From
http://www.seafoamsales.com/
"SEA FOAM MOTOR TREATMENT
Solving Engine Problems Easily and Inexpensively!
See SEA FOAM MOTOR TREATMENT technical information
Common Reasons Service Technicians Use SEA FOAM MOTOR TREATMENT
When your vehicle has a rough idle, hesitates, stalls, pings or has an after run problem – this is often due to carbon buildup.
Your service technician can offer a reasonably priced fuel systems cleaning with the use of SEA FOAM products to solve these carbon problems.
When your vehicle’s fuel injectors need cleaning – this is often due to residue left on injectors from poor burning fuels and contaminants.
Your service technician can offer an inline fuel injection cleaning with the use of an injector cleaning machine and SEA FOAM MOTOR TREATMENT. SEA FOAM MOTOR TREATMENT is also added to the fuel to disperse moisture, clean fuel lines and injectors while driving.
When moisture needs to be removed from fuels or an anti gel or de-icer is needed – these conditions are due to condensation in the fuel tank and extreme cold weather creating gas line freeze or diesel fuel gelling.
Your service technician can recommend the use of SEA FOAM MOTOR TREATMENT in the fuel tanks to dry moisture and cure these problems.
When there is moisture detected in the oil – this problem is due mostly to poor ventilation and condensation. Sometimes, however, there is a bad head gasket, cracked head or block that must be replaced.
Your service technician will diagnose the problem and recommend the repairs. As part of the diagnostics, a SEA FOAM MOTOR TREATMENT can be used in the oil crankcase to cure the moisture problems. A SEA FOAM MOTOR TREATMENT can also be used in the oil crankcase after repairs to make sure moisture is eliminated.
When valve lifter noise is apparent or piston rings seem to be sticking – this is often due to dirty and gummed up oil passages, varnished lifters and buildup of gum, varnish and carbon in the piston ring areas.
Your service technician can offer a SEA FOAM MOTOR TREATMENT that will clean sticky lifters and free sticky rings. By doing this treatment you will be able to determine if there is a varnish problem or a mechanical problem.
To help pass emissions tests – high emission numbers are usually caused by extreme carbon build up, dirty emission control items such as: pcv valve, egr valve, oxygen sensors or bad spark plugs and wires.
Your service technician can provide a pre-emission test service that includes SEA FOAM MOTOR TREATMENT as a cleaning agent to help pass emissions tests.
When fuel stabilization and engine fogging is needed – fuels of today become stale in less than thirty days. Therefore, stabilization and engine fogging are needed when vehicles, lawnmowers, snow blowers, outboard motors, chainsaws, motorcycles, gas in cans and engines are put into storage. "
