Old 01-28-03, 10:41   #1 (permalink)
Track addict
02 t-wrex's Avatar
02 t-wrex is offline
Contact: Send a message via ICQ to 02 t-wrex
Monster brakes for the Scooby
Since I do quite a few track days in my WRX I was getting very tired of inadequate brakes... so I called up Stoptech and ordered thier big brake kit
So here are the teaser pics, I'll take more pictures during and after installation and post them tomorrow. They looked pretty big to me in pictures, but once I actually got them in my hand they are HHUUGGEE!!!
Here are the specs:
-328mm x 28mm 2 piece AEROROTOR front rotors, slotted
-ST-40 4 piston aluminum front calipers (same caliper as Ferrari F40)
- 6061-T6 Aluminum caliper brackets
-Stainless steel braided brake lines (DOT approved teflon coated to keep dirt out of the braids)
-slotted rear rotors, stock size
-Axxis Ultimate brake pads
-Motul RBR600 racing brake fluid
-Chip
2002 Subaru WRX (World Rally Blue Pearl), 1989 Alfa Romeo Milano (Black)
http://www.fastalfas.com
Old 01-28-03, 11:20   #2 (permalink)
Bill Lessard is offline
I was watching Two Guys Garage on Speed Channel tonight, and in thier segment on parts they were showing cadminum plated rotors for different cars and trucks. I don't remember the company that makes them, but it sure sounds like the end of rusty rotors are in the near future.
No more wire brushes or pulling the rotors off to had them bead blasted. Just install and drive. Products just get better and better! Check out Twoguysgarage.com. Enjoy!
BGL
Old 01-29-03, 06:03   #3 (permalink)
Lowejackson's Avatar
Lowejackson is offline
Just on looks alone, they should knock a few seconds off your lap times.
Steven
Old 01-29-03, 09:44   #4 (permalink)
Track addict
02 t-wrex's Avatar
All I want is CONSISTANT brake performance! I'm tired of bleeding brakes and toasting rotors at the track and having to constantly worry about brakes. Every car I've had on the track I've had to worry about brake fade after only a few hard laps. Best part about the kit is that it's LIGHTER than the stock brakes, because of the 2-piece rotors with Aluminum hats and aluminum calipers. Less unsprung weight =
Alfa 164S - way too small brakes for the size/weight of car, one stop from 100+ and the brakes were starting hurt.
Alfa Milano - Constantaly worrying about boiling fluid because of those pesky inboard rear calipers, finally solved with side-exit exhaust and vented rear rotors.
Subaru WRX - for some reason of another we got smaller brakes on the US version, probably because our version comes with 16" wheels rather than the 17s they get in Europe & Japan Now I'll have better brakes than the STi
-Chip
Old 01-29-03, 10:21   #5 (permalink)
Mr. Anderson?
2wheelsx2's Avatar
2wheelsx2 is offline
Contact: Send a message via AIM to 2wheelsx2 Send a message via Yahoo to 2wheelsx2
You are going to be using race brake fluid full time? Are the race fluids more hygroscopic than street fluid? Are you not worried about day to day performance? Or do you plan to change the fluid once a month?
Gary
Old 01-29-03, 10:36   #6 (permalink)
Track addict
02 t-wrex's Avatar
I've always used Motul RBF600 in my cars, for street and track. Race fluids ARE more hygroscopic than regular fluid, but I've never had a problem with it... although I change fluid once a year, sometimes more. I usually bleed the brakes before each event, so that's a partial fluid change every other month and then a full fluid change every year or two. Pedal has always stayed nice and firm, but after a while I'm sure the boiling point will be affected by the moisture in the fluid.
-Chip
Old 01-29-03, 10:46   #7 (permalink)
Mr. Anderson?
2wheelsx2's Avatar
Oh, I just noticed you're in San Diego. Probably not as much of a problem as us up here in the Pacific Northwest. But I just might give the race fluid the next time I track my bikes. Thanks.
Gary
Old 01-29-03, 10:55   #8 (permalink)
Would some sort of ducting not help on the Milano? I would have thought that confidence in the brakes is critical on the racetrack. I think your being a little hard on the 164 though, its brakes are fine (not the best by anymeans) for the road.
It seems strange that the WRX would have different brakes than elsewhere in the world
Steven
Old 01-29-03, 10:55   #9 (permalink)
Track addict
02 t-wrex's Avatar
That's true, I'm sure the climate here in Southern California helps a lot. The car lives in the garage at night too, so really the only time it's exposed to moisture is the 5 days per year it rains here
-Chip
Old 01-29-03, 11:07   #10 (permalink)
Track addict
02 t-wrex's Avatar
Steven
I have brake ducts in the front of the Milano, coming from the foglight openings, but there really isn't any easy place to put ducting in the rear because of very limited ground clearence. I was actually thinking of replaceing the side windows with Lexan and adding a clear lexan NACA duct to each rear window which would feed a duct that could run through the rear floor area and right to the rear caliper & rotors. It isn't too much of an issue on the Milano anymore, because I'm not running enduro races here... just 30min sessions.
You're right, the 164 brakes are fine on the street.. and actually pretty decent with some high-temp fluid and uprated pads, but a little inadequate on the track I think.
I think the US WRX got 16" wheels because of cost cutting, and then the brakes wouldn't fit under the wheels so they were made smaller. Or maybe it's because most Americans prefer a squishey ride over performance so they wanted a higher profile tire... I can't remember the exact reasoning behind it.
-Chip
Old 01-29-03, 11:32   #11 (permalink)
Let us know how these new brakes work.
Steven
Old 01-31-03, 03:02   #12 (permalink)
Track addict
02 t-wrex's Avatar
Ok guys... here are the pictures of the installed StopTech brakes like I promised. The kit fit perfectly and looks awesome. The black anodized hats on the rotors are a nice touch, no more rust! I think I'll nickname these "The hand of God"! After bedding them in they work AMAZINGLY! Very good brake feel and easy modulation... and NO FADE!
Enjoy the pics, sorry the car was kinda dirty
Here's everything I installed:
328mm front rotors, 4-pot calipers, SS lines & Axxis Ultimate pads installed:
Stock size slotted rear rotors, Axxis Ultimate pads, & SS lines installed:
Front brakes with the wheel installed:
Rear brakes with wheel installed:
Size comparison of front brakes, StopTech on left, stock on right:
My updated mod list:
Vishnu Stage Zero
-catless uppipe
-underdrive pulley
-piggyback engine management
-boost controller
-colder plugs
Prodrive springs
Whiteline Anti-lift kit
17x7.5" Rota SDRs with 225/45/17 Falken Azenis
Stoptech big brake kit
-328mm slotted front rotors
-4 pot front calipers
-Axxis Ultimate pads
-SS braided brake lines
-Motul RBF600 brake fluid
Painted sideskirts (DIY)
BLACKFIRE!
Coming in the next week or so:
Cusco adjustable rear swaybar
Kartboy solid rear swaybar endlinks
Cusco rear strut brace
-Chip
