Touchup paint should apply the same in cold temps - no worries there. If you apply it carefully odds are you can get by without a wetsand/polish since you're having it re-sprayed in the spring. Then again if you're looking to experiment you could wetsand and polish just for fun (well, I consider it fun anyway!). Otherwise let the paint dry for a couple days then you can wax right over it. Oh, make sure to clean around the scratch with some alcohol/water before touching up - it's a major hassle if you apply touchup without removing wax first.
GTA In Detail
