Old 06-05-02, 12:02   #1 (permalink)
u571 is offline
Contact: Send a message via AIM to u571
can any car have an intercooler?
please explain to me about intercoolers, all i know is that turbo cars have them and they improve performance by cooling air so it can expand more in the pistons.
Old 06-05-02, 06:47   #2 (permalink)
bretfraz is offline
google search 0wNz j00000
http://www.spearcointercoolers.com/
Old 06-05-02, 01:08   #3 (permalink)
The Red Baron
Mugenman is offline
By physics, cooler air is more dense, and contains more oxygen......
If we have more oxygen, we can add even more fuel.....
And, we raise even more the boost pressures......any gas heats up on compression, after such amount of boost, the air charge will heat up so much that it will melt your pistons.....so that´s the use of the intercooler, it is used so that the air charge temperature is reduced, and higher boost pressure is achieved....
All turbo cars have an intercooler (gas), but typical performance mods for them include a front mount intercooler (that shiny radiator you see) which allows for higher flow, and higher temperature drop, allowing for higher boost pressures......
Old 06-05-02, 02:02   #4 (permalink)
Cya, & take the care eh?
4DSC's Avatar
4DSC is offline
Are you wondering if any non-turbo car has any use for an intercooler? Only turbocharged (not supercharged which is a different animal) cars can use an intercooler to reduce intake charge temperatures. This is because turbos use the very hot exhaust gas to power the turbo's compressor.
Brian
Old 06-05-02, 03:44   #5 (permalink)
Time's a-wastin',speedy!
TortoiseAWD's Avatar
TortoiseAWD is offline
Contact: Send a message via AIM to TortoiseAWD
Actually, there's no reason why a supercharged engine couldn't be intercooled, as well. Supercharging and turbocharging are different sides of the same coin: forced induction. Both use a compressor fan to suck more air through the intake than would be provided in a naturally aspirated vehicle. The difference? The supercharger compressor is typically belt-driven, while the compressor on a turbocharger is attached to a turbine that is driven by exhaust gases. Both systems of forced induction heat the intake charge and can benefit from intercooling, but most supercharger setups only supply low-pressure boost, and intercooling is often not included because of the additional plumbing required.
The heating of the intake charge in a turbocharger is due to the compression of the intake gases, not because of the hot exhaust that powers the turbine . . . superchargers heat the air in the same manner, just typically not as much because of the low-pressure application.
That said, not all turbos have intercoolers (you can run a low-boost application with a small turbo, and as long as intake temps don't get too high, there's no need for one), and some superchargers do utilize intercoolers(you can run high boost with the right kind of supercharger, and then intercooling becomes beneficial).
Tort
If you wish to make an apple pie from scratch, you must first invent the universe. — Carl Sagan
Old 06-05-02, 03:54   #6 (permalink)
The Red Baron
Mugenman is offline
May I add that it depends on the type of supercharger, if it is a Eaton type one (jackson racing for instance) you cannot intercool it since it is one part with the intake manifold.....
If you are running a regular supercharger such as a vortech, then yes, you can intercool it, but typically water to air intercoolers are used, as there isnt enough space in the engine compartment for the tubing a front mounted intercooler needs....
Old 06-05-02, 05:01   #7 (permalink)
4DSC's Avatar
4DSC is offline
Hmm, I'm glad the people on my other forum aren't reading this. They'd tear me a new one!
I stand corrected.
Brian
Old 06-05-02, 06:12   #8 (permalink)
The name says it all
caddyman's Avatar
caddyman is offline
Contact: Send a message via AIM to caddyman Send a message via Yahoo to caddyman
Any car can have an intercooler. But if the car is not forced induction, then the benifits will not be anywhere near an engine that is forced induction. Normally aspirated engines can benifit from intercoolers, but only forced induction engines real see the better part of the benifit.
Get out and Detail your car TODAY!
Old 06-05-02, 07:09   #9 (permalink)
The Red Baron
Mugenman is offline
NA cars will not benefit at all, what´s even worse, they´ll run even worse.....
NA cars run at best with direct air intakes (piping + filter) and what´s even better, cold air intakes, in which the filter sucks air from outside the engine compartment, sucking cold air through an ceramic coated pipe....
NA cars need an intake as restricted as possible, but not to large as to slow the velocity of the air (higher diameter= more flow, but less speed) (same rule applies to exhaust, not always bigger is better).
Old 06-06-02, 11:17   #10 (permalink)
stupid computer
samiam513's Avatar
samiam513 is offline
Contact: Send a message via AIM to samiam513
Eaton is a brand. Not a type. They type eaton makes is roots.
http://automotive.eaton.com/product/...rchargers.html
Old 06-06-02, 02:20   #11 (permalink)
The Red Baron
Mugenman is offline
Yeah I know, but it is the most common one now, it is OEM equipment for jaguar and mercedes, and it´s the one used in jackson racing´s kit......
Old 06-06-02, 07:25   #12 (permalink)
caddyman's Avatar
caddyman is offline
the scew type is uslayy more reliable then the centrifugal type superchagers, thats whay it is the most commonly used on factory aplications!
