Old 02-08-06, 05:40   #1 (permalink)
twopu is offline
How often to change fluids?
I got my oil changed today and they recommended fuel injection service, transmission fluid and radiator fluid change. I have a 2000 Honda Accord with 62,500 miles. I had my transmission and radiator fluid changed at 43,000 miles and never had my fuel injection serviced. My mechanic said I didn't need it yet, but the Honda dealer and Grease and Go say I do. Should I just get my fuel injectors cleaned and hold off on the two fluids?
Old 02-08-06, 06:10   #2 (permalink)
Kayak detailer
White95Max's Avatar
White95Max is offline
I don't think fuel injection service is really necessary. Most gasoline contains ethanol, which will clean the injectors continuously. You can also buy fuel injector cleaner at the local store for a couple bucks, and dump that in your tank if you want.
I changed the Maxima's coolant/antifreeze every two years, and I changed the Protege's manual tranny fluid to synthetic last fall. I just bought the car in July, and I believe it hadn't been changed since 2002. I don't think I'll change the tranny fluid again, because I'll probably be selling the car in a couple years, for a Mazda6s or similar vehicle.
Paul...
Old 02-08-06, 06:34   #3 (permalink)
One Shiny tC
Neothin's Avatar
Neothin is offline
Contact: Send a message via AIM to Neothin
I haven't had the tC long enough to really figure out any of fluid change intervals, but I think ill replace trans fluid @ 30,000, oil every 3,000, radiator fluid 1x a year (the summers here put a strain on the cooling system, rather safe than sorry), throw a bottle of fuel system cleaner 2x a year, change the fuel filter 1x a year, ummm brake fluid idk, anything else that i missed?
Mods can be found HERE
AIO-RMG-Souveran
Old 02-08-06, 06:45   #4 (permalink)
Canyoneer
John Styrnol's Avatar
John Styrnol is offline
When I had my injector's clean, they also clean the throtle body and the MAF which is nice.
My Home Page
00 Explorer XLT
Old 02-08-06, 06:48   #5 (permalink)
jchetty's Avatar
jchetty is offline
i dont know bout the fuel injection service, many ppl think its a gimmick. to clean the injectors like the *claim* to, they would have to remove them = alot of work. I agree, rather change your fuel filter and add some fuel injection cleaner which you can buy at any auto store, just follow the label any maybe buy a funnel to minimze spills as for the coolant change you can wait 10k. Keep in mind that flushing your coolant is alot more effective than draining and filling, so if they dont hook up your car to a machine they are not flushing and you so drain and fills should be done more regularly. I bet you noticed a huge difference when you changed the tranny fluid it really helps.anyways I tend to do the following when it comes to fluids
radiator flush - 6 months
coolant drain(complete engine) - every yearly
oil - 3k miles (synthetic)
brake fluid - (yearly)
clutch fluid - (yearly)
power steering - (yearly)
manual tranny fluid - (yearly)
Old 02-08-06, 08:43   #6 (permalink)
Setec Astronomy's Avatar
Setec Astronomy is online now
Holy crap, jchetty...radiator flush every 6 mos??? Most cars it's 2 years or 30 months/24,000 miles, something like that...my Acura says 10 years (!). I personally think injector cleaning is a gimmick, but I really only have long term experience with GM cars; I would recommend some Techron first (if you are actually having problems, or maybe as a preventative service if you're not).
Grumpy like Ketch...
"Well, it certainly does!"
Old 02-09-06, 05:16   #7 (permalink)
flatstick is offline
Dude what kind of oil are you using that you change at 3,000 ? take a trip over to BITOG and see that the 3,000 oil change is a thing of the past with todays modern oils. one thing you will learn at BITOG is that all oil filters are not created equal, they have done extensive testing on them and you will be suprised what the results were. also I would get an UOA ( used oil analysis) to get you started on you OCIS ( oil change intervals) as far as the tranny 30,000- 50,000 is the norm, unless you are towing a lot. I have not heard about any differentials being changed here.... hope people are doing that, especially if you have a new car with all the break in shavings in the rear
Old 02-09-06, 05:20   #8 (permalink)
Danase's Avatar
Danase is offline
I hate those oil change shops, they are always trying to con you into more than you need. The one I used to go to told me I needed a radiator flush because my fluid was brownish. Well, I actually did a radiator flush on the truck and filled it with new fluid 30 minutes before I went for my oil change. I never went back. Just do what the manufacturer recommends and you will be fine. And don't go for that fuel injector service crap. In all of my cars I have had an injector go bad and it was on a ZX2 that had more problems than anything. Your Honda will go 300,000 miles without needed any sort of fuel injector service.
Old 02-09-06, 05:22   #9 (permalink)
Danase's Avatar
Danase is offline
Eh, I use Mobil One Synthetic in my car and still change it every 3000-3500 miles. That stuff is pretty dark when I take it out and I would not want to drive with the old oil for much longer than that.
Old 02-09-06, 05:25   #10 (permalink)
jchetty's Avatar
jchetty is offline
one is 6month old the other is year old antifreeze i did mine and a friend who was over asked me to do theirs, i couldnt say no. some cars take that orange antifreeze which supposedly lasts longer..i wonder if that to is a gimmick..hmmm
***edit***as for the frequent changing of fluids i do my own oil changes. and when the car is on jackstands i might as well changing the tranny fluid...tranny fluid change takes me all but 6 minutes tops, the hardest thing is filling it. and for oil changes, better safe than sorry, kinda of like how someppl ask me why I wash my car at least weekly or why i wax it monthly....i say im an autopia the craziest thing is radiator flushes on my car, i dont need to put it on jackstands , that takes bout 10 minutes tops
Old 02-09-06, 05:52   #11 (permalink)
Don't get me started, I was busy and didn't feel like messing with the brakes on my car, so I went to [insert name of national tire mfr/service chain] and told them that I wanted the brakes done. So I'm sitting there waiting and I see my car drive by and out into the street. So I ask the guy at the counter what's going on, and he says that it's standard for them to take the car for a test drive before they work on it--so I tell him I know it needs brakes, and I just want to get that done, and they don't need to be checking out my car beforehand; he told me that's just their normal practice. So the car comes back, they put it on the lift, and tell me I need brakes (duh), and oh, by the way, when the technician was driving my car, he noticed that the windshield wipers needed to be replaced (it was a completely dry, sunny summer day, and of course the wipers were fine anyway). I just looked at the guy and said "You're kidding, right? I come in here for brakes and you're trying to sell me windshield wipers? Do people really fall for that? No, I don't want windshield wipers." He was basically speechless. (Before you guys start on me, I know that's a standard upsell, but please, they should save that for the housewives, it's not going to work on me)
Oh...and I generally try to stick to the standard drain interval even when using Mobil 1, both for warranty purposes, and because I look at it as an extra insurance policy...I don't put a lot of miles on my cars, so the extra cost isn't a huge amount of dollars for the added peace of mind.
Old 02-09-06, 05:54   #12 (permalink)
Is that the same brand antifreeze? And from the same car? I have noticed in the past that different brands can have markedly different colors.
