04-26-06, 07:36
wasaabi is offline
BBS RK-II 2 piece rims...how do I take it apart?
Hey everyone, I got a set of these rims ( for reference ), 17x8, 5x112 BBS RK-II rims. I can't figure out how to take the rims apart, stuck a 6mm hex in there and it fit, turned it and it stripped a bolt...anyone have any idea what size BBS uses for the bolts on their multi-piece rims? It's a 12-pointed star, and I know the size is between a T40 and T45, but I don't know if i want to risk a 6 sided tool again, might strip the rest.
04-26-06, 07:49
Setec Astronomy is offline
First of all, I don't think those come apart. Second of all, why would you want to take them apart?
Grumpy like Ketch...
"Well, it certainly does!"
04-26-06, 07:58
wasaabi is offline
They do come apart, because they are two piece wheels. I want to refinish my rims and do a good job with it, so that's why I wanted to take them apart. Cant find the tool anywhere...
04-26-06, 08:08
Well, just because they started out as 2-piece, doesn't mean they were meant to come apart. You mention a hex key, a "twelve pointed star"and then two Torx key sizes, which is it? Are you saying it looks like a Torx but it has 12 lobes instead of 6? Or that it looks like the inside of a 12-point socket? Also, you say you stripped a bolt, does that mean you stripped the drive out of the head of the bolt?
04-26-06, 08:14
wasaabi is offline
I used a 6mm hex and it stripped, what I'm looking for is a 12-pointed tool (not sure what it's called)..
04-26-06, 08:27
There are a number of proprietary internal-tooth drive systems, I am unaware of any that have 12 teeth/lobes/elements. I really don't know, but I wouldn't be surprised if those fasteners are not what they seem, and may not be removeable. Do you know anyone else who has taken these apart?
04-26-06, 09:10
wasaabi is offline
nope, I don't....but I am pretty sure they are able to be taken apart, that's the whole point of 2/3-piece wheels, replace only one part for cheap when the other is undamaged
04-26-06, 09:16
I don't have much to add
SpoiledMan is offline
Are there assembly bolts on the back side of the wheel face? If not, they are likely "bonded" together and don't come apart by removing the bolts.
Black cars are fun!
04-26-06, 09:58
wasaabi is offline
I just looked at the back of the rim, and all I see is the line where the two pieces meet (basically, I see nothing). I'm kinda disappointed if that's the case...but thanks to everyone that has replied, I might try calling a rim refinishing shop to see what they know.
04-27-06, 03:06
Originally Posted by wasaabi
... I am pretty sure they are able to be taken apart, that's the whole point of 2/3-piece wheels, replace only one part for cheap when the other is undamaged
<shrug> That may be the case with racing wheels, but many street wheels are made to look like that without actually being like that. That's not the only reason to make wheels from multiple pieces, either. According to the BBS site (which has a half unintelligible translation from the German) your style wheel has a rolled rim with a cast center section. The rolled rim would be made from wrought material, which would give it different mechanical properties than a cast part (higher tensile strength, zero porosity, etc.). The two halves could be permanently attached as SpoiledMan indicated (welded, swaged, etc.) and not seperable while still having advantages over a one-piece cast wheel. The bolt heads could just be for show (as on many one-piece cast wheels). Someone here will know if they come apart. Anyway, good luck whichever way it turns out.
04-27-06, 07:18
wasaabi is offline
Where did you see the spec of the wheel on the official BBS site? I saw it elsewhere before but I always like to look at the original source. I looked all over and it seems to them that the RK-II basically does not exist..or I'm looking in the wrong places..
04-27-06, 07:53
Rupert Pupkin
jdoria is offline
If you get them apart, wait until you tryto put these back together!
You will need about 5lbs of lead to balance each wheel!
Dont waste your time. they are made in pieces for stregnth and weight, not for cleaning.
