03-28-08, 04:30
#13 (permalink)
baseballlover1 is offline
Join Date: Dec 2005 Location: Virginia Posts: 1,428 | Re: Best flooring for detailing Quote:
Originally Posted by admac some people re-use the gray water for non-potable purposes like watering the lawn or landscaping. it's a conservation effort. | We do not.
Again, im not possitive how it works. me and my father have a 13 hour car ride to FL today so ile ask him and have an answer for you tomorrow.
Daniel J Wendell
03-28-08, 04:57
#14 (permalink)
| | Precision driver!
mhadden is offline
Join Date: Jan 2008 Location: Chicagoland Posts: 212 | Re: Best flooring for detailing Quote:
Originally Posted by baseballlover1 Im thinking epoxy, or stained right now. This garage would ONLY be used for detailing and car storage for my personal car every night. This "wing" of the garage would be added onto our pretty large garage already that is concrete.
As for the drain, there are a couple problems i plan on by passing. My house isnt hooked up to the sewer system, we have it drain under ground in backyard so it is a little hard. Since we have to take up the whole thing anyway we are just going to put a drain that goes directly behind the garage. This is illegal but we can just tell the inspector that we dont like water collecting on the floor. Theres gotta be a way around it. | If you do epoxy, I can't stress enough how important the first step of stripping/cleaning the floor prior to application is. If you don't do it properly, the epoxy will peel up. Usually, the only time I've seen a problem in the 7 garage my father and I have done is when the concrete was sealed already. If it is, the acid cleaner won't do enough. You will have to purchase some concrete etch to remove most/all the sealant, then use the acid cleaner, then apply.
As for the drain, yes, the EPA sucks sometimes, but now with my floor epoxied and smooth, I just spray with a hose or PW and use a 24" squeegee to wipe dry.
-Matt | |
03-28-08, 05:38
#15 (permalink)
Setec Astronomy is online now Join Date: Jul 2004 Location: New Jersey Posts: 7,398 | Re: Best flooring for detailing Quote:
Originally Posted by admac some people re-use the gray water for non-potable purposes like watering the lawn or landscaping. it's a conservation effort. | I'm familiar with the technique, having lived through two periods of water rationing. I'm just not familiar with building a house with two sets of drain plumbing to facilitate that or to relieve the load on a septic system (in which the aforementioned "draining it under the back yard" would not be considered a conservation method).
Grumpy like Ketch...
"You're darned right it does!"
03-30-08, 10:11
#16 (permalink)
MBenz is online now Join Date: Mar 2008 Location: Colorado Posts: 116 | Re: Best flooring for detailing The way most septic systems work to my knowledge is what is a 2 tank system. The solids fall into the first tank and the liquids spill over into the second thank. From there the liquids will go out into the leach field. It is dry enough here in Colorado that you can noticeably see how the grass is greener over the leach filed. That is probably why you think it is draining into the backyard. Just a friendly word of advice, know where your septic tanks lids are and get them pumped as a precautionary measure when you move in.
Anyways, back to the subject at hand,
I've personally had really good luck with just plain concrete. I really wish i had a drain in my garage, especially in the winter when the snow melts off the cars and pools up. I'm not sure what it takes to put in a drain in Virginia, but if you are going to do it to code, do it right, trust me it will pay off. If the inspector is a real A$$, he could make you rip it all up and do it again.
My $0.02 | |
04-22-08, 11:26
#17 (permalink)
BlueLibby04 is offline
Join Date: Jul 2006 Location: Eastern Ky Posts: 1,031 | Re: Best flooring for detailing Quote:
Originally Posted by Setec Astronomy Wow, I've never heard of a house with separate drain plumbing for the sinks and showers from the toilets. What do you call that...you have sanitary lines for the toilet, and gray water lines for the sinks and showers? Sounds to me like all that extra plumbing and keeping it all straight would be more expensive than just having a properly sized septic system, but then again, you do live in one of those affluent areas where people would pay more to run their gray water somewhere other than the septic system. | Its not that complicated. All of the pipes in our house go to the basement. It just so happens when they built the house, they made it so all the showers and sinks in the bathrooms went into one 2" pipe with the washer(which is in the basement). We cut that and sent a pipe over the hill for the showers and sinks. Works out great!
