Re: where to get a lift kit for my truck??
Although I don't drive my lifted SUV much anymore (5" spring lift), I enjoyed it a lot for a long time. I'll put it back into limited use this fall, but just wanted the OP to be aware that lifting a truck isn't just a quick buy of a kit and you're done. At the very least, on a spring lift, you'll probably have to adjust front driveshaft and steering angles. On a big lift, there's a lot more to consider. On a body lift, there's shifter lengths, and all kinds of fun to deal with. But the geometry of the driveline and steering don't change, so that's an advantage.
Really does depend on why the lift is desired.
1991 Range Rover Black on Tan (gotta submit to the before and after contest)
2002 Subaru WRX Midnight Blue Pearl
