05-28-06, 08:55
metload1 is offline
Synthetic Oil
Hey,
Is it true that once you put synthetic oil in your car, you can never put regular back into it? Even when getting your oil changed?
Thanks!
metload1
05-28-06, 08:57
hadboosttroy is offline
total myth
05-28-06, 09:19
Welcome 2 the KEVOLUTION
gmblack3a is offline
Originally Posted by hadboosttroy
total myth
I agree 110%.
05-28-06, 09:26
It relaxes me
RP-350Z is offline
Yup yup it's a myth.
05-28-06, 10:36
Canyoneer
John Styrnol is offline
I totally agree, but once you start using Synthetic you won't go back, LOL
My Home Page
00 Explorer XLT
05-28-06, 11:53
Not too old to learn.
RTexasF is offline
Agreed.... That is a pantsload.
05-28-06, 06:07
FalconGuy is offline
bobistheoilguy.com
Like this forum, but for oil.........
On the other Hand, your dealing with an entirely different set of fingers
05-28-06, 06:26
Rupert Pupkin
jdoria is offline
I believe there are more myths:
Synthetic is so slick, it will go through your piston rings if you use it after 3000 miles.
You cant use synthetic if you have used regular oil for longer than the break-in period.
A 60k+ mile engine will die with synthetic in it.
There are a lot of stories. I use only Mobil 1 and have for 15+ years. Good or not, I feel good. I have cases of it in my garage, I bring it to my oil changes. Along with Sunoco 94 octane fuel. For the few extra bucks, who cares!
05-28-06, 07:35
victory is offline
I'm a die hard Amsoil user. Every fluid that needs changing gets changed with Amsoil.
05-28-06, 07:43
O-C-Detailer
TnM6i is offline
Yup, it's a myth. Have you ever noticed "Synthetic Blend" oils on the shelf with the dino and synthetic stuff? If they can mix it in a bottle, there's no reason why changing back and forth in the engine would harm anything.
 Obsessive-Compulsive Detailer
05-28-06, 07:49
Tenebris1 is offline
It's a myth, although I wouldn't be switching back and forth. I've been using Lubro Moly and then Elf synthetics in my turbo Volvo for over a decade and she has always been running great. Regular changes are still key, I usually do so well before it's recommended (6000 kms on average).
05-28-06, 08:44
SayNoToPistons
another qx4 is offline
yup those are myths. at rx7club some of us believe that we shouldnt run synthetic oils in rotary engines but the truth is that you should never run craptastic synthetic oils, so its ok if you go for the big brands like Mobile 1.
Mazda RX8 Velocity red mica
Infiniti QX brillant silver
