Page 15 of 15 FirstFirst 123456789101112131415
Results 169 to 176 of 176
Like Tree9Likes
Thread: the 'little tricks you've learned' thread
  1. #169
    Re: the 'little tricks you've learned' thread
    Accumulator's Avatar
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,402
    Quote: Originally Posted by Concourswanna b View Post
    I always get the old "rinse water bucket becomes as soapy as the soap bucket" though...
    I use a big spring-clamp on my rinse buckets so I can easily keep track of which is which.
    I'm thinking of going back to using my second bucket as replacement soapwater for when the first needs changed, instead of the trad. two bucket way.
    If your rinse/"second" bucket's water gets dirty, and I suspect that most people's rinse water does, then I wouldn't try that.
    And I'm a bit here...why would your "first" bucket's water need changed? It's the shampoo mix, right?
  2. #170
    Nth Degree's Avatar
    Join Date
    Aug 2011
    Location
    RDU
    Posts
    715
    That's not a bad idea. I just use two different color buckets. Gray is rinse/dirty and white is soap/clean.
  3. #171
    Concourswanna b's Avatar
    Join Date
    Apr 2009
    Posts
    256
    I like that idea.
    I probably didn't say that very clearly... Sure, the rinse water would not be a good substitute for the wash water. I guess I meant to say "just use a one-bucket method, but have a second reserve bucket of suds ready for whenever I feel the first bucket is somehow contaminated." With this method, the mitt would be rinsed out well and often with the hose.
    Maybe I need to ring out the mitt more after rinsing when using the two-bucket way.
    Well, I do notice a higher degree of liquid loss with the lamb’s wool mitts, vs. the old days of the grout sponge. I found those to be faster, but I swear I noticed a little marring. I love the waschpudel, but I see slight, slight, slight marring with it, as well.
  4. #172
    TOGWT's Avatar
    Join Date
    Sep 2003
    Location
    Florida, USA / London, England
    Posts
    5,101
    Blog Entries
    41
    Finish Kare FK 1000P
    Use a dampened, soft applicator pad with a very light pressure and spread product thinly and evenly. Leave Finish Kare FK1000P for a few minutes (apply to 2-3 panels before removing. Spritz the paint surface with Finish Kare FK#425 and then remove with a clean applicator, this will cut down on any product dusting and finally buff surface with a clean dry towel
  5. #173
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,402
    Concourswanna B- OK, that cleared up some of my confusion. But eh, I suspect I just approach this stuff too differently...I can't imagine *ever* letting an unrinsed/soiled wash mitt/sponge/brush/etc. get into my shampoo mix lest it contaminate it. I make sure all my wash media are completely clean before they go back into that bucket, and not that due to my wash technique my wash media stay so clean that my *rinse* water is usually perfectly clean at the end of a wash (even when I do a winter-filthy vehicle).
  6. #174
    Join Date
    Dec 2011
    Location
    NC
    Posts
    241
    Images
    1
    To add one of mine:
    When you're doing a task that involves a spray bottle in one hand and a towel or something else in the other, keep your finger off the spray trigger. For some reason I involuntarily spray the bottle sometimes and it gets on things it isn't supposed to. So just hold the bottle without your finger on the trigger.
    Quote: Originally Posted by David Fermani View Post
    The better you get, the longer it will take you!!
  7. #175
    Saurabh14673's Avatar
    Join Date
    Jul 2011
    Posts
    10
    P21 S GEPC works wonders on removing hard water spots from the windscreen.
    Very effective in removing dried ONR stains. Found out the hard way when out of station and was without clay & KAIO.
  8. #176
    Nth Degree's Avatar
    Join Date
    Aug 2011
    Location
    RDU
    Posts
    715
    Quote: Originally Posted by 01GreyStangGT View Post
    Mr. Clean Magic Erasers work for getting wax or polish residue off of textured black plastic.
    Of course, taping the trim makes it not get on it at all.
    A simple pink eraser from the school supplies isle works wonders for that too.
    audio1der likes this.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
