Go Back   Autopia.org > THE MAN CAVE > General Garage Discussion
Old 12-05-03, 08:34   #1 (permalink)
zilla's Avatar
zilla is offline
zilla is on a distinguished road
ghetto alternative to plating rotors?
I'm getting new rotors and pads installed on Monday. Since this was a last minute thing, there isn't time to send the rotors out to get plated.
Does anyone know of any other way to protect the rotor from rust and brake dust? Can i get some rustoleum or high temperature paint and spray the whole rotor? the first couple of brake applications should be enough to remove the paint from the area where the pads come into contact with the rotor.
opinions?
Old 12-05-03, 09:35   #2 (permalink)
MBZ 500E is offline
MBZ 500E is on a distinguished road
A good high temp paint will work for a reasonable amount of time from what others have suggested. If you do this you really should tape off the wear surface to prevent gumming up your brake pads.
Afshin
90 Porsche 928 GT - Marine Blue
04 Honda Pilot - Silver
02 Honda CRV - Silver
Old 12-05-03, 09:58   #3 (permalink)
kgb
kgb's Avatar
kgb is offline
kgb is on a distinguished road
Send a message via Yahoo to kgb
I would not put anything on my rotos at all! You will end up in the back of another car when you try to stop.
Wax and polish sniffer.
Old 12-05-03, 10:09   #4 (permalink)
Dean is offline
Dean is on a distinguished road
Please don't call my Type R rotors ghetto.
Eastwood high temp silver (brush-on) paint, If you were interested.
Dean
Old 12-05-03, 10:41   #5 (permalink)
TOGWT is offline
TOGWT is on a distinguished road
Send a message via ICQ to TOGWT
Nice wheels. Applying paint to rotors just sounds 'sortta iffy'to me.
Just a thought 'paint the calipers red' they should stand out well from your white wheels'.
Experience unshared; is knowledge wasted…/
~ justadumbarchitect ~so I question everything ~
Old 12-05-03, 10:53   #6 (permalink)
MBZ 500E is offline
Have to jump in here.
If you take a look at Dean's rotors you'll note he's only painted the surfaces which do not come in contact with the brake pad. This is very common with show cars and done frequently. As long as the paint is not applied to the wear surface you'll be fine. If you do apply paint to the wear surface it should be removed with brass brush prior to installing it.
Since plating is a metal it will wear away without causing problems with brake pads. Typical plating processes for rotors include Cadmium plating and Nickel Plating. If you go with this option you should take into account increased braking distance until the plating is worn off of the wear surface.
Good luck and let us know how it turns out.
Afshin
Old 12-05-03, 01:08   #7 (permalink)
russellp23 is offline
russellp23 is on a distinguished road
I think it looks great, I can tell the rotors are done, but from the angle it's kind of hard to tell whether the calipers are done too. Did you tape off the rotors first?
Mine is a MINI!
Old 12-05-03, 07:00   #8 (permalink)
Dean is offline
Yes, sir.
The calipers have been painted with silver Folia Tec brake caliper paint. Sorry, my Canadian-spec Type already has a screaming red interior. I'm not about to paint the calipers red
Only the rotor hats are painted. Any surface that comes in contact with the brake pads is left untouched. It's a very easy project that has so far looked good after 1 year.
Dean
Old 12-06-03, 12:41   #9 (permalink)
Cya, & take the care eh?
4DSC's Avatar
4DSC is offline
4DSC is on a distinguished road
Try searching for a thread or two by Luster who paints the whole rotors and just lets the paint rub off from the pads like you said. Not that complicated and looks good.
Brian
Old 12-06-03, 08:12   #10 (permalink)
Senior Moderator
Brad B.'s Avatar
Brad B. is offline
Brad B. is on a distinguished road
I have always painted the rotor edges and hubs. The best high heat paints will work well for street cars. The Carrera, which sees the track will burn off the paint much quicker.
For touch ups I don't even bother removing wheels, I use a 12" long artists paintbrush and go through the wheels. (Spray the paint in a cap and dab.) I just lay it on the edge of the rotor, which is the area that looks rusty, and if there is any slight bit of spillage on the shiny surface I just wipe away or it will be removed the first time I hit the brakes. It's too little paint to cause any gumming.
2005 Audi S4, 1996 Porsche Carrera C4S, 1972 BMW 2002tii, 2004 BMW M3.
Old 12-07-03, 09:32   #11 (permalink)
4DSC's Avatar
4DSC is offline
Once again that's a great pic Brad.
Do you use 1500 F paint or 900 F? I'm just curious because Plastikote actually sells a brake caliper paint, but it's only rated to 900 F while they have a different line of paint rated up to 1500 F which would sound like a better idea to me?
Brian
