as the walls of the pad sweep them along. In addition, there's undoubtedly going to be an abundance of abrasive particles physically attached to the foam walls (and the top edge of the walls), and those particles will be moving at the same rate of speed as the foam. A-ha! This is likely where we will realize maximum cutting power. However, if the wall flexes and bends as it contacts the scratch, what happens to our cutting power?
Recall that we previously discussed the membrane-like structure of a foam pad, and how it might deform its shape under pressure. A recap of the statement:
If the pad is compressed, the walls are going to either:
intact.
If the pores and walls are coated with abrasive polishing grains, then polishing performance should be pretty good. However, if there is an absence of abrasive grains, then the abrasive action of the foam must be relied upon to scrub paint away. The probability that any foam buffing pad would feature the same amount of cutting power of any cutting compound is pretty small. Therefore, we could reasonably conclude that there would be a decrease in defect removal capability. This statement could also apply to polishing pads and liquids, and finishing pads and liquids.
What happens if we fill the pores with buffing liquid? Instead of the pad walls readily deflecting their shape (consequentially changing the shape of each affected pore in the process), wall shape should remain mostly intact, especially if the pad is moving at a high rate of speed. There's a lot to discuss in regards to that statement, but in my opinion, the laws of physics would support the premise.
With buffing liquid now supporting the pad walls, would they still deflect or change shape as they contacted the edge of the canyon-like scratch? It's highly likely that the answer is yes, but not nearly as much as they would without the added support. Essentially, by priming the face of the pad, we've made the pad face stiffer to some degree.
This may or may not be a desirable effect, but it comes in handy if you find yourself working on a complex-shaped panel. Whereas we would normally reach for a typically dense or firm foam cutting pad to remove harsh defects, pad priming and its stiffening effects could allow you to use a rather pliable polishing pad in place of a firm or hard-to-compress cutting pad.
As long as the pad you choose can squeegee the paint surface clean during polishing, the pad will perform impressively. However, if the abrasive particles stick to the paint surface and the mechanical action of the pad cannot budge the abrasive residue, the surface may become coated with abrasive particles or gummy residue (a mixture of spent polishing liquid and abraded paint).
05-02-11, 12:26 #6
Forum Sponsor
PAD PRIMING, AND HOW IT RELATES TO DEFECT REMOVAL
When the goal is defect removal, pad priming can do wonders. Some of the benefits are seemingly small, but as their benefits accumulate, the difference is quite substantial. In a way, it’s a lot like the tuning of an engine or the balancing of a rotating device; infinitesimal adjustments, when combined, make all the difference! This diagram shows how pad priming and added downward pressure might cause the abrasive grains in the buffing liquid to interact with the pad:
Non-primed pad, lightly applied polish
Non-primed pad, moderately applied polish
Primed pad
Compressed and primed pad
Compressed and primed pad, abrasive minimized
A quick recap of the benefits of pad priming:
When we pack the pores tight with compound, to a large degree we’ve filled in the void areas across the face of the pad. This effectively creates more surface area on which to place a layer of buffing compound. As a result, we realize faster cutting of the surface. Since the pad pores have been packed with hard particles, the fluid portion of the buffing compound cannot easily travel upward through the pad, so saturation has been hindered. This “damming effect” also helps to keep the fluid-to-particle ratio of the buffing liquid close to optimal, or at least close to what the manufacturer intended it to be. We’ve also stiffened the face of the pad (so machine motion transfers much better), and mass-loaded it too, so momentum and force increase compared to a non-primed pad. So far, so good!
To better visualize these benefits, imagine that we've built a structure to resemble a BIG foam pad. The walls are not made of foam, but are instead made of heavy yet flexible cardboard tubes. Instead of buffing liquid, we're using uncured fresh cement.
To simulate pad priming, we fill the tubes with the uncured cement, and seal the ends with massive flat saltshaker tops. Next, we strap the tubes together using a sturdy circular band around the perimeter of the grouped tubes (think hula hoop, only a lot bigger). The tightly grouped cardboard tubes now resemble a giant honeycomb-like structure. Finally, we employ a giant machine to clasp onto and shake and spin the entire circular structure, moving it in a manner similar to the motion a random orbital creates.
