Turbos are big, but superchargers are affordable. $2395, bolt-on (and an extra $200 for the Bipes Boost Timer). And turbos are mucho upgradeable, but I just want "Miata plus", no-fiddling driveable reliable horsepower.
Stock rwhp = about 109, w/SC = about 162. (From a typical dyno run, can be found anywhere on the 'net)
Stock torque = about 102, w/SC = about 150.
All numbers measured at the wheels; stock hp and torque #s are like, 142/130, or something like that.
Currently, I have a header/freeflow cat/ hp exhaust/muffler, so I'm looking to be about 170-175 rwhp, including the optional boost timing control unit (not used in the above hp/torque figures). And, the kit I'm getting includes a different pulley set for "an extra 20-25 hp over the standard kit!" I figure with everyone being optimistic, I would be around 185 to 190 rwhp, so the truth will probably be around 170 (185 minus 15%, plus the exhaust and BT unit not accounted for in the original estimate).
It should definitely be "Miata Plus".
And, the unit is visually appealing under the hood, as well; I mean, this
is Autopia, the place where these things matter.
Tom
