Old 06-16-09, 06:44   #1 (permalink)
jhe888 is offline
What do you think of super halogen bulbs? (Silverstar, etc.)
The Silverstar Ultras, in particular, or the Philips X-treme? I am sure they are brighter. Do you think they are worth the cost (at least double), especially in light of their shorter lifespan?
I don't want HID. Any other options or brands?
Thanks.
Old 06-16-09, 06:48   #2 (permalink)
Wicked Pissah
BostonBull is offline
Re: What do you think of super halogen bulbs? (Silverstar, etc.)
Toshiba HIRare the best and vrightest bulbs out there short of HID. about same cost as Silverstar, lil bit more. only guy I know that sells the is on ebay.. search toshiba HIR. I won't run any other bulbs in my car. those in the lows and fogs, and haven't used my highs in over a year. put them in my wifes car and she was amazed. have actually used them in all vehicles for 3 years now.
great stuff!
Old 06-16-09, 06:58   #3 (permalink)
jhe888 is offline
How is the life on the HIR bulbs?
Old 06-16-09, 07:24   #4 (permalink)
PedroDaGr8 is offline
If you are REALLY serious about getting more light out of your headlights, look into making a wiring harness. Many times the wiring to the headlights is under spec'd which causes a voltage drop.
Taken from Daniel Stern Lighting:
In many cases, the thin factory wires are inadequate even for the stock headlamp equipment. Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages:
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens ←Rated output voltage
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens ←Rated life voltage
14.5V : 1528 lumens
As you can see, if you battery is at 14V (a common voltage) and your wires are dropping the voltage to 12V you just lost 40% of your light just in those 2V. Similarly, by increasing the voltage you exponentially increase the light output.
A harness is EASY to make if you are interested and I can provide you with the needed schematics to make it.
Just tell me your bulb size(s) and I'll whip one up. I did this on my car before I did a retrofit and I must say it made a noticeable difference.
Old 06-16-09, 08:09   #5 (permalink)
jhe888 is offline
That is very generous, Pedro. The bulbs are 9006/9005. Thanks.
Old 06-16-09, 09:10   #6 (permalink)
jDizzle is offline
Contact: Send a message via AIM to jDizzle
the silverstar ultras are deffinatley nicer than stock. but not worth double the price.. mine lasted a little over 6 months, which is crap in my book... im deffinatley going to have to watch this thread, and hopefully learn of some better bulbs.
Old 06-17-09, 02:49   #7 (permalink)
Wicked Pissah
I have had HIR's installed in my, and my wifes car for well over a year now with no problems. The biggest thing is do NOT touch the bulb with your skin during install!
Old 06-17-09, 02:51   #8 (permalink)
Wicked Pissah
Here ya geaux!
eBay Seller: hir headlights: Parts Accessories items on eBay Motors
Old 06-17-09, 03:03   #9 (permalink)
critical_level2's Avatar
critical_level2 is offline
I have had silverstars in my last 3 vehicles and liked them. I got plenty of life from them. The ones in my Explorer were 4 years old when I traded it in and they still worked. I also had them in my Honda Element and they were still going strong when I sold it 3 years later. I have had great success with them. I also wear latex gloves when I install them to make sure I did not touch the bulbs, which equals certain death for any halogen bulbs. I had a wiring harness in my explorer and that really helped increase the output of them.
Working on becoming an Autopian Driveway Detailer
Old 06-17-09, 04:54   #10 (permalink)
Alright, here is the schematic for your wiring. You should use atleast 14Gauge or higher wires (12G is ideal or 10G if you plan on running high wattage bulbs).
You will need:
2 30A bosch style relays
1 9005 Male plug
1 9006 Male plug
Then either 2 9005 or 9011 and 2 9006 or 9012 female plugs. They may be the same I am not sure. These will plug into your bulbs (the latter are if you go the HIR route).
Some soldering skills and waterproof heatshrink(better or waterproof connectors (acceptable if you can't solder)
Some loom or electrical tape to wrap the wires.
In the schematic I show all of the bulbs connecting together and grounding to the battery. In reality, each bulb will have its own ground and if you have suitable ground points near by you can use those. On the other hand if you don't run each bulb to the battery.
Also, both the red, orange and blue wires are power. The blue is power from the socket to the signal on of the relay. The red and orange are power either from the battery or out of the relay to the bulbs
THe black and the yellow are grounds. The yellow is the socket ground (this MUST be hooked up to the socket).
When wiring everything, you only need to use the sockets on ONE side of the car. The other side can be left empty.
Lastly if you decide to use HIR bulbs:
How to convert 9011 and 9012 HIR bulbs in to 9005 and 9006 bulbs.
HIR 9011 and 9012 bulbs are exactly identical in all dimensions to 9005 and 9006 bulbs, except for two areas, the second of wh
Old 06-17-09, 06:08   #11 (permalink)
jhe888 is offline
Thanks, Pedro.
Old 06-17-09, 06:16   #12 (permalink)
No problem. It's pretty quick and easy to make. Took me about an hour the first time, the second time it too me under 30 minutes.
Wax Shop's Super Glaze HD (high definition wax) Scottwax Car Detailing Product Discussion 6 05-07-09 12:27
SilverStars John Styrnol Exterior & Performance 112 01-31-06 02:27
Fluorescent Bulbs and Color Temperature? Shiny Lil Detlr The Man Cave 8 03-02-05 11:26
Halogen exspectations NVCobra Car Detailing 2 10-17-04 10:32
for those with silverstar headlight bulbs gnahc79 Exterior & Performance 23 12-31-03 06:26
