04-10-03, 06:39
Senior Moderator
Brad B. is offline
getting ready for the weekend Driving Event!
I am checking my Carrera C4S over for this weekends driving event at Gateway International Raceway in St. Louis. I am adjusting up the Bilsteins from street mode to track settings and checking everything for safety.
The photo illustrates how stiff the Porsche chassis is.
<img src="http://fototime.com/C88DBE570861B7E/standard.jpg" border=0>
04-10-03, 06:53
Opus is offline
Very nice...amazing aren't they? I'm getting ready for DE here at Road Atlanta, taking my 79' 930 Turbo and going to try and stay on the track..facing the right direction.....
Do you use any of the clear film protectors on your car for events?
Cheers!
04-10-03, 08:46
Got secondaries?
Aurora40 is offline
Re: getting ready for the weekend Driving Event!
Hope you have fun, but doesn't that pict just illustrate where the car's center of gravity is relative to the jacking point?
04-10-03, 09:28
Senior Moderator
Brad B. is offline
Re: Re: getting ready for the weekend Driving Event!
It's true, the Carrera is rear weight biased, but when the jack is put under the front jacking point ( a few inches behind the door seam) and the front wheel is raised off the ground the rear will follow as well! These cars are tight.
04-10-03, 09:33
Senior Moderator
Brad B. is offline
Cheers!
I have the entire nose and arches behind the front and rear wheels covered in film to protect from chips. I still may cover the car with a padded bra which covers additional areas.
<img src="http://www.fototime.com/69DEC6D706B7AF8/standard.jpg" border=0>
<img src="http://www.fototime.com/54355A3F1B11B46/standard.jpg" border=0>
04-10-03, 10:02
weekend warrior
JustinTRW is offline
Good luck Brad! And watch that tail coming around!
04-10-03, 10:35
Got secondaries?
Aurora40 is offline
Re: Re: Re: getting ready for the weekend Driving Event!
Well, not just front to back cg, but top to bottom too (and left to right, but that should be pretty much in the middle). All I mean is most cars don't do that, but not because the frame bends like a noodle or anything. Suspension travel/stiffness would likely play a part as well. I'm sure your car is tight, though.
04-10-03, 10:44
Survey Monkey
IndigoGTI is offline
Re: Re: Re: Re: getting ready for the weekend Driving Event!
If you look closely, you can see that not only is the passenger side raised up, but the driver's side rear is also coming up. Considering the jack is under the frame rail which looks to be about 10" inside the rocker panel, that is an extremely stiff chassis. Of course, I would expect nothing less from a Porsche.
-Chris
2001 Absolutely Red Toyota MR2 Spyder, 2003 Platinum Grey Jetta 1.8t
04-10-03, 01:20
A garage would be nice...
RemmoSi is offline
What a beautiful machine to take to a track and let it run free. I'm very jealous.
It's so shiny too.
Remmo
'99 MR Civic Si
04-14-03, 02:43
Senior Moderator
Brad B. is offline
Originally posted by RemmoSi
It's so shiny too.
It's not so shiny now! But it was worth it!!!!! My weekend DE event at Gateway International Raceway in St. Louis was a blast. I ran through two tanks of Premium gas. I think I got about 5mpg. I guess hitting the rev limiter so often is bad for fuel economy? I took about 5000 miles off my Bridgestone SO2's. I cut about a year out of my brake pads. And I'm gonna sign up and do it again as soon as I can. Woohoo!
<img src="http://www.fototime.com/A47D879B2746DB3/standard.jpg" border=0>
<img src="http://www.fototime.com/087EAFE574525FF/standard.jpg" border=0>
<img src="http://www.fototime.com/C9E27881961C015/standard.jpg" border=0>
<img src="http://www.fototime.com/7CDC37DF75BD464/standard.jpg" border=0>
04-14-03, 03:07
Mr. Anderson?
2wheelsx2 is offline
Yep, pinging engines off the rev limiters are hard on gas mileage. When I took my Beemer (yes, a bike) to Laguna Seca last year. I burned off the brakes pads down to the backing almost, and got about 200 km out of the tank, when I normall get almost 400 km out of a tank.
Oh yeah, you're going to spend a lot of time cleaning off the rubber marks from the melted rubber too. Check your oil too, I bet you're down a bit there too.
Gary
04-14-03, 08:46
Got secondaries?
Aurora40 is offline
Re: Re: Re: Re: Re: getting ready for the weekend Driving Event!
That's two neat tricks: a) being able to lift the whole car up from one side and b) being able to tell the drivers side is coming up when you can't even see the wheels.
Anyway, those picts are great Brad! Looks like it was a lot of fun!