As the machine moves the structure, the cardboard tubes may move and flex, but they won’t collapse because the circular band binds them together. Since the tubes are filled with hard-to-compress material (water, rocks, sand, and cement), the honeycomb shaped cardboard walls flex, but remain intact. The saltshaker tops allow some cement to escape as the unit is moved. Some splashes out the top, and even more falls out the bottom, sprinkling material on the ground as it moves.
We've just created a situation that is similar to what happens when we prime a buffing pad, and use it to polish paint. The cardboard walls and outer hoop mimic the action of a foam pad, storing polish and moving it about. The saltshaker tops allow liquid and abrasive grains to travel out of the tubes, much like what occurs as the buffing pad oscillates and rotates. Some of the polish travels upward and sideways through the pad, while most of the polish falls out of the pad as it wiggles and shakes across the paint surface.
Once again I am getting off track. You asked about pad priming in regards to final polishing.
05-02-11, 12:27 #7
Forum Sponsor
PAD PRIMING, AND HOW IT RELATES TO FINAL POLISHING
Some of the benefits attributed to pad priming become liabilities during the final polishing process. Although a thorough priming of the pad is still helpful, excessive amounts of polish should be removed prior to buffing. Before we explore the reasons why it is important to minimize the amount of polish covering the pad, it might be a good idea to review the priming procedure as described at the very beginning of this article. If it’s all still fresh in your mind, then read on!
WHY PRIME THE PAD AND THEN IMMEDIATELY REMOVE THE POLISH?
It certainly seems wasteful to prime the pad using a generous amount of polishing liquid, only to immediately remove the majority of it. As previously mentioned, the word prime denotes the word preparation in this case, so it should not be left to happen consequently, or by chance. Priming the pad increases the likelihood that if any portion of the pad contacts the paint surface, there will be abrasive particles attached to that area of the pad.
Although priming is important, it is imperative that coverage of the pad be consistent. After all, we wouldn’t want some areas of the pad face to have little or no particle coverage, with other areas featuring clumps of abrasives. Besides- as grippy and tiny as some of these abrasive grains are nowadays, there is a high probability that they would fail to disperse in an even and timely manner.
To better understand how inconsistent pad priming can lead to poor polishing results, imagine that we are creating a sheet of ultra-fine finishing sandpaper to sand a freshly painted panel. To guarantee a consistent sanding result, the paper must have consistently-sized particles that are placed equidistant from each other.
As luck would have it, we've located some pyramid-shaped abrasive grains that are non-wearing (very durable), and their dimensions are exactly the same. We decide that we shall place each grain right next to each other, bases touching, and glue them to the paper. By positioning our grains in this manner, the sandpaper will cut its way through the paint surface, leaving evenly spaced and consistently shaped v-grooves atop our paint surface. Once the paper building process has been completed, we sand the surface using perfect sanding etiquette. Time to break out the polishing machines!
As we buff, we realize that something has gone terribly wrong during our sanding session. Unfortunately for us, somebody double-stacked and even triple-stacked abrasive grains on top of other grains! Due to this incompetence, our paper created some rather deep gouges in the paint. It gets worse! Our gluing efforts were less than extraordinary, so an uncountable number of grains broke loose during sanding. Would you care to guess the damaging effects of this blunder? Right- even more gouges, and an inconsistently leveled surface because the loose grains acted as casters or rollers that did not allow the paper to glide atop the paint surface.
This is not a perfect analogy for several reasons, but it does paint a picture of what can happen if our abrasives are inconsistently positioned across the pad face. Although our paint surface would not be affected to the same degree if we had clumping of our compound or an inconsistently coated pad, we would likely see at least some scouring or swirling effects across the paint surface. A soft and pliable foam pad may also eliminate the some of the negative effects of clumping by allowing the abrasive grains to move upward into the soft pad material, as opposed to being forced into the much harder paint surface.
Let’s get back on track again.
05-02-11, 12:28 #8
Forum Sponsor
Once a pad has been primed, minimizing the amount of polishing liquid present on the pad gives us more control over how the pad is going to work with the polishing abrasives. In other words, when we use polishing liquids featuring abrasive grains (or particles), and we move those particles across a paint surface using any particular foam pad, there are a few possibilities as to how they might work together.
Realistically, it is likely that any one of these possibilities occur independently for only brief moments because the interaction between the pad and polishing liquid is very dynamic, meaning that change is never-ending as the buffing cycle advances.
At some point, most of the abrasive grains will either become trapped in the pore structure of the pad, attach to the pad or paint surface, float or be flung away from the polishing area, or be pulverized to the point of becoming useless in terms of their ability to further refine the surface in a positive manner.
