Old 03-02-05, 03:38   #1 (permalink)
Bill D's Avatar
Bill D is offline
Bumper Plugs
I no longer need a front license plate here in Florida so I after taking a while deciding whether to install an Audi logo plate or trying to get the cleanest front bumper look possible, I decided to opt for the clean look. ( I do have a nice 3D emblem plate on the Caddy) I needed two pairs of custom painted Bumper Plugs to get this look. I had to wait for a while for all of the plugs I ordered to complete production before they could be shipped to me but it was exciting when they finally came.
I uninstalled the front license plate holder and polished spots of the area now exposed. When they finally arrived, I installed the four Bumper Plugs, which are made for a perfect fit for the ¼” holes in the bumper. As stated by the Bumper Plug instructions, dealer drilled holes on non Porsche vehicles need to be made drilled larger to fit the ¼” diameter. Thanks to my friend Ken, having the courage, which I did not for doing this for me .
As you can see from the red markers I drew on the photos, there was a slight outline in the paint where the plate holder was and some spots near the exposed holes that were in need of polishing.
Unfortunately, the screws that had held the top of the license plate that was once there had made small, shallow pin holes in the bumper and half circle shaped indentations around themL
I hoped once the Bumper Plugs were installed they would detract from those two spots. I tried a very close work touch up job on the pin holes. I broke out my old bottle of Langka following painting and for these tiny spots, the results are half decent, about the best I could’ve hoped for. The half circle indentations are discouraging. Other than those, the rest of the exposed area inside the perimeter of where the plate holder sat seemed defect free.
The portion of this area where the bumper curves downward into its vertical side also needed some attention, by an Autopian's standards . Even I have to admit it is extremely minute. It sorta resembles a very tiny version of road rash one would see in the clear on a wheel. I was thinking perhaps of getting a hold of some 10,000 or 12,000 grit sand paper and see if I can improve that as well as those half circle shaped indentations because trying to polish by hand in this tight and awkward area probably wouldn’t yield the kind of results I expect but otherwise, that too is relatively minor. Filling with clear might be option also No rush to try fix it, if I do (don’t want to dig myself a hole ) and these things may truly be a case of “to leave well enough alone”. However,I do welcome feedback about addressing them.
my product collection
My Detailing Credo
Old 03-02-05, 03:39   #2 (permalink)
Bill D's Avatar
Bill D is offline
Upon a wipe down with Prep-All, I used a PC with a 4” white LC polishing pad and 3m PI III MG to polish most of the area . Around the “road rash-like” and half circle marks in the paint I tried Menzerna IP and a yellow cutting pad. No notable improvement. These minute, grainy-textured defects don’t seem to be a candidate for correction via PC or Cyclo and one must be extremely careful of paint heating up on a bumper with any thing more aggressive so I continued to play it safe. That’s why the very high number wet sand paper came to mind. I made a final pass with the PI III MG over the entire area.
I followed with a typical Klasse-Souveran topping. The Bumper Plugs have also received the same treatment. This beats the hassle of a body shop fill-in fix risking unknown results ( can always be done at a later date if I find a super shop) or getting a new bumper all together.
If you don't like the look of the key holes in your doors, (and, of course, use a functional remote) the keyhole plugs are a very attractive touch to the car's appearance. I'd highly recommend them These were the items that delayed my shipment but they were worth the wait. I wish the photos turned out better
You also probably noticed the clear film over the door handle cup. That’s simply a piece of clear static cling-on plastic, following the idea of paint protection film. I just shaved the pieces to fit under my door handles the best I could. I do understand Stongard makes exact door cup guards like these. I would imagine trying to squeegee them on into place in these spots could be challenging though. I’ve had my version for quite some time now and I’m pleased with them.
My Detailing Credo
Old 03-02-05, 03:39   #3 (permalink)
Bill D's Avatar
Bill D is offline
Here are my attempts to capture the overall look of the car now with the Bumper Plugs.
Also, here's the Caddy's front look with its 3D emblem plate:
As an alternative to Bumper Plugs themselves, you could go to an auto parts store and find plastic retainers intended for trim or body splash guards or fascia which accommodate a ¼” hole. The retainers themselves would have to have a smooth texture, nothing grainy. If you’re savvy at spray painting you’d probably have to carefully layer several coats of OEM spray paint. This should do it for a lot less $$ although it appears to me the Bumper Plugs are professionally baked and cured.
My Detailing Credo
Old 03-02-05, 03:45   #4 (permalink)
Senior Moderator
Pats300zx's Avatar
Pats300zx is offline
Bill....
Where did you get the plugs from. I have the same issue with my Black 350Z. I would love to plug those holes up.
Old 03-02-05, 03:47   #5 (permalink)
Bill D's Avatar
Bill D is offline
Hi Pat,
You could buy the plugs painted to your color from http://www.bumperplugs.com . Just have the courage to drill if your existing holes are a little too small
My Detailing Credo
Old 03-02-05, 03:55   #6 (permalink)
Ari Gold
G35stilez's Avatar
G35stilez is offline
Holy ****!
A picture of Bill D's Audi .
Looking good man. I gather that flash on the front bumper shot is prior to polishing?
'02 Escalade
'08 Legacy
Old 03-02-05, 04:10   #7 (permalink)
TOGWT is offline
Contact: Send a message via ICQ to TOGWT
Great write-up/useful information, thanks
JonM
Old 03-02-05, 04:10   #8 (permalink)
Bill D's Avatar
Bill D is offline
Yep, I'll take a closer look at it and I'm sure I'll be laboring under the halogens again I can't get rid of parts of the outline of the former plate holder for now.....
My Detailing Credo
Old 03-02-05, 04:13   #9 (permalink)
L33
Buff
L33 is offline
Contact: Send a message via AIM to L33
oooooooohhhh bbbumper plugs, i mis-read the title.
'98 ///M3 Estoril Blue 5spd vert
Old 03-02-05, 04:19   #10 (permalink)
Pursuing Wheel Cleaners
dcswd's Avatar
dcswd is offline
Looks nice. I like the work you put into all of it. For most, just buying the bumper plugs and sticking them in would be too much, but for the few, not even that is enough
Old 03-02-05, 05:30   #11 (permalink)
Bill D's Avatar
Bill D is offline
That is very true. I'm going to have to inspect very closely again. Knowing me I'll find something again I won't be satisfied with it
My Detailing Credo
Old 03-02-05, 06:05   #12 (permalink)
Good post Bill. I like how it looks with the plugs a *lot* better. I'd always wondered how nice the stuff from BumperPlugs was. Heh heh, you're a brave man to fill the lock cylinder holes. I think I would've gambled on enlarging the bumper holes before I gambled on the remote always working
I think I too would try the ultra-fine grit wetsanding before I tried aggressive polishing. Get some of that stuff from MicroMark.
The little dimples, well, you might just have to live with those.
