Old 09-01-09, 09:11   #1 (permalink)
The Enforcer is offline
help cleaning burnout rubber out of wheel wells!
today i detailed a GTO that has been at the dragstrip alot. the rear wheel wells were CAKED in rubber, prob 1/4 inch thick on the back of the wells. what methods are people using to easily get this rubber off?
i sprayed the wheel wells down with a heavy duty APC diluted 5:1 (this stuff is recommened 10:1 for heavy things, i went even heavier). it took me about 20 minutes on each wheel well to get it clean, and then it wasnt even perfect, just about 95% of the rubber was gone. i used a regular fender brush to scrub it down, but found that my hand (rubber glove) worked better at rubbing the rubber off than the brush did.
Old 09-02-09, 08:03   #2 (permalink)
Formerly carn00bie
gofastman is offline
Re: help cleaning burnout rubber out of wheel wells!
Im guessing you're gonna need mechnaical agitation rather than simple chemical removal, try a strong car wash mix to provide lubricatin then got nuts with a bug scrubber. 400* rubber flung onto a plastic part is gonna be pretty persistant.
Formerly carn00bie
Old 09-02-09, 08:28   #3 (permalink)
well....i mixed up some heavy duty APC twice as strong as they suggested for "heavy cleaning"......and scrubbed with a stiff fender brush....didnt work very well. i knew i would need to manually remove it, instead of rinse on/rinse off type thing. i wouldve tried a big scrubber, but i would want the rubber to get in the netting and ruin it!
Old 09-02-09, 03:35   #4 (permalink)
alowe is offline
Putty knife???
Old 09-02-09, 03:44   #5 (permalink)
...good idea!
Old 09-19-09, 05:30   #6 (permalink)
thump_rrr's Avatar
thump_rrr is offline
I go to the track very often and the best method is cold water and your bare hands to start.
Once you get all the loose stuff off I use Stoener Tarminator.
To prevent this from reoccuring once the wheel wells are clean and dry spray 2 coats of Geddex Burnout Guard.
Wheel Cleaning Problem redvalkyrie Car Detailing 4 04-18-07 03:57
Washing & Drying DavidB Guide to Detailing 0 11-10-06 02:19
Cleaning wheel wells Intercooled Car Detailing 30 09-23-04 11:25
Maguires Engine Kote and wheel wells mgk65 Car Detailing Product Discussion 5 02-26-04 08:26
Cleaning wheel wells? waxman Car Detailing 5 08-22-01 09:15