In the case of polishes featuring diminishing abrasives, the abrasive structures crumble apart as they are worked, and eventually reach the limit of disintegration. It is likely that not all of the structures fully diminish as we polish (for one reason or another), which is why we often see a lower degree of refinement compared to a non-diminishing abrasive of the same quality. Even if the structures do fully diminish (or disintegrate), we cannot be certain how quickly this occurs. Imagine a finishing polish that initially cuts relatively aggressively into the paint, and then diminishes very rapidly. In this case, we might not be able to refine the finish to the highest degree.
Lately, compounds and polishes featuring non-diminishing abrasives have been very successful. One of the most popular, Meguiar’s M105 Ultra-Cut Compound, uses very hard and durable abrasive grains. Still, many polishing enthusiasts believe that the compound “breaks down too quickly”. This is an understandable yet incorrect assumption. Since the particles are so small and aggressive (or sharp), they attach rather easily to the buffing pad. Although the cutting ability of the abrasive particles remains high, most of them are positioned in the pore structure of the pad, and therefore cannot easily contact the paint surface. This brings us to the possible ways that the pad interacts with an abrasive buffing polish:
- The pad will move the polishing liquid across the paint by encapsulating it within the pore structure. In this scenario, if we assume that no abrasive grains are attached to the wall-tops, we can surmise that the pad will affect the paint in a manner independent of the encapsulated polish. In other words, the pad and polish will not create a combined polishing effect. Instead, the pad would act as a squeegee of sorts, scuttling the polish across the paint surface as it moves.
Of course, the pad would also have some effect upon the paint. The extent of its effect would depend upon the abrasiveness of the pad, and the level of lubrication between it and the paint surface. If the surface were already in very good condition, the imperfections would be small in size, so very little friction would be needed to show an improvement upon the surface. Given the right circumstances, the potential for a high level refinement via burnishing might exist.
- The pad will move the polishing liquid across the paint by constantly shifting and tumbling the abrasive particles trapped between the pad and paint surface. Imagine the particles to be very small barbed ball bearings, and you’ll better envision their movements across the paint surface. As the pad moves, the wall-tops roll the particles over imperfections in the paint. If the particles happen to be small enough to enter a surface defect (such as a scratch), minute amounts of paint would be removed in the process. This would effectively alter the shape of the scratch by replacing large imperfections with smaller ones. In addition, a smoothing or burnishing of the scratch edges would make the imperfection less noticeable.
It is likely that maximum polishing or refining ability would occur during tumbling, as the individual particles could feasibly enter any scratch they could physically fit into. Some particles might roll across the paint surface, as would a tire across the pavement. In this case, the abrasives would create little more than a micro pockmark trail (if that). It seems reasonable to assume that most of the particles would roll, then drag (as they attached to the pad or were pushed), then repeat the process over and over again.
Thinking things through, it seems to me that free-rolling particles would be able to follow the nuances of a surface better than attached particles, so they would therefore refine the finish best.
- The pad will move the abrasive grains across the paint as they attach to the wall-tops. When this happens, leveling ability increases because the particles are moving in tandem with the pad, so speed of movement is at its peak. However, if there are no free-rolling abrasive grains present between the pad and paint surface (as discussed in the section immediately above), polishing results will suffer.
Therefore, when using foam pads in the manner outlined (the abrasives grains are attached to the pad face), thorough polishing of the surface requires that multiple passes be made. Oftentimes, the abrasive particles must be forced into scratches and defects via user applied downward pressure. This is especially true if the abrasive grains are of a smaller size than the overall depth of a defect.
Even the softest foam pads available to us cannot readily contour to every surface detail. Think of a tire rolling across a pebbly road for a visual of what I mean: although the tire would have an ability to contour to the overall shape of the road, (the degree would be dependent upon the tread design and characteristics of the rubber), it is very unlikely that it could precisely match every topography detail.
Note: Meguiar’s® DA Microfiber Discs and Surbuf® Microfingers Pads feature vertically placed fibers across the pad face. The fibers used on both styles of pad are very pliable, and rather unique.
The structural design of Meguiar’s Microfiber material is flexible yet crushable; each strand can bend, yet collapse in diameter and length (similar to the pile of fuzzy shag carpeting, while they’re being stepped on).
