Re: Rim Grip? Center Post? Help....
Also check on tirerack.com for their recommended installers. Hunter has some of the best mounting machines available. They use rubber "pads" that protect the rims surface from damage.
I think that the rim grip mounting will be either a 3 or 4 point machine that will hold the outside of the lip. They'll grip the rear of the wheel(side that is not seen) so the face of the wheel won't be damaged.
I've not seen a center mount so not familiar with that one.
