03-23-07, 11:16
| | Have PC, Am dangerous
mschuyler is offline
Join Date: Mar 2007 Location: Bainbridge Island, WA Posts: 57 | Warning on epoxy floors I have a three car garage. During the winter the floor would get wet and stay wet. (whaddya expect in Seattle?) When it dried a white powder would encrust the floor, leached from the concrete. So I decided to empty the garage entirely and paint it with floor epoxy. It comes in dual cans, each half full. Pour the catalyst from one into the other, then paint the floor. It took several days from start to finish. When I was done it looked really good.
But it didn't last. Even after following directions for cure times, etc. it didn't take long for the tires on the cars to wear into the coating and show the concrete. Pretty much anything adverse will damage the look. Now it looks terrible. I talked with one of the guys at a homeshow who does the professional floors (at least one is posted here) and he said they encounter this on a regular basis. They have to grind the epoxy away before they can put on a good finish, which adds to the cost.
So, this is just a warning. If you think the Home Depot epoxy thing is cheaper, it is, in more ways than one. Stay away.
2007 Silverado 2500 HD, 2004 Acura RL
03-23-07, 11:36
superstring is offline
Join Date: Feb 2004 Location: Victoria, BC, Canada Posts: 531 | Re: Warning on epoxy floors Thanks for the heads up, mschuyler. Sorry to hear about your experience, though. What a bummer!  | |
03-23-07, 11:42
David703 is offline
Join Date: Feb 2005 Location: Northern NJ Posts: 871 | Re: Warning on epoxy floors Yea.. I used Ucoat It and that was three years ago.. so far so good. | |
03-23-07, 12:34
| | Rubbin' it all day long
armoredsaintt is offline
Join Date: Nov 2003 Location: Middle Ohio Posts: 578 | Re: Warning on epoxy floors Just like car detailing, it's about the prep. Did you do the moisture test on your floors before? Scrubbing with a degreaser and then a muriatic acid wash and etc? What brand did you use from Homey D?
I just ordered UCoat It yesterday, definitely excited about putting it on! It's also $400 more than the Rustoleum stuff for a 2-car garage too.
2006 BMW 330i Titanium Silver / 2004 Audi TT-QC Brilliant Black
03-23-07, 04:24
Join Date: Mar 2007 Location: Bainbridge Island, WA Posts: 57 | Re: Warning on epoxy floors The stuff I used was much cheaper than the UCoat It system, about $50.00 per gallon, if I remember correctly, and took about 300 ft sq per gallon. This was a couple of years go. From the looks and price of UCoat It, this stuff looks prifessional. I used an alkaline wash rather than acid. The prep certainly might have something to do with the results, but there's just no comparison to the stuff I used and UCoat. Now I've got to figure out how to get the crap off the floor so I can redo it, correctly, this time, I hope. I think I'll hire it out. I'm getting too old for all this work stuff. :-)
03-23-07, 07:51
Join Date: Nov 2003 Location: Middle Ohio Posts: 578 | Re: Warning on epoxy floors Sorry for your problems, I talked to UCoat-It about using an alkaline wash instead of a regular degreaser and it wasn't recommended. The alkaline will actually raise the pH levels on your concrete and the muriatic acid wash is suppose to lower the pH levels and etch it for epoxy. You can rent an orbital concrete sander from Home Depot. I think it's $24 for 4 hours. Good luck!
03-23-07, 08:46
qadsan is offline
Join Date: Aug 2005 Location: SoCal Posts: 215 | Re: Warning on epoxy floors Quote: |
Originally Posted by mschuyler I have a three car garage. During the winter the floor would get wet and stay wet. (whaddya expect in Seattle?) When it dried a white powder would encrust the floor, leached from the concrete.... | What you're seeing is efflorescence, which is caused by moisture that penetrates through the concrete. No matter how you prep the surface, you'll always have a problem with epoxy lifting or peeling. You've got to go to the root of the problem and seal the concrete and even then you still run a risk.
There are water-based sealers that are proven to work well. You want one that says it reacts with hydrated lime (calcium hydroxide) and alkali. A product like this will penetrate into the concrete filling the voids and bonding all the particles into a solid mass. The sealer basically becomes a permanent part of the concrete and forms a permanent moisture barrier / seal. Only then will you have a chace of good results with your epoxy floor, but make sure the sealer you're using is compatible with the epoxy you're using.
If you want the really good stuff (epoxy), then look for a two component self leveling 100% solids non-blushing cycloaliphatic amine cured phenol novolac epoxy. This type of epoxy provides excellent protection in extremely hostile environments when factors such as heat, chemical and abrasion factors are concerned. While you won't find this high of quality product at Home Depot, you don't have to look too far because your local paint supplier may be able to get you this kind of product. Or you can simply google for this type of product and I'm sure you'll find plenty of companies offering this type of high quality epoxy. You'll find this kind of product used in the military, nuclear applications, etc. And it's not all that much more expensive than some of the higher end DIY kits, but prep is the key in addition to making sure you do not have any issues such as efflorescence, etc. | |
03-23-07, 09:30
| | Enjoying Single Life
Monte78Carlo2k1 is offline
Join Date: Feb 2006 Location: Michigan Posts: 455 | Re: Warning on epoxy floors I have also read that multiple coats helps a lot too.
BGB Mobile Detailing Service - ASE and I-Car certified Refinishing Technician as of August 12th, 2008
My Cars: 78 Monte - 01 Monte LSX - 04 KB Cobra
03-23-07, 11:01
twitch is offline
Join Date: Jan 2006 Location: near New Orleans, LA Posts: 959 | Re: Warning on epoxy floors There are people who used the epoxy floor coating with success. See this thread: http://autopia.org/forum/garage/5522...ighlight=epoxy
As mentioned good preperation is the key. I still haven't tackled this project but intend to do it soon with the Rust-oleum epoxy shield.
__________________ Scott - 04 G35 6MT Coupe - Club Flex | |
03-23-07, 11:18
| | Turtle Wax User
LouisanaJeeper is offline
Join Date: Apr 2003 Posts: 1,730 | Re: Warning on epoxy floors i want to do something to the garage floor soon. I think I am going with a concrete sealer/stain. want to change the color to more of a tan to match the exposed aggregate driveway
Black Mustang GT
03-25-07, 03:25
| | MaThGr82 Custom User Text
MaThGr82 is offline
Join Date: Dec 2004 Location: Peoria, AZ Posts: 223 | Re: Warning on epoxy floors My experience has been completely different with the epoxy floors. Living in AZ, I have not had any of the peeling issues you have.
2002 325Ci
2000 Chevy Z71
03-26-07, 10:53
BJ007 is offline
Join Date: Sep 2005 Location: Phoenix, AZ Posts: 44 | Re: Warning on epoxy floors Quote: |
Originally Posted by mschuyler So, this is just a warning. If you think the Home Depot epoxy thing is cheaper, it is, in more ways than one. Stay away. | Not to flame you here, but did you do the moisture test? Looks like a 10 cent garbage bag and some duct tape would have saved you $200 in epoxy. Sounds like you're upset at the product because you failed to do the proper prep work. It has worked for many of us. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 09:41. | | | |
