10-29-05, 05:30
bonfire is offline
Warming up?
How long should you let your car warm up before you drive?
10-29-05, 06:16
Setec Astronomy is offline
I'm sure some people will tell you a long time, but for a variety of reasons, studies have shown you should go as soon as the oil pressure comes up, just take it easy until the car warms up, no hard acceleration/high revs, etc.
Grumpy like Ketch...
"Well, it certainly does!"
10-29-05, 06:18
Hayabusa
atticdog is offline
I try to leave then the cold engine light goes off
if you leave before its warm when its cold out it would take longer to warm up while driving due to cold air blowing on the engine and then run richer longer and use abit more gas
08 Scion XB Gold Rush
03 Toyota Echo 40+ MPG
01 Suzuki Hayabusa GSX1300R
10-29-05, 06:23
Canyoneer
John Styrnol is offline
I go within a minute.
My Home Page
00 Explorer XLT
10-29-05, 06:28
JohnnyDaJackal is offline
I usually only wait 1-2 minutes, mainly because i'm looking for the cd I want to listen to. IMO it's better to take it easy and drive really slow and conservative then to have your car ideling for 15-20 minutes then flooring it. It takes forever for your car to hit normal operating temps. if its just ideling and its a waste of gas. Not to mention its only warming up your engine; not your tranny, axels and all your other moving parts.
10-29-05, 06:29
What is a "cold engine light"? Also, I think studies have shown that driving warms the engine faster than idling. You want to minimize the time it takes to bring the engine to operating temperature to minimize piston ring blowby which causes condensation of combustion byproducts (water, unburned fuel, etc.) in your oil, and to get the emissions system (catalytic converter) up to (operating) temperature, if you care about emissions, that is.
10-29-05, 06:51
I eat plastic.
Corey Bit Spank is offline
About 30 seconds idling and then I drive lightly.
10-29-05, 07:01
Dr. Jan Itor
ZaneO is offline
I let it warm up for about 1 minute and keep the RPM under 2000 for about 10 minutes.
Originally Posted by David Fermani
I don't care if Sal dropped a deuce in my package
10-29-05, 07:17
LightngSVT is offline
1 - 2 minutes (or until the lights on the tach reach 6k rpm on the M3), then drive carefully for the first 5 minutes.
Chuck P
06 BMW 330i, 93 SVT Lightning, 91 Mustang GT, 98 Contour SVT, 09 Harley FLHX Street Glide
10-29-05, 07:18
Dr. Ramp
ramp is offline
My car tells me: When I start the cold engine it revs to about 1,200 RPM and stays there for several seconds. Then it drops back to 800-900 RPMs and I proceed.
10-29-05, 07:38
flatstick is offline
Depends on how long of a drive you are taking. the crucial factor of warming up a car properly is not really getting the engine to temp. making sure the oil reaches operating temp is a more important factor. your oil may never reach the temperature it needs to burn off the condensation that forms. Running it for a while before driving will provide more driving at a higher engine temperature, allowing the moisture to burn off. if you have a short drive in very cold weather not warming up the oil enough is a bad thing. if you have a longer drive you can get on the road faster and drive slow to start out with. nothing worse than romping on a cold motor. if you really want to know if you are doing your motor harm go grab a UOA. this will tell the condition of your motor and how it is wearing. just my two cents
10-29-05, 12:32
BenP is offline
Oil generally takes about 10 minutes to get up to temperature so I always drive easily until then. In terms of start up, I may leave it 30 seconds on a cold day but generally I go as soon as it;s up and running.
Ben
