Originally Posted by GLuXuRy
the currenty deal on AG is i believe 10% off with free shiping on orders over 95 dollars .. let me look for the link
since you and i are stuck on this thread .. i noticed your pressure and foam lance setup thread .. but did not read too much into it .. who makes it, how much and how do you like it ?
edit : AG LINK Stock Up For Spring!
The foam lance is absolute sex, when it comes to washing your car
It is an attachment when used with a pressure washer. It's like a foam gun that you attach to your regular hose, but on roids. Depending on the soap used, you can make some incredible foam (shaving cream consistency if need be). You can let this dwell on the vehicle much longer. Theory is that it helps to loosen and encapsulate some of the dirt on the paint surface so that it is rinsed away, leaving you with a potentially cleaner surface, ultimately less prone to marring the finish when washing.
PROCESS:
- power rinse vehicle (rid of any loose debris and dirt that is easily removed)
- foam entire vehicle (let dwell long enough that it can do some magic, but not to where the entire vehicle dries (no no)
- re-rinse w/ pressure washer
- proceed with 2BM or whatever you wish
