Old 05-03-05, 08:05   #1 (permalink)
Advanced Noob
mystickid's Avatar
mystickid is offline
Exclamation Messed up my car paint...
I got a jet black 98' camry. I wanted to make the stock black door handles Chrome so i purchased the Dupli-colorâ„¢ Instant chromeâ„¢ spray paint. So i used newspaper and masking tape to cover everything on the door except the door handle and began spray painting.
Everything looked perfect for now...... Then after it dried (only one handle so far), i pulled off the masking tape and the newspaper. Then...... DAMN!!!!! Where the paint was sprayed over the masking tape no harm was done. BUT, where there was newspaper covering the door, the chrome spray paint bled through the thin newspaper and went onto my black doors. I screamed Ah!, then i ran in the house put some dish washing liquid on a little scrub and scrubbed the areas where the pasint bled through.
luckily i was able to removed the chrome spray paint on the doors but the scrub caused a few scratches which i can take care of with some 3M rubbing compound.
most fortunately, i only tried it on one door handle so all the other doors and handles are allright.
Now what I really need is if there is a "How-To" (with pictures) on removing door handles for a 98" Gen 4 camry. or a different solution where i don't have to remove the handles. I'm tooo scared to paint with the door handles on the doors right now. Well, you learn from bad experiences.
Well if anyone can help me out, I would feel alot better and would greatly appreciate it. thanks for any effort on your part.
Old 05-03-05, 09:05   #2 (permalink)
Shiny Lil Detlr's Avatar
Shiny Lil Detlr is offline
Contact: Send a message via AIM to Shiny Lil Detlr
Re: Messed up my car paint...
Try using a couple layers thick of wax paper instead of newspaper; it won't bleed through as easily. Or even better yet, a couple layers of wax paper and then some aluminum foil (so the foil isn't directly on the paint but is there as protection.
My $0.02
Old 05-03-05, 09:08   #3 (permalink)
yowza!
99se5spd's Avatar
99se5spd is offline
Contact: Send a message via AIM to 99se5spd
Painting them on the door is probably not such a good idea, because of the overspray/bleeding and also for the durability (it will leave a "raw" edge where it was masked off). most exterior door handles are removed by removing the interior door panel, and reaching inside the door there usually is 2 nuts (8 or 10mm) on imports. Once you get the handle loose you will have to play with the open/unlock mechanism attatched to the handle, most likely a metal rod that connects to the door latch assembly. Usually there is some sort of plastic clip that you must unclip to remove the rod, every vehicle has a different trick, just be careful! good luck.
2001 Prelude TypeSH
Old 05-03-05, 09:19   #4 (permalink)
This space for rent.....
Sullybob's Avatar
Sullybob is offline
Unfortunately I have no idea on how to remove your door handles. So here is an alternate suggestion.
Take Zip lock bags and cut them open and use them in the place of the newspaper. The paint should not bleed through the plastic bags. I would put newspaper over the top of the zip lock bags to absorb any over spray.
Test my zip lock bag theory first before you try this on your car.
Insert witty quip here...
Shawn
Old 05-03-05, 10:10   #5 (permalink)
94BlkStang's Avatar
94BlkStang is offline
Newspaper is filled with small perforations and will allow paint to seep through. Go to a paint store or home depot and pick up some masking paper. It usually comes in a roll and about 6" wide or more. It's made to mask off areas you don't want overspray to get on. It should be less than $10.00 for a roll.
Old 05-03-05, 10:43   #6 (permalink)
Advanced Noob
mystickid's Avatar
thanx everyone for tryin to help me out. i feel so lousy after what i did to my paint.
94BlkStang--> I think that masking paper may be a good idea. i'll go to home depot & check it out.
I'm aslo a bit scared of disassembling my doors.
Old 05-04-05, 12:42   #7 (permalink)
From Hobby to Obsession
Denzil's Avatar
Denzil is offline
Disassembling and reassembling interior panels/parts is not difficult at all... just depends whether you have the courage to do it or not. Stripping cars to prep them for the track is always fun.
Good luck in which method you decide to use.
Devil PAD
Professional Automotive Detailing
Old 05-04-05, 03:12   #8 (permalink)
Advanced Noob
mystickid's Avatar
Is there any manufacturer that makes Chrome door handles for a Gen 4 camry? I searched ebay but they only got regular black ones.
Old 05-04-05, 03:31   #9 (permalink)
Come on! Fhqwhgads!!
Jngrbrdman's Avatar
Jngrbrdman is offline
Contact: Send a message via AIM to Jngrbrdman Send a message via Yahoo to Jngrbrdman
My experience is that if its not on ebay then its probably not out there. Not too much in the aftermarket department for Camrys.
Something else that might work well is if you use some chrome looking vinyl to cover the handles with. It will look better and probably last longer than just painting them. In fact, you may even be able to apply it with the door handle still attached. You'll want to find a local sign company that works with vinyl to get the material from. Or you can go to trusty ebay and shop there. I know they make it in chrome and also a really sweet brushed aluminum color. I had some STi decals made out of the aluminum type and it worked out great.
edit: by the way, if you check out that ebay guy's other auctions you'll see that aluminum vinyl as well as some pretty cool looking diamond plate vinyl too. Mmmmm....vinyl.
...it should be Encouraged!
Old 05-04-05, 08:10   #10 (permalink)
Advanced Noob
mystickid's Avatar
Jngrbrdman,
Super thanx, for the great suggestion. I feel alot safer with using adhesive chrome strips. That is such a genius idea; you're brilliant! I hope the vinyl isn't that thick.
Do you happn to know anything about how strong its adhesive is, I don't want it to fall off during the highs & low temps of Chicago.
It sounds really promising for me & will hopefully solve my plight.
Thanx again.
P.S. Thanx everyone for chiming in to help.
Old 05-04-05, 08:24   #11 (permalink)
Jngrbrdman's Avatar
I used carbon fiber vinyl on the sideskirts of my Integra. It lasted 2 years in snow and shine before I sold the car. It was still there last time I saw it. I think it will probably last longer than your paint will. The vinyl isn't really that thick either. just cut some out to fit and then use a hair dryer to heat it up and get it to conform and sort of melt around the edges. It should clean up great and look a lot better than spray paint.
edit: In case you are curious... carbon fiber vinyl sideskirts thread here.
Old 05-04-05, 08:47   #12 (permalink)
Turtle Wax User
LouisanaJeeper's Avatar
LouisanaJeeper is offline
i cannot see chromed out door handles looking very good on a camery
body color matched black > ghetto chrome spray paint
Black Mustang GT