While the Surbuf’s Microfingers are also flexible, they retain their cylindrical shape and length, even under pressure (bending in a manner similar to the bristles of a toothbrush).
Both types of pad enable attached abrasive particles to enter very small nuances of the paint surface. In the case of the Meguiar’s discs, the microfiber material can accommodate a massive amount of buffing liquid, and since the fibers are so fine, its polishing ability is unmatched when used with ultrafine abrasive compounds.
05-02-11, 12:30 #9
Forum Sponsor
“HEY, I’M JUST GETTING STARTED HERE!”
Since we’re on the subject of attached abrasives, let’s discuss the misconceptions that arise when this happens across the entire face of the pad. When all of the abrasive grains have attached to the face of the pad, polishing enthusiasts tend to think that the polish has run a very short work cycle. To explain this phenomenon, phrases often bantered about include:
- “The polish broke down too quickly.”
The user thinks that the abrasives became unusable due to mechanical destruction or disintegration.
- “The lubrication evaporated too fast. It flashed off… it soaked in.”
The user thinks that the lubricating agents or liquid ingredients used in the compound have evaporated, or soaked into the pad.
Essentially, the impression is that the compound has either worn out or dried very quickly. Most times, this is not the case… so spread the word!
There are plusses and minuses to “loose” grains, “attached” grains, and a combination of the two. Hopefully, this information helps to point these out.
“THE REASON I PULLED YOU OVER TODAY, SON…”
At this stage of the polishing session, the liquids we use typically feature very fine abrasives, while the pads we outfit our machines with are chosen to gently apply the liquids in an oh-so delicate manner. It makes sense that in order to further refine the surface, paint must be removed using a gentle approach. Besides using slow and deliberate motions to control the machine, one of the best ways to achieve stellar results is to lower the machine speed.
We already know that, for the most part, higher machine speeds will remove paint more rapidly than slower machine speeds. The primary reason is obvious: an increase in repetitive scrubbing of a section of paint for a given amount of time. In addition, the faster the pad is moving, the more likely leveling ability is going to increase.
It is important to mention that leveling refers to a minimizing of height variations across the paint surface. Leveling makes a surface appear smooth, and reflections upon that surface will appear more accurate to the object being reflected. Examples? The reflection cast off of a still body of liquid, or a high quality glass mirror.
All that being said… once we’ve sufficiently removed defects or leveled the surface, there’s no real benefit to using high speed for final polishing. In fact, there are a lot of negatives associated with moving the buffing pad at a rapid clip.
05-02-11, 12:31 #10
Forum Sponsor
SLOW AND LOW IS MELLOW
There are many benefits to using a slow speed setting for the task of final polishing. Some of the most important ones are listed below:
- Slower operating speeds lessen the need to control the machine using a heavy hand, so edge digging and uneven compression of the pad is kept to a minimum.
- Pads maintain a higher level of pliability when used at lower speeds. This allows them to more accurately contour to complex shapes and the small nuances of a surface (such as orange peel). A pad that has become effectively stiffer due to an increase in speed is beneficial for the task of defect removal or surface leveling, but for final polishing it can leave scour marks, or light hazing.
- When using very soft and pliable foam pads, too much speed can cause the pad to ride atop the buffing polish rather than move it across the surface.
- Slower operating speeds curtail the generation of friction induced heat. This has all sorts of benefits. Lower operating temperatures keep paint characteristics stable, so the potential for paint swelling may be minimized. Fluids evaporate at a slower pace, so polishing liquids last longer and perform as intended. Fluids efficiently transfer heat, so polishes and pads can help to keep paint surfaces cooler during the buffing process.
- Buffing pads and backing plates can wear quickly as the adhesives warm to the point of failure.
- Foams, fibers, and attachment materials weaken or can be damaged by overly aggressive machine movements.
- Rapid evaporation of lubricants and liquids can even cause buffing cycles to be dramatically shortened.
- The smooth and curved motions made by the random orbital change to motions that are aggressive and pointed when operating speeds are increased. This can lead to less than perfect polishing results. The following pictures illustrate this point:
A Meguiar’s G110 Dual Action Polisher was outfitted with a backing plate using four modified ballpoint pens in place of
a typical buffing pad. The circle created by the rotating pens measures 4-3/8” (or 111.125mm) in diameter.
This pattern was created using the machine on speed setting 1, which equates to approximately 2,560 orbits per minute (OPM).
