It is fairly easy to paint your calipers actually but be sure to allow yourself a good bit of time for the task.
You can use high temp engine paint and it will work fine. I did this on my old Prelude and it looked good and didn't peel or chip (except where I hit it with the wheel when rotating my tires once). You can find the paint at Autozone or any automotive parts place.
Be sure you prep the calipers to remove anything that the paint will not stick to such as grease or oils. Mask off everything as best as you can with tape and newspaper remembering to also cover most of your car because of the overspray that will occur. You will basically make a paint booth in your wheel well so to speak. Use high temp primer than the high temp paint according to the instructions.
Be careful with one thing though if you do paint them. Do not spray the caliper, after it is painted, with brake cleaner. It will make the paint crinkle up and may remove some of it. Yes, I’ve experienced this first hand
Powder coating offers a wide range of colors and is very durable. However, it may not be practical to do on a daily driver and will involve much more labor. You would have to remove the calipers, disassemble them completely, have them powder coated, reinstall, bleed them and so on…
OR
You can trade in your sedan for an 03-04 6 speed manual and have nice gold painted Brembo calipers
Originally Posted by Coupe
I painted mine with the G2 paint kit.
Your calipers look good.
