Old 12-26-02, 04:53   #1 (permalink)
James A is offline
Exhaust system,, Help
I need some custom bending done on some 2 inch exhaust pipe, but I really need it mandrel bent. In order to keep the flow optimized a standard bender that necks the pipe down just won't do. Do any of you know of a shop that has a mandrel bender that will keep the nominal inside diameter of the pipe while bending 45 degree angles in it? I am in Houston but will be glad to send the pattern to any shop that can do the job right.
Old 12-26-02, 06:06   #2 (permalink)
Black02Z28LS1's Avatar
Black02Z28LS1 is offline
Contact: Send a message via AIM to Black02Z28LS1
try http://www.laneswheels.com/ cause he makes custom mandrel bent exhaust for camaros and trans ams in texas maybe he can make you an exhaust system
03 Yellow Chevy Silverado w/20 inch rims
Old 12-31-02, 02:51   #3 (permalink)
James A is offline
Thank you for the tip, I have snet an EM to Lane's.
Old 01-01-03, 03:11   #4 (permalink)
your welcome hope Lane can help you
Old 01-01-03, 05:55   #5 (permalink)
Time's a-wastin',speedy!
TortoiseAWD's Avatar
TortoiseAWD is offline
Contact: Send a message via AIM to TortoiseAWD
Also, I believe you can order mandrel bends from Summit or Jeg's . . . these are short sections of mandrel-bent pipe of varying degrees, 45' being common, I'm sure. It means a couple of extra welds around each bend to fit it into the exhaust at the correct orientation, but it is an option if you know a welder you can trust. The entire intake and exhaust on my Talon was fabricated in this way.
Tort
If you wish to make an apple pie from scratch, you must first invent the universe. — Carl Sagan
Old 01-02-03, 10:16   #6 (permalink)
James A is offline
Thanks Tort, that's not a bad idea and I do know a good welder. I'm going to look at Summit on line and see what they have.