This pattern was created using the machine on speed setting 6, which equates to approximately 6,700 orbits per minute (OPM).
The list of reasons why using slower machine speeds can improve final polishing results goes on and on. Bottom line? If there’s no need to finish a job in a hurry to meet a deadline… and you’re not attempting to level a surface… and you’re not trying to maintain a specific amount of random pad rotation (or increase it)… then lower the machine speed setting for final polishing.
Side note: Another simple yet highly successful way to improve final polishing results is to use large diameter pads as opposed to equivalent small diameter pads. Large diameter pads provide a much more stable platform, which helps to minimize machine wobble and user-applied pressure variances across the face of the pad. In addition, larger pads feature more surface area, so they can be used longer before cleaning is needed.
05-02-11, 12:32 #11
Forum Sponsor
A CLEAN SWEEP.
Since today’s polishing technology does not allow us to eliminate abraded paint residue from the buffing liquid after each cycle, it is important to keep our pads clean. Sometimes the residue’s effects are negligible, but other times it can wreak havoc on a paint surface. In fact, this type of contamination can cause scouring so fine that it seems no pad & polish combination will deliver stellar polishing results. When this occurs, it can really shake your confidence!
This sort of thing happens any time we use one item to remove material from another. A rake that becomes clogged with leaves can no longer gather them efficiently… a file clogged with shavings can no longer remove material in an even manner (if at all). In most cases, the tool is still usable, but contamination slows or halts progress altogether. Stuck-on debris can even ruin a surface. Can you imagine the damage caused by a file that has become loaded with aluminum shavings? How about a piece of sandpaper packed with pills of freshly sanded paint?
In the case of buffing pads, once they have become clogged with abraded residue and spent abrasives, we tend to see a less than perfect finish. When using rotary machines, we see swirls in the paint surface: these are scratches that are long and curved. When using dual-action or orbital machines, we see scouring or hazing of the paint surface: this is simply caused by an accumulation of scratches that are short and curved, and layered upon each other.
Wouldn’t it be nice to know whether the residue featured sharp, hard points and edges similar to the type found on shards of glass? What if instead it was pulverized into a soft, powder-like substance? If we had this sort of information, perhaps it would help us to make choices as to the type of pad we should use and how often it should be cleaned. We might even get some insight as to which buffing liquid would work best for the situation.
On that note, I’ll leave you to ponder whether or not the solvents and other liquids designed into a buffing liquid help to dissolve the abraded paint remnants. At the minimum, they likely coat the residue and other contaminants, perhaps curtailing some of their negative effects. For now, we’ll have to rely upon common sense cleaning of our pads.
USE A RAKE TO COMB YOUR HAIR? I DON’T THINK SO!
Imagine having to remove some sort of gritty, oily, caked on goop from your hair using nothing more than a common leaf rake. For guys like me, imagining a full head of hair is merely a harsh reminder of what once was, but I digress. For the hairy-headed among us, think about how futile such an attempt might be.
Unless the rake’s teeth were able to force their way between the hairs and strip the goop away, all that would likely occur is perhaps a haphazard redo of your 'do! I think it’s pretty safe to say that most of the hair on your head would stay packed tightly together. The probability of cleaning and separating thousands of hair strands using the comparatively thick and flimsy raking teeth is undoubtedly very low.
Yet, in the midst of a polishing session, many of us attempt to clean our buffing pads using nothing more than a run of the mill, nylon bristled brush. Unless the pad is coated in dry or crusty residue, agitating the fibers or pores of a pad won’t do a whole lot of good. In fact, other than seeing some foam or fibrous pad remnants and a few crusty residue bits, I don’t recall seeing any oil or grease droppings oozing from the brush. Isn’t there a better way to clean foam, microfiber, or microfinger pads on the fly?
Back to the hair: I suppose that if we didn’t have shampoo and water handy, most of use would reach for a towel in an attempt to wipe the goop away. Perhaps we would first wipe our hair with the towel, then agitate it with a brush, and repeat both steps until we were satisfied that we had removed all we could. In fact, lots of us use this exact method for cleaning our pads when we are polishing paint using random orbital machines. First, we agitate the pad with a brush. Then, we place the face of the pad against a towel and run the machine until the pad looks pretty clean. Some guys will go one step further and mist the pad with water, then repeat the towel step (I do this while cutting, but never for finishing). Three steps later, the pad usually looks pretty darned good! Sounds like a lot of work, and it is. Luckily, there is a much better way.