Usually you have one big tank(ours is 10, 000 gallons) then a smaller tank for the water. The water stays on top of the poo then goes into another small box called a distribution box. This is where all the water goes out into the yard.
2004 Jeep liberty w/ stuff.
05-08-08, 03:48
#18 (permalink)
Join Date: Dec 2005 Location: Virginia Posts: 1,428 | Re: Best flooring for detailing we have 1 septic tank and the fluids spill over and into the septic feild. the solid matter is eaten by bacteria.
i think im going to go with epoxy.
Daniel J Wendell
05-08-08, 05:19
#19 (permalink)
Originally Posted by baseballlover1 we have 1 septic tank and the fluids spill over and into the septic feild. the solid matter is eaten by bacteria. | So what was the answer, do you have separate lines for the sinks and showers that bypass the septic system, as you said earlier, or does all of the water go to the septic system?
05-08-08, 09:37
#20 (permalink)
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,338 | Re: Best flooring for detailing Quote:
Originally Posted by baseballlover1 ..i think im going to go with epoxy. | If you mean epoxy *paint*, note that a) it probably won't adhere 100% even if professionally installed on a new floor (voice of experience several times over), and b) it'll be *VERY* slippery when wet unless you add some friction media (e.g., sand) to the top layer.
There are other "epoxy" floor coatings. I have a mixture of epoxy and stone (they advertise these for basememts/etc.) that's also sealed with more epoxy. This has the friction media too, but after ~8 years it's wearing away enough that I know I'll have to have it redone some day.
The "regular"/unsealed epoxy and stone flooring did *not* work well for me...it held water and made for way too much humidity. They'd said that the water would flow to the drain and that it'd dry out, but that didn't happen so they had to redo the whole (44' x 44') floor.
Oh, and I really would give some thought to the drainage. A lot of the stuff that'll be going down the shop's floor drain is stuff you *do not* want to just leave untreated. I'm nobody's idea of a tree-hugger, but still.....this is a case where IMO you really oughta do the responsible thing.
Yeah, I know, that's a big PIA over "what goes down the drain". When we were looking for our current place, stuff like that was a big part of deciding which property was/wasn't suitable. Before we built this place, I had to have a commercial building to do my detailing as my previous homes just weren't set up to handle such stuff. | |
07-30-08, 09:17
#21 (permalink)
| | RX-7 Freak
RDAVEX7 is offline
Join Date: Sep 2007 Location: Yakima WA Posts: 208 | Re: Best flooring for detailing I cant believe I missed this thread!
Anyways, I guess this is where you learn a little about me, and why a house would have separate drainage systems. Oh, and I know nothing about garage flooring
I am a plumber and have been for a long time. It's the only thing I know how to do well because I grew up doing it. My dad has been a licensed plumber since before I was born and I followed suit. Heck, I was almost born in a plumbing van, no lie! The truth is that even though I have made alot of money plumbing I love cars and have realized that I would be much happier in this field. This is why I love Autopia, it's like my code book for auto detailing! By the way working with your dad is pure hell when your young lol, but as you both get older you will learn to appreciate him. But im torn between what I know and what I love so I started my little business in the detailing world and I still work as a plumber but hopefully I can make the complete transition soon. Kinda scary really.
Enough about me. Daniel, do you have an older house? Most older homes were built to old codes or no codes. The septic tanks were usually under sized or only had the sewege in mind. So usually the toilet or the entire bathroom are the only fixtures on the septic tank. The kitchen, laundry etc are all grey water that sometimes bypasess the septic tank and connects straight into the same drainfield. Or they can have theyre own separate drainfield and even have a small inline 50 gal or less grease interceptor outside just for the greywater. Usually they are small homemade concrete vaults that nobody knows is there untill things stop draining. So the 2 separate systems leave the house at different exit points. Things changed along time ago but there are area's where this type of stuff still goes on.
