Old 06-15-08, 08:01   #97 (permalink)
swirl mark adder
.hondajake's Avatar
.hondajake is offline
.hondajake is on a distinguished road
Re: What oil do you use and why?
Originally Posted by Spali32 View Post
I use Amsoil full-synthetic oils. Use Amsoil in all my cars in the past 8 years. They were the #1 Full Synthetic oil to come out first and still going strong.
not api certified....i wonder why.
Old 06-20-08, 05:48   #98 (permalink)
Calm like a Bomb
EisenHulk's Avatar
EisenHulk is offline
EisenHulk is on a distinguished road
I just replaced the oil pan gasket on my TL and I switched over to Mobil 0W/30 synthetic.
Old 06-26-08, 12:04   #99 (permalink)
Little Bernie!
mburnickas's Avatar
mburnickas is offline
mburnickas is on a distinguished road
Because they do not NEED to be. When they change oil formulation, if you are API approved you need to re-test oil (aka cost $$$) and there ZDDP levels are higher then API allow. For me I could give too about the API specs and use Amsoil. Worked great for over 16 years on my UOA.
Signature content edited by moderators.
Old 06-26-08, 02:37   #100 (permalink)
Purewatre Dzine is offline
Purewatre Dzine is on a distinguished road
Amsoil G1 with no problems at 190k
Old 07-17-08, 02:22   #101 (permalink)
JamRWS6 is offline
JamRWS6 is on a distinguished road
Originally Posted by CleanGSR View Post
I use German Catrol 0w30 because the German Castrol is leaps and bounds ahead of the US stuff and the Mobil 1 5w30 is a thin 30weight and tends to shear back fairly quickly. My car tending to naturally burn oil in VTEC means I definately don't want an oil on the thin side.
Same here...works very well in my '02 WS6.
'02 Trans Am WS6
Old 07-17-08, 02:32   #102 (permalink)
LETS MOTOR!
Devilsown's Avatar
Devilsown is offline
Devilsown is on a distinguished road
I think Im going to start useing elf
Canfield
03 Mini Cooper S- 900 Pure Silver
97 Acura 2.2cl-G- 82P-5 Cypress Green Pearl
93 Mazda Rx-7 R1- J9 Competition Yellow Mica
Old 07-17-08, 02:54   #103 (permalink)
2002 Z06's Avatar
2002 Z06 is offline
2002 Z06 is on a distinguished road
Depends on which car.
Vette: Mobil 1 Extended performance (15,OOO mile) synthetic 10W-30
Integra GS-R: Same as above
Integra LS : Whatever autozone has on sale....general that is Valvoline 10W-30
I usually choose the heavier weight oil because of oil consumption and how I drive my vehicles.
Old 07-17-08, 04:11   #104 (permalink)
Late bloomer
Bunky's Avatar
Bunky is offline
Bunky is on a distinguished road
Send a message via AIM to Bunky Send a message via Yahoo to Bunky
I do not know anyone that has had an oil problem that was not a design problem (bad pcv system) or just lack of changing on a reasonable basis.
Al
Old 07-18-08, 07:11   #105 (permalink)
Distrbd is offline
Distrbd is on a distinguished road
AMsoil for me here.
It all started when I heard that Amsoil Manual Synchromesh Transmission Fluid 5W-30
remedied the third gear stickiness of 2006/2008 Honda Civic SI's,even though I don't own an SI model but I thought it would help with my regular DXG Civic and while I was ordering MTF I also decided to order 5 W 20 motor oil and WIX oil filter .
My manual transmission now goes through the gears like butter,the engine is good to go until the maintenance minder tells me so which is a year or 5500 miles.
Old 07-18-08, 04:22   #106 (permalink)
Bottom Feeder
wfedwar's Avatar
wfedwar is offline
wfedwar is on a distinguished road
Wear of bearings, rings, and other moving parts can be related to "oil problems". Shrinking seals and gaskets are other "oil problems". I'd venture to say that a great many engine problems could be remedied if the oil had performed perfectly. Have you ever rebuilt an engine? If you do, you'll see all these things and how the oil is so critical.
Old 07-18-08, 04:54   #107 (permalink)
2Swedes is offline
2Swedes is on a distinguished road
I use Mobil 1 5-30 Synthetic. My car sometimes sits at the airport for weeks in below freezing temps. I have found that with most oils it takes a while for the engine to start, gets real sluggish. Not with Mobil 1. My last vehicle, 1992 Explorer, I used Pennzoil with Duralube as an additive to get over the sluggishness.
Since Volvo doesn't recommend any additives, I go with Mobil 1 in the 2005 XC-70 and 2007 S80 and haven't had any problems. I have noticed that the XC-70 gets about 4 mpg better mileage with the synthetic over Castrol on those occassions I have neglected to inform the dealer I want the synthetic.
Old 07-29-08, 07:13   #108 (permalink)
burn740i is offline
burn740i is on a distinguished road
Mobil 1 0W40
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/general-garage-discussion/104747-what-oil-do-you-use-why.html
Posted By For Type Date
10w 30 vs 5w 30 oil | Topic profile | BoardReader This thread Refback 04-05-08 08:20
"5w 30 vs 10w 30 oil" - topic profile :: BoardReader This thread Refback 04-01-08 07:49
"mobil 1 ep" - topic profile :: BoardReader This thread Refback 04-01-08 11:24
syntec blend oil | Topic profile | BoardReader This thread Refback 03-30-08 09:09
