I need to get some new jacks (I like to have two for tire rotations), and Kmart has some scissors-style hydraulic jacks (like the kind in your trunk, but hydraulic) that are cheaper than the floor jacks. I hate the floor jack because it won't go in the factory lift point without damaging the lower body panels, and I hate using other parts of the
undercarriage because you always run the risk of crushing something. Plus, floor jacks pull as they raise, so they either pull on the vehicle or have to roll (which means you'd better position it the right way so it can roll). A scissors-style just lifts straight up and uses the factory lift point designed for the spare-tire jack.
I just wanted to see if anyone had any feedback on them or any reasons they may not be a good idea. I always use jack stands if I'm going under (though not when I just rotate tires), but I also leave the jack on so the jackstand isn't fully loaded (again, you have to find a spot to put it that won't crush or anything) just in case someone was going to chime in with a safety tip about supporting vehicles with jacks.
Also, does anyone know a website for Rally? I found
http://www.rallymfg.com/ but it is pretty worthless.
Thanks!