The best way to clean a buffing pad in the midst of a polishing session is to blow it clean using compressed air. A high-pressure blast of air aimed directly at the pad’s face loosens stuck-on contaminants, and will have no problem separating fibers or cleaning pores with ease. Compressed air works incredibly well on wool pads, so the need to spur a pad is virtually eliminated. With air, there’s no way I’m transferring trace amounts of plastic or metal onto my pads as I clean them. One less big deal to worry about.
Most detailers and paint polishing enthusiasts don’t keep a portable air compressor in their polishing kits, so perhaps it’s not a reasonable option for most folks right now. But rest assured, as our pads become more fibrous and our compounds feature finer and more capable abrasives, you’re going to need an air compressor.
So the next time the desire hits to buy that “must have” polishing machine, consider purchasing a small air compressor instead. Once you make the switch, you may just realize that you didn’t need that new machine after all.Last edited by Kevin Brown; 05-02-11 at 08:45.
05-02-11, 12:34 #12
Forum Sponsor
“I’VE GOTTA HAND IT TO YOU…”
A good way to test the effects of paint residue is to polish a section of paint by hand. A few rubs of the paint using a high quality foam or microfiber applicator and some polish will give you an idea of what to expect from the polish itself. It's best to compare the resultant finish using different applicators to determine whether or not a particular type is affecting the paint surface. It might even be a good idea to rub the paint surface using only a clean applicator to determine its effects beforehand. If you can get a similar result using various applicators, there’s a pretty good chance that the residue will not create a lot of problems.
Once you’ve got your base, try another similarly sized section using the same polish, applicator, and pressure, but double the rub time. Obviously, you’ve got to be reasonable because as paint is removed and the polish dries out, the residue can build to the point that it engulfs the surface of the applicator. In terms of the detrimental effects caused by dried polish and abraded paint residue rubbing against the paint, expect to see a magnification of the results you've achieved by hand when using a machine.
Paints that are seemingly impossible to dial-in often respond well to soft and pliable non-marring pads, and a minimum amount of polish. Sometimes priming as specified for final polishing works well, but other times a non-primed pad and a minimal amount of polish delivers the desired result. More times than not, when using high grade, non-diminishing abrasive compounds and polishes, additional downward pressure can work surprisingly well.
Patience and methodical analysis is often the only way to form the optimum finishing method. In the end, the best advice is the obvious advice: to avoid contamination-induced swirls, scouring, and hazing… keep the pad clean!
“IF YOU CAN’T STAND THE HEATNIKS…”
When the discussion turns to heat and its positive or negative effects on paint polishing, things can become heated rather quickly! The pro-heat crowd (the Heatniks) insists that the heat generated by pad friction as it rubs against the paint is the ultimate polishing medium, never accounting for how the friction was created in the first place.
Heatniks often mention that high operating temperatures help to break down the abrasives in our compounds and polishes. This to me is interesting, considering the hard and durable composition of the abrasive grains used in buffing liquids these days. Commonly used materials include varieties of aluminum oxide, silicon carbide, diatomaceous earth, clay, and silica. While these materials vary in hardness, none of them would be terribly affected by the temperatures generated by the typical buffer, pad, and compound.
Heatniks have even been known to boast that a specific amount of heat further hardens a paint surface, effectively making the paint more durable and less susceptible to scratching. I suppose the effect is akin to the shot peening of metal parts to improve stress crack resistance. With no actual scientific data to back this up, nor any other convincing evidence that a fully cured or catalyzed paint system will further harden with the introduction of heat after the fact (or any paint type, for that matter), I have nothing positive to say about this unproven premise.
rinse with wetting agent?
By jedovaty in forum Car Detailing Product DiscussionReplies: 1Last Post: 07-26-07, 11:08 -
wetting pads
By toyota2 in forum Car DetailingReplies: 16Last Post: 11-13-04, 12:10 -
wetting pad before use
By schneider325 in forum Car DetailingReplies: 4Last Post: 07-03-04, 03:41 -
Any insurance agents in the house??
By ExplorerXLT95 in forum Car & DriverReplies: 4Last Post: 08-08-03, 03:59 -
Types of washing agents...
By Mike328i in forum Car DetailingReplies: 7Last Post: 02-11-02, 05:57
LinkBack URL
About LinkBacks