Somebody said they had a 10,000 gallon septic tank, I think it's more like 1,000. Septic tanks are sized by the number of bedrooms in the house and they should be pumped about every 3-4 years. Even with only 2 people in the house. Sure you might go twenty years without pumping the tank but all the while the solids have slowly made theyre way into your drainfield and will cause a huge problem down the road. Most septic tanks are one solid tank with 2 separate chambers inside, sometimes 3. The inlet (solids) side, and the outlet (effluient) side. Drainfields are another issue.
It sounds like you would have to instal a sand/oil seperator to have the drain you want in your garage. Basicly you would have to set up like an oil or lube shop in your garage! Thats expensive, and you would have to jump through alot of hoops to get it approved. Then there is the issue of disposal in to a new separate drainfield or where ever the county would let you. They probably would say no. If you were on city sewer you would have more options as the waste water would be treated at it's final destination. And you would have to pay a company to pump the sand/oil separater on a regular basis. Maybe they would consider it storm drainage but I doubt it since there is the chance of oil getting down the drain.
I know this is an old thread but I kinda feel it's my way of giving back where I can since I have learned alot of stuff here from some of the best in the biz. I dont have to be a pro to know who's the real deal and who's not. I have stepped my game up big time and also alot of trial and error lol.
Black 1957 Porsche 356 Speedster / Black S4 RX-7
Red S5 RX-7 Convertable / Blue Dodge Durango
07-31-08, 09:59
#22 (permalink)
Join Date: Sep 2002 Location: NE Ohio Posts: 20,338 | Re: Best flooring for detailing RDAVEX7- Good to see an expert opining on this thread, and heh heh, you've reminded me why I'm glad I'm no longer on a septic system
One area where my experiences have been different though, the oil separator:
I had zero problems with zoning/code having one installed in my home shop, they were *happy* that I wanted to do it. And mine probably won't need pumped out in my lifetime, based on my experience with a smaller-tank unit at my previous shop (which was a commercial operation with much more oil/etc. going down the drain). I had that tank pumped after ~10 years, and it turned out that it wasn't really necessary...the thing wasn't even 1/3 full. The shop that did the pumping was responsible for the disposal, so the whole thing was transparent to me, well, other than the bill!
That was my experience, but there are lots of variables that could factor it, so please don't take this as an  | |
07-31-08, 06:08
#23 (permalink)
| | RX-7 Freak
RDAVEX7 is offline
Join Date: Sep 2007 Location: Yakima WA Posts: 208 | Re: Best flooring for detailing I dont care for septic systems either lol. Your right there alot of variables and set up differences. The waste has to go somewhere kinda like a car wash.
There is still some old houses in the old nieghborhoods here that have septic tanks. Sometimes an apprentice will run 120' of cable into it thinking they are on city sewer lol. City sewer is less headaches for a homeowner.
07-31-08, 07:24
#24 (permalink)
| | Be Noticed
Twinscroll is offline
Join Date: Mar 2008 Location: Northern Virginia Posts: 42 | Re: Best flooring for detailing I love this site more and more. I've been in a good mood all day, minus my accounting class earlier tonight, but to have someone want to give back even though it was an old thread was awesome. U imparted knowledge without the superiority copmlex. I learned a lot to say the least.
I think that to installation of a drain in any matter would be very benificial. Not only is it a business expense but simply the peace of mind that it can give you. Beyond all of that is the fact that with any customer (some are more environmentally concious than others) and if they see you running a business out of the home some might ask how you do dispose of the water. And your answer could be the key to having another repeat customer or not. Might not be worth it in some peoples eyes to just have one more repeat customer for all the money that it might cost to install the drain. But you never know. It's definitely the responsible thing / right thing to do in a case as the one in this thread.
__________________ ~Tyler C.
T.C. Detailing L.L.C | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 07:15. | | | |
