In a previous thread, I asked for recommendations to remove imbedded brake dust from the backs of alloy wheels. I've tried Megs
Hot Rims and E1 wheel cleaner and used a soft brush but still had a lot brake dust remaining. After trying the wheel cleaners and brush, I then tried clay with both wheel cleaners. Still a lot of brake dust. So I stepped up the aggressiveness, continuing to use the wheel cleaners and tried a scotch pad and then 0000-steel wool. Slightly better results but still didn't get all the brake dust. When these still didn't work, I finally wet sanded the back of the wheel with 600 grit. Finally, the brake dust came off. The finish appears to have some etching left by the brake dust. What grit sandpaper would I need to use to get rid of the etching? After sanding, I would like to clear coat the backs of the wheels. I'm not convinced that there is any clear on the backs or if there is, it's mighty thin. The wheels have a grove type casting on the backs which allows for dirt to get easily embedded. I think it is a ridiculous design. They should have been smooth. A lot easier to clean. The fronts of the wheels are just about perfect so i don't want to mess with them.
Can someone help me out with the steps to sand and clear these wheels? What do I need to do to prep the wheels before clear coating? Grit numbers to use? Also, could anyone recommend a clear coat to use? I've heard about Duplicolor Clear Coat but I don't know about its quality.
